Simple "IR Extender" using standard cabling? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-28-2012, 08:23 PM - Thread Starter
joako's Avatar
Anyone knows of a simple/cheap device to extend infrared? I have a Comcast STB about 75 feet from the TV fed using 5x RG59 cables and that works great. Now I would like to be able to change channels while in front of the TV. Any suggestions. Ideally it would use cat5 cable and cost under $50. I looked on eBay and see a few devices that use 3.5mm cables. I don't need multiple anything just 1 IR in and 1 IR out.
joako is offline
post #2 of 5 Old 01-28-2012, 08:45 PM
meyer64's Avatar
Quoted: 282 Post(s)
Liked: 234
meyer64 is offline
post #3 of 5 Old 01-28-2012, 09:41 PM
kromkamp's Avatar
Quoted: 88 Post(s)
Liked: 70
I use this Xantech kit:
http://www.parts-express.com/pe/show...number=182-460
It uses RG6 rather than Cat5 though.
kromkamp is offline
post #4 of 5 Old 01-29-2012, 11:46 AM
bryhemm's Avatar
I used this system:
http://www.amazon.com/gp/product/B00...00_i01_details
It doesn't come as a kit, so you have to buy the IR repeater and power supply separately. I used cat 6 to wire my system up.
http://www.amazon.com/Buffalo-DV9-50...ref=pd_vtp_e_1
http://www.amazon.com/Buffalo-IR-350...ref=pd_vtp_e_3
bryhemm is offline
post #5 of 5 Old 01-29-2012, 12:25 PM
RobertR's Avatar
Quoted: 404 Post(s)
Liked: 563
I use the Buffalo system with cat-5 and it works great.
RobertR is offline
