/// Reference Blu-Ray Demo Disc - BD9 (DVD-DL Media + BD50) \\\ - Page 2 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #31 of 1433 Old 02-06-2012, 05:24 PM
shadowcaster's Avatar
Sorry to see that several seeds have hit and run in the last couple of hrs.
"Talk to me Goose"
shadowcaster is offline
post #32 of 1433 Old 02-06-2012, 07:17 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Whoops, sorry, my wife was using the computer and managed to lock it up, so uTorrent wasn't running anymore after she restarted. I'm home, and seeding again.
Kalani is offline
post #33 of 1433 Old 02-06-2012, 07:21 PM
No need for apology, those things happen. It's looking good again.
Anxious to try this disc (I'm at 97% right now). So, SL, a lot more interest than you thought, right?
At least 42 involved in the torrent right now.....not too shabby.
Thanks for going forward with this project !!
"Talk to me Goose"
post #34 of 1433 Old 02-06-2012, 07:30 PM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Anxious to try this disc (I'm at 97% right now). So, SL, a lot more interest that you thought, right?
I have two seeds at different sites and during the weekend I was using/borrowing the neighbor's wifi for an extra seeder.
RPCRT-TV Overscan Reduction
superleo is offline
post #35 of 1433 Old 02-06-2012, 10:25 PM
nickbuol's Avatar
Quoted: 553 Post(s)
Liked: 613
I forgot to increase my torrent upload speed. I was set at only 70 kbps. I just put it to 150 kbps for during the day, and unlimited at night...
nickbuol is offline
post #36 of 1433 Old 02-07-2012, 05:14 AM
carboranadum's Avatar
Quoted: 21 Post(s)
Seeding!
carboranadum is offline
post #37 of 1433 Old 02-07-2012, 11:17 AM
I can confirm that the burned disc will not play on a Pioneer BDP-51FD without severe pixelating/stuttering.
The bitrate is just too high and the DL-DVD can't stream it fast enough. Hopefully, others, with other players, will have better luck because it's a great project.
BTW, the player does play all my other avchd discs, with lower BR, no problem.
"Talk to me Goose"
post #38 of 1433 Old 02-07-2012, 11:27 AM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
I can confirm that the burned disc will not play on a Pioneer BDP-51FD without severe pixelating.
The bitrate is just too high and the DL-DVD can't stream it fast enough. Hopefully, others, with other players, will have better luck because it's great project.
I have confirmed that it won't play at all on my creaky old Panny BD355. I seem to recall the same happened with the test disc, though, which did play fine on my newer Sony (S570). I haven't had a chance to try this new one on my Sony yet, however. I'll be sure to do so tonight, though. Note: I DID replace the two files (in both locations) to maximize compatibility per the notes. If, for some reason, the disc won't play on the Sony BR player, either, I'll burn one without swapping out the two files and see if there is any difference.
Again, though, I recall the preview disc I had played fine in the Sony BR player, so I'm sure that'll be fine. That Panny BD35 is fairly ancient, and due for replacement in the not-too-distant future anyway.
Kalani is offline
post #39 of 1433 Old 02-07-2012, 11:46 AM
nickbuol's Avatar
Quoted: 553 Post(s)
Liked: 613
I wonder if my new Panny DMP-BDT210 will play it, or if I should just wait for the full 50GB BD...
nickbuol is offline
post #40 of 1433 Old 02-07-2012, 12:16 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Blank DVDs are cheap enough to just give it a shot. (Blank BR50s, less so)
Kalani is offline
post #41 of 1433 Old 02-07-2012, 12:33 PM
cybrsage's Avatar
Liked: 154
Seeding...
cybrsage is offline
post #42 of 1433 Old 02-07-2012, 12:37 PM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Bummer guys!!!
It has been my experience that cheap players play these discs better than the expensive ones. I would say that maybe because the cheap players do not adhere as close to the standards as the expensive ones. (?)
Anyone that it plays fine other than my Insignia and Magnavox?
superleo is offline
post #43 of 1433 Old 02-07-2012, 12:46 PM
fight4yu's Avatar
Liked: 43
Originally Posted by superleo View Post
That is correct. BD50 to wrap everything up, It'll be exactly the same as the individual discs but everything on one disc and with a top menu.
Thanks! Can't wait for the BD50 to come up. I promise I will seed at least 5 days.
fight4yu is offline
post #44 of 1433 Old 02-07-2012, 01:13 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Bummer guys!!!
Considering how old and creaky (not to mention fairly low end, even at the time) my Panny BD35 is, I wouldn't worry yet. IIRC, it played fine in my older (tho not quite as old) Sony. I'll confirm tonight.
Kalani is offline
post #45 of 1433 Old 02-07-2012, 07:53 PM
Quoted: 21 Post(s)
How do you burn this to disk? I've got IMGBurn, but there is some extra stuff in the folder structure. I am not familiar with the structure of a DVD.
Help?
post #46 of 1433 Old 02-07-2012, 08:36 PM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Help?
Open Imgburn and select write folder to disc. Then open windows explorer to the folder where you unpacked the bass disc. You should see a "BDMV" folder and a "Index and Movie Files" folder, drag the "BDMV" folder to imgburn. Go to the Label tab on imgburn and type under UDF: Bass Demo disc or the description that you would like. Go the the Options tab and make sure that the UDF Revision is 2.5. then burn...
superleo is offline
post #47 of 1433 Old 02-07-2012, 08:54 PM
Quoted: 21 Post(s)
That sounds too easy! Thank you for the help.
And thank you for putting these together. I can't wait for the BR50!
post #48 of 1433 Old 02-07-2012, 09:37 PM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
"Happiness only real when is shared"
superleo is offline
post #49 of 1433 Old 02-08-2012, 12:39 AM
fight4yu's Avatar
Liked: 43
BTW, I have a question on the quality of the clips between BD9 and BD50. Are they the same quality, or will BD50 offer better quality? Since I have a media server, if the quality is the same, then I can also download the individual discs and use for streaming. However, I do want the best quality.
fight4yu is offline
post #50 of 1433 Old 02-08-2012, 01:35 AM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Same quality. DVD9 has a lower capacity than BR50 (as the numbers indicate), but the files are the same.
Kalani is offline
post #51 of 1433 Old 02-08-2012, 07:39 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
BTW...
Quality is the same as the original disc. If you have an HTPC or media player device, you can play it as as ISO and it should play with menus. On a HTPC I like Total Media Theater, it plays everything and includes ALL the codecs that one might need to play any type of file, plus you can use it as a front end for the files.
superleo is offline
post #52 of 1433 Old 02-08-2012, 08:27 AM
nickbuol's Avatar
Quoted: 553 Post(s)
Liked: 613
Oddly enough, I have no DL DVDs right now. Haven't used on in a while since going Blu... You are right though, if I need to order some media anyway (out of 50GB Blus too), I could just get a few DL DVDs and try it for a lot less than a single 50GB Blu...
nickbuol is offline
post #53 of 1433 Old 02-08-2012, 12:18 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Bummer guys!!!
FWIW, I confirmed it seems to play fine on my Sony S570 (BX57, same thing). Just not on the old Panny BD35.
I didn't try the top menu thing, now that I think about it, but the clips played no prob.
Kalani is offline
post #54 of 1433 Old 02-08-2012, 01:21 PM
fight4yu's Avatar
Liked: 43
Thanks! Will start download soon!
fight4yu is offline
post #55 of 1433 Old 02-08-2012, 02:46 PM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
You can not get to the TOP MENU heading on the segment discs, this button is ONLY for the Blu-Ray disc.
superleo is offline
post #56 of 1433 Old 02-08-2012, 02:49 PM
manthatsnice's Avatar
Downloaded last night in an hour and a half. Started seeding immediately after but haven't seen many leechers.
Cory
manthatsnice is offline
post #57 of 1433 Old 02-08-2012, 05:40 PM
pokekevin's Avatar
Liked: 102
I'm interested to see what you picked for music!
pokekevin is offline
post #58 of 1433 Old 02-09-2012, 12:10 PM
Brad Horstkotte's Avatar
Liked: 68
Subbed, looks nice, bookmarking so I remember to get at the torrent.
BTW - what's this "Kug Fu Panda" movie?
Brad Horstkotte is offline
post #59 of 1433 Old 02-09-2012, 12:26 PM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Just checking to see if you all are paying attention (thanks, I'll fix it)
superleo is offline
post #60 of 1433 Old 02-09-2012, 12:31 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Glad I hadn't gotten around to printing the case cover yet. LOL (it happens to us all...)
Question about the "disc label"... where does that go? Shouldn't a label destined for a disc be round? That image looks rectangular. I assume I'm being a dork and just missing something here...
Kalani is offline
Blu Ray Movies , Blu Ray Players , Panasonic Dmp Bd50k 1080p Blu Ray Disc Player , Sony Bdp Cx960 400 Disc Blu Ray Disc Changer , Playstation 3 160gb System
