Riser step lights? - AVS Forum | Home Theater Discussions And Reviews
 1Likes
  • 1 Post By mtbdudex
post #1 of 7 Old 01-29-2012, 06:05 PM - Thread Starter
PhilT3's Avatar
Hey guys...
Anyone using LED's for step lights?
What ARE you using for step lights?
PhilT3 is offline
post #2 of 7 Old 01-29-2012, 07:22 PM
RShlansky's Avatar
Found these online.
RShlansky is offline
post #3 of 7 Old 01-29-2012, 07:34 PM
cheron1701's Avatar
Those look fantastic--where did you find them?
cheron1701 is offline
post #4 of 7 Old 01-29-2012, 07:46 PM
go_habs's Avatar
Check out my build detailed riser pics,wiring and lighting info. We used home depot LED rope lights
Check out my HT Build!
http://www.avsforum.com/avs-vb/showthread.php?t=1379436
Check out my YouTube Channel (Theater tours,bluray reviews all things tech)
http://www.youtube.com/user/bigky226?feature=mhee
go_habs is offline
post #5 of 7 Old 01-29-2012, 09:06 PM
RShlansky's Avatar
post #6 of 7 Old 01-29-2012, 09:43 PM
bluejayht's Avatar
bluejayht is offline
post #7 of 7 Old 01-30-2012, 08:03 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
I got this riser lighting project done 3/6/2011, (via member Tupalev thread, as I got the Riser lip lighting idea from him.)
Since that thread in 2009, I added 1" x 1" alum angle to keep the rope light projected downward, and got rid of the blue painter tape I had on there all this time.
It really made a huge difference.
Total cost: $25 for lights and under $20 for the alum angle, call it $45 total.
I was ready to paint the alum L green, but not needed at all.
It blends in with the carpet fine, and the alum inside helps reflect light down in a safe walking zone.
At full power almost zero light spillage now, its all directed downward.
I filed the corners so they are not sharp, a 2" lip takes the 1" angle nicely with still a lip portion showing.
I got on the floor to show detail here:
dabsabre likes this.
mtbdudex is offline
