What cables should I run to my projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 31 Old 01-25-2012, 09:40 PM - Thread Starter
FHT123's Avatar
Working on a build in my basement, still very early on in the build, however the studs are up and alot of the wiring is in place.
Any suggestions on which cables I should run to a projector? Beyond a single HDMI cable?
FHT123 is offline
post #2 of 31 Old 01-25-2012, 09:43 PM
aaustin's Avatar
Liked: 36
I ran one HDMI, a snake of 5 RCA, and a cat 5e. Plus power of course.
The Austin Home Theater:
aaustin is offline
post #3 of 31 Old 01-25-2012, 09:59 PM - Thread Starter
FHT123's Avatar
Why did you run more then the HDMI? Do you use the 5 RCAs? The ethernet?
FHT123 is offline
post #4 of 31 Old 01-25-2012, 11:57 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
1) High quality HDMI (Blue Jeans Cable or similar)
2) 2-4 Cat5e/Cat6 (Ethernet, 2x HDMI-over-Cat5, IR/RS232/Future)
I'd skip the RCA's, and instead run flex conduit (empty) to future-proof. If you ever need to run component and/or another HDMI, easily done with one or two of the Cat5's.
I ran HDMI, 3x Cat5e, an IR emitter cable and conduit...
Jeff
jautor is online now
post #5 of 31 Old 01-26-2012, 05:52 AM - Thread Starter
FHT123's Avatar
Great idea! I forgot about the IR emitter cable, does Monoprice sell those?
Why run cat5 to a projector?
FHT123 is offline
post #6 of 31 Old 01-26-2012, 06:08 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 100
CAT5 or 6 to projector:
1. You need one cable for either IR or RS232 to control the projector;
2. More and more projectors have ethernet connectivity for control, remote diagnosis, set up, proactive notification of faults or predictive failure, so you need a Cat5/6 for that (some systems provide IP for set up and diagnosis but won't provide the ability to use the IP connection for interface to a control or IR system);
3. Should you have an issue with your HDMI cable, now or in the future, you can use a balun or HDBaseT device to run HDMI over one, or two, CAT5/6 cables.
That then is a total of four CAT5/6 cables.
When would you run five RCA cables? You may have legacy devices in your system which will not have an HDMI output ... so unless you want to replace those items, you need to provide for RGB or RGBHV input into the projector.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
Dennis Erskine is offline
post #7 of 31 Old 01-26-2012, 06:34 AM
Quoted: 3255 Post(s)
Liked: 2743
Or get a receiver that switches and converts all legacy RGB devices to HDMI. Like a Denon 4311
post #8 of 31 Old 01-26-2012, 08:12 AM
jautor's Avatar
Liked: 777
Don't know if there's any difference in construction between the Xantech emitter cable:
http://www.smarthome.com/8186/Xantec...-784-00/p.aspx
And any random 3.5mm cable:
But Monoprice has them in a lot of different lengths, too...
It's the swiss army knife (or perhaps a Ginsu?) of cables.
Jeff
post #9 of 31 Old 01-26-2012, 08:24 AM
chess's Avatar
Agreed about the RS-232C, but how do you plan on controlling it ?
Just think about everything you may want...
Agree with jautor, dont run RCA right now
chess is offline
post #10 of 31 Old 01-26-2012, 08:27 AM
NJ Jackals's Avatar
I ran 1 hdmi, 1 component, 2 cat6, and smurf tube for future. Everyone always asks "why did you bother running the component cable?" Until recently my only answer was "just in case". Turns out, I settled on the Epson 6010 for my projector. The projector happens to do split screen PIP but not from 2 Hdmi sources. Only one can be hdmi. The other needs to be analog. Therefore, without my component cable, I would not be able to watch two dofferent games side by side at the same time.
NJ Jackals is offline
post #11 of 31 Old 01-26-2012, 08:33 AM
exipnos's Avatar
How about the power cable? I have a big conduit that will take all the hdmi and cat5 cables. It will also need to have a power cable for the projector. Normally signal and power lines should be separated but in my case I could not do this and need to run them in the same large conduit. Any special consideration in this case for the power cable? Should I use a shielded power cable?
exipnos is offline
post #12 of 31 Old 01-26-2012, 08:54 AM
aaustin's Avatar
Liked: 36
I decided to run the RCA because I had it left over from my theater at the old house. I do have a receiver that upconverts everything to HDMI but I thought "what the heck it can't hurt." It makes me feel good that it's there if I need it.
In terms of the power cable I would run romex outside the conduit to an outlet at the projector location. Then just plug the projector in. You wouldn't need to swap the cord out so putting it in the conduit isn't necessary.
aaustin is offline
post #13 of 31 Old 01-26-2012, 08:55 AM
stockmonkey2000's Avatar
I ran 2 HDMI, one Component, 1 Cat5, AC (Powerbridge) and thermostat for remote fan. I also have a 2" conduit to the projector. I ran 2 HDMI because my Integra processor may not pass 3d. I can hook one output on the oppo to the processor and run the 2nd output directly to the projector on the occasions I watch 3d. I ran component because I have a standalone OTA tuner that has great picture quality that uses component. The integra processor will convert component to HDMI but I ran the component when I was still planning to use an Aragon Soundstage.
stockmonkey2000 is offline
post #14 of 31 Old 01-26-2012, 11:51 AM
exipnos's Avatar
Many years ago when I pre-wired the theatre room, I for some reason only brought in two main cables. Just outside the HT room where my AV equipment will be, I have a lot of dedicated lines that I could use. Thus I wanted to bring in a dedicated line that the projector will use but the only clean way of bringing it in is via the existing conduit.
Will shielded cable be sufficient or should I extend one of the existing HT lines to the projector location?
exipnos is offline
post #15 of 31 Old 01-26-2012, 03:19 PM
I would rather not have a dedicated line than have an AC line running in a conduit with low voltage cables.
post #16 of 31 Old 01-26-2012, 04:51 PM
aaustin's Avatar
Liked: 36
I agree. I have AC passing low voltage in the walls at times but I would not run both in the same conduit.
aaustin is offline
post #17 of 31 Old 01-26-2012, 08:40 PM - Thread Starter
FHT123's Avatar
Talk to me about this AC Powerbridge. I have a Monster Power HTUPS 500 Battery Backup that I purchased a while ago for a projector. I think I might need one of these Powerbridges to get the power cord from the projector over to the equipment rack. Can anyone recommend a inexpensive Powerbridge?
FHT123 is offline
post #18 of 31 Old 01-26-2012, 08:42 PM - Thread Starter
FHT123's Avatar
Also, another question, if I want to do a touch screen jukebox (think Bose touchtunes, what they have in some bars), what cables should I run from the computer to the touch screen? Just a VGA?
From the computer to the sound system, i would assume just a 3.5mm to a RCA Red/White? for the sound? Not looking for high quality sound from it, just functionality.
FHT123 is offline
post #19 of 31 Old 01-26-2012, 08:51 PM
jautor's Avatar
Liked: 777
PowerBridge has an AVS forum discount... There are similar setups available elsewhere, but this is one of the better models.
http://www.powerbridgesolution.com/avsspecialorder.html
And yes, that's what you need.
Jeff
post #20 of 31 Old 01-26-2012, 08:55 PM
dc_pilgrim's Avatar
http://www.avsforum.com/avs-vb/showthread.php?t=1043428
OR cobble the pieces together yourself:
http://www.avsforum.com/avs-vb/showthread.php?t=978306
dc_pilgrim is offline
post #21 of 31 Old 01-26-2012, 09:18 PM - Thread Starter
FHT123's Avatar
thanks for the feedback, going to go with the Monoprice one, i love that site! Anyone know of a good place to go to "create" a custom large faceplate for all of the connections coming out of the wall? I want it to look very clean and friendly when there isnt any equipment there, not daunting with a mess of wires hanging out of the wall.
FHT123 is offline
post #22 of 31 Old 01-26-2012, 09:25 PM
aaustin's Avatar
Liked: 36
It sounds like you're looking for a keystone wallplate. They are plates with empty squares where you can insert HDMI couplers, Ethernet jacks, etc. Monoprice has them. They allow for a lot of customization.
aaustin is offline
post #23 of 31 Old 01-26-2012, 09:29 PM
andymo's Avatar
I run a touchscreen to a small form factor PC for jukebox-ing and it requires a USB to send the touch data, as well as the VGA.
andymo is offline
post #24 of 31 Old 01-26-2012, 09:42 PM - Thread Starter
FHT123's Avatar
A keystone wall plate is perfect!...however I need 18-20 inputs...can't find that many on monoprice...
FHT123 is offline
post #25 of 31 Old 01-26-2012, 09:51 PM
aaustin's Avatar
Liked: 36
What about doing something like this for video, audio, ethernet, etc.
They have 6 hole and 8 hole too.
Then do something like this for the speakers and subwoofer.
They have 7.1 and 7.2 as well.
aaustin is offline
post #26 of 31 Old 01-27-2012, 05:46 AM - Thread Starter
FHT123's Avatar
thanks for the advice, going with the 7.2 for audio and the 12 gang keystone for the video and other cables
FHT123 is offline
post #27 of 31 Old 01-27-2012, 06:06 AM - Thread Starter
FHT123's Avatar
follow up question.....monoprice and keystone ethernet jacks? Anyone know if they have a female to female version? Or is it pretty easy to take a cord apart?
FHT123 is offline
post #28 of 31 Old 01-27-2012, 07:18 AM
oman321's Avatar
Quoted: 127 Post(s)
Liked: 117
Are you looking for an in line coupler?
They have white or black. Easy way to do it if you have a terminated cable already.
If you need to though, it is easy enough to use the cable push down type.
oman321 is offline
post #29 of 31 Old 01-27-2012, 08:23 AM
aaustin's Avatar
Liked: 36
Yup. I just used those couplers since I already had terminated cables.
aaustin is offline
post #30 of 31 Old 01-29-2012, 03:08 PM
rickjsr's Avatar
Do the pros us green glue or is this anothe 'snake oil' product, would ruberrized silicon be an equivlant ot green glue for adhering 2 sheets of drywall together.
rickjsr is offline
