Honest opinions on soundproofing options - Whisper Clips and hat channel worth it? - Page 3 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #61 of 74 Old 10-25-2013, 06:22 AM
RossoDiamante's Avatar
Originally Posted by GWCR View Post
Full disclosure, the reason for your rework is due to improper installation from your contractor, not the isolation products and concepts correct?
Based on my reading of the last couple of pages of that build thread, you are correct.  A valid question was raised about whether or not that small amount of deviation from ideal practice is enough to cause the amount of decreased performance he is experiencing.  I've seen a couple of interesting posts (I think it may have even been in that same thread) where people have tried to measure the amount of decrease in SPL across their finished walls/ceilings.  But I think most of us really have no idea what we should be expecting as far as objective performance from our design and construction efforts.  It's definitely useful to hear other peoples' experiences knowing what kind of construction techniques they used.  I've chronicled my experience and thoughts so far in his thread.
Diamante Build in DC - Double Drywall, Green Glue, Drywall Furring Channel, Riser, Stage, Bass Trap, In-Wall Speakers, BG Radia, JTR Captivators, Seymour AV, Sony HW-50ES, Sherbourn, Panasonic, Middle Atlantic, Lutron Grafik Eye, Baffle Wall
RossoDiamante is offline
post #62 of 74 Old 10-25-2013, 08:00 AM
jedimastergrant's Avatar
Quoted: 665 Post(s)
Liked: 418
I think I understand some of the frustration. When one is making a decision in a big ticket item like sound isolation you want before and after results that you can in some way apply to your own situation. Very few people are in the position to provide this data. At the very least you would need to have measurements in that room with normal construction meaning single drywall and no decoupling etc. Then rip it down and reconstruct using some application of sound isolation which may or may not Address hvac etc and re measure the room. The noise floor inside the room is relatively straight forward to grasp. But quantifying how well the room prevents sound from escaping just has too many variables for most people to bother with. Every home is different so we can expect wildly different results. Are there hardwoods directly above? Where are the sleeping quarters? Should we measure just outside of an adjoining wall? Or maybe the door? The floor above might be the main concern. Or maybe 2 floors up where the kids sleep. And maybe the room is connected to a stairwell that is also connected to the room where the munchkins are sleeping.
I did set up my speakers and a smaller sub in my room before I ripped the drywall out and listened to the system at various levels and in several locations throughout my house. I did not take measurements of my noise floor inside the room nor did I take an spl reading. I do have my subjective impressions of the noise floor in the room and outside of it. In my situation I do have a hardwood kitchen directly above and the bedrooms are on the second floor. The room is adjoining the stairwell.
I am looking forward to doing some post subjective listening inside and outside the room at those locations for what it is worth. I will be sure to post in my thread hopefully late next month.
jedimastergrant is offline
post #63 of 74 Old 10-25-2013, 08:36 AM
235
235's Avatar
That's right, my contractor did everything as requested except he ended up short-circuiting the clips/channel all around the perimeter of the ceiling. In my post above I was simply agreeing with RossoDiamante about the difficulty of obtaining much post-construction feedback. I was hoping I could avoid cutting open my ceiling to repair the contractor coupling error. I can only see myself living with my current situation if I had sufficient feedback that convinced me attempting a repair would not be of significant benefit. For example if others with similar construction were to tell me foot fall noise on hardwood above their theater was clearly audible inside their rooms then that might sway may to just accept my current results.
235 is offline
post #64 of 74 Old 10-25-2013, 11:45 AM
GWCR's Avatar
Quoted: 17 Post(s)
Liked: 39
Sounds good. Wish I could give you and others meaningful feedback and data here, but as jedi pointed out above, measuring the difference between none, some and full soundproofing is not really practical for most of us DIY HT hobbyists. Initially I relied on test data from the Soundproofing Company, Erskine Group and user experiences from the forum prior to finalizing my design with EG. I think it is healthy to question test data, but at some point you either trust the source or you have to spend the $$ to test it out yourself.
I don't have quantifiable before/after measurements, but I can tell you that the noise floor inside the room is extremely quiet when the door is closed (almost creepily so). No hardwood above, but master BR is above. Sound from inside the HT is mostly inaudible to me with the exception of some really heavy LF scenes, and at that point it is a distant rumble of thunder. Nothing jarring to wake SWMBO tongue.gif.
Bottom line is it was well worth it for me. Everybody's situation and sound sensitivity is different, so hopefully there is a measurable difference for you too. Now cut that ceiling so we can see more progress pics! wink.gif
GWCR is offline
post #65 of 74 Old 11-25-2013, 03:11 PM
STARA's Avatar
WE ARE DOING A hHOPEFULLY PRETTY SOUNDPROOF CEILING--bwt floors in our home for a rental below. Bought mineral wool insulation for soundproofing and now want tips on resilient channel w clips or another option when we tack up the ceiling. We are in Hawaii where shipping costs are horrendous.
ANY TAKERS? The 864 sf lower floor will have mineral wool insulation and now we do:
1. Resilient channels with the clips...and how many clips or is there another way? CLIPS are 10.00 EACH! ouch!!!
Aloha
Alea
STARA is offline
post #66 of 74 Old 11-26-2013, 04:23 AM
Quoted: 3892 Post(s)
Liked: 3328
post #67 of 74 Old 11-26-2013, 05:35 AM
Tom Bley's Avatar
Quoted: 711 Post(s)
Liked: 641
I was going to say the same thing! eek.gif Well under 5 bucks for a Whisper Clip.
Tom Bley is online now
post #68 of 74 Old 11-26-2013, 10:45 AM
STARA's Avatar
I'm in HAWAII--EVERYTHING is shipped in and costs $$$. If you can find whisper clips for 5.00 that are still 5.00 after Hawaii shipment, please let me know! We are also running into shipping time. Can get the resilient track part here but wanted clips that were the iso-mount type to NOT lose ceiling height but they are 10 each as well from Australia £7.68 is around $12.88 PER CLIP. so now the whisper clips would be great but where do I find them for 5.00?
Aloha
STARA is offline
post #69 of 74 Old 11-26-2013, 01:03 PM
Tom Bley's Avatar
Quoted: 711 Post(s)
Liked: 641
Aloha
I use The Soundproofing Company for everything I need as well as a lot of people around here. They offer great support with your projects and offer AVS'ers discounts. You could ask them what shipping would cost, give them a call.
http://www.soundproofingcompany.com/soundproofing-products/soundproofing-clips/
maximus12105 likes this.
post #70 of 74 Old 04-26-2014, 01:22 PM
chidave's Avatar
First of all a HUGE thank you to Ted White for helping me out in emails, he has clarified our thinking AND allowed us to reconsider our whole approach. It seems the best approach is to make all neighbors move about 200 feet away and then to cover our house in a tent made of 5/8" boards sandwiching green glue :-)
Seriously , thanks Mr White for all your help.
theakson
chidave is offline
post #71 of 74 Old 05-02-2014, 06:32 PM
rocksnboarder's Avatar
I think I'm going to try to make my own Whisper clips...
rocksnboarder is offline
post #72 of 74 Old 05-03-2014, 07:25 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2698
Is it worth the trouble?
Mfusick is offline
post #73 of 74 Old 05-03-2014, 04:35 PM
Sorry! Forgot the "lol". Just wish the clips were cheaper for what they are. A couple bends in a thin piece of metal. I could make them in the metal shop I work at, but it's not worth the hassle of asking the owners for something like that.
post #74 of 74 Old 03-06-2015, 08:32 AM
tjcinnamon's Avatar
Quoted: 1277 Post(s)
Liked: 314
Andy's referring to this technique to preserve ceiling height:
If these are blocking is right next to each other how do I nail them in?
tjcinnamon is online now
Hat Channel
