/// Reference Blu-Ray Demo Disc - BD9 (DVD-DL Media + BD50) \\\ - Page 37 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #1081 of 1433 Old 01-22-2013, 08:11 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Originally Posted by mflanagan View Post
Are there any updated links for the Cover art? All the ones on the main page are dead frown.gif
Flan
The links had been updated. Box cover, disc labels and all fan art.
RPCRT-TV Overscan Reduction
superleo is offline
post #1082 of 1433 Old 01-22-2013, 08:13 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Originally Posted by Kadath View Post
Got it burned with no coasters on first try! Thanks for putting this together!
One suggestion for next version, is it possible to have the Dolby, DTS, THX trailers available from a menu full screen and not just playing behind the menus? That would rock.
Now on to go build my Ultimate Bass Test music collection =)
These clips are accessible from the "Play All" menu. Once selected you can "chapter next" until you get to that clip.
superleo is offline
post #1083 of 1433 Old 01-22-2013, 09:10 AM
Kadath's Avatar
Quoted: 351 Post(s)
Liked: 226
thanks Leo!
Buncha savages in this town....
Sam Posten
Kadath is offline
post #1084 of 1433 Old 01-22-2013, 12:00 PM
mflanagan's Avatar
Thanks!!
Flan's Theater!
Xbox Gamertag: Darth Flan
mflanagan is offline
post #1085 of 1433 Old 01-22-2013, 12:16 PM
BroncoSport's Avatar
Would anyone be willing to burn this project for someone who doesn't own a Bluray burner? I would love to have this disc. I would e willing to cover the cost of the disc and postage. I can D/L and print the cover art myself.
BroncoSport is offline
post #1086 of 1433 Old 01-22-2013, 12:26 PM
LastButNotLeast's Avatar
Quoted: 1536 Post(s)
Liked: 1144
The whole point is that you don't need one:
"This project is geared to have HD material, audio and video, in a regular DVD that can be played on a Blu-Ray player. Due to size constraints the media has been chosen to be DVD-DL. The final project consists of 1 top menu and 5 segments; Bass, animation, visual, surround and music, where each segments has 8 clips. When I say final project I mean a full Blu-Ray 50gig disc, while in the interim, there will be a segment on its own that will fit into a DVD-DL disc."
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
For most of the time, the here and now is neither now nor here. Graham Swift
LastButNotLeast is offline
post #1087 of 1433 Old 01-22-2013, 12:45 PM
Liked: 1144
Start here:
2011 KC Sub Shootout
2012 KC Blind Sub Shootout
post #1088 of 1433 Old 01-22-2013, 02:09 PM
Kadath's Avatar
Quoted: 351 Post(s)
Liked: 226
Nice, will do!
Sam Posten
Kadath is offline
post #1089 of 1433 Old 01-27-2013, 05:59 AM
strike shadow's Avatar
Originally Posted by Flageborg View Post
Surround Disc is loaded...maybe try this one?
http://kringlyd.no/bluraydemo/surrounddisc/all_in_one/
Hey Flageborg, is there a chance that you put up visualdisc, too? smile.gifsmile.gifsmile.gif The other ones worked very well. Thanks again!
strike shadow is offline
post #1090 of 1433 Old 01-29-2013, 07:42 PM
kajo's Avatar
Originally Posted by superleo View Post
If you re-authored the files though MultiAVCHD you DO NOT need to change the index files MultiAVCHD makes all the necessary changes to the index files and other files. If your intention is to burn the files to disc make sure you choose the AVCHD option of Re-authoring, NOT the PS3 option, this option is for external media such as an external drive or a flash stick.
Once MultiAVCHD has finish its process, you drag the BDMV and AVCHDTN folders into Imgeburn. Also, you should be using UDF 2.5 as the file system for the disc.
Ok I've been reading thru this entire thread to figure out how to get the BASS DISC burnt onto a DVD+DL and able to run it on a PS3 with the menu's and no audio pauses. I have tried the following:
1st Try: Burning the default Bass disc BDMV folder using ImgBurn using UDF 2.5. Result: Doesn't work on PS3 at all.
2nd Try: Burning the Bass disc with the patched index files, and added a CERTIFICATE folder, and labeled the disc AVCHD. Result: DVD loads on PS3. Menu and popup functionality work. But audio cuts out after 10 seconds of playing.
3rd Try: Installed multiAVCHD. Dragged the default Bass disc BDMV folder. Result: the Estimated output is 26.686 GB! Won't fit onto a DVD+DL disc.
I really want to get this disc working on my ps3 with all the menu's and without the audio loss. Any help is appreciated.
kajo is offline
post #1091 of 1433 Old 01-30-2013, 06:31 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
I believe that the "Estimated ouput" that MultiAVCHD is refering to is not the output size but the needed free space to process the files. The output file(s) will actually be the same size as the original file, so go ahead and process it.
If you want 100% flawless playback on the PS3 the best way is by using a flash/external drive and using MultiAVCHD to output for external drive. The only drawback is that you lose the pop-up menu, but you have perfect playback. Now a days an 8GB flash drive is less than $5.00
superleo is offline
post #1092 of 1433 Old 01-30-2013, 10:54 AM
edlittle's Avatar
Quoted: 22 Post(s)
Liked: 39
Just wanted to say thanks to everyone who is still seeding! Was getting a good 500kb/s on my really crappy internet.
edlittle is offline
post #1093 of 1433 Old 01-30-2013, 05:31 PM
Liked: 1144
From DealNews today:
ADATA 16GB USB 3.0 Flash Drive for $7 after rebate + free shipping
newegg offers the ADATA 16GB S102 Pro USB 3.0 Flash Drive, model no. AS102P-16G-RBL, for $11.99. This $5 mail-in rebate drops it to $6.99. With free shipping, that's $0.44/GB, a $2 overnight drop, and the lowest total price we could find in any color by $7. It features read and write speeds of up to 100MB/s and 25MB/s, respectively. Rebate ends January 31.
post #1094 of 1433 Old 01-31-2013, 07:48 PM
kajo's Avatar
Weird. The first time I tried to re-author it ended up being 22gb. Second try now it is able to fit on a DVD-DL. Thanks! Burning now. Hopefully it works.
kajo is offline
post #1095 of 1433 Old 02-03-2013, 12:50 PM
24tate's Avatar
I need some help with burning the disc please...
I have downloaded the torrent through u-torrent and extraced to a folder on my desktop
The file is 38 GB with 58 parts,340files and 16 folders.(the extraction took almost 7 hours)
I opened image burn and dropped in the 2 folders BDMV and Certificate.
I set up image burn for UDF and 2.5 and hit the "burn" button.
It looked like it was working but when I checked back later there was a message there that said
"cyclic reduncancy check" and the process had stopped.
I think I have made a coaster !
What have I done wrong?
24tate is offline
post #1096 of 1433 Old 02-03-2013, 09:21 PM
colleycol's Avatar
Quoted: 23 Post(s)
HTPC Newbie here....How do I play directly from my hard drive using VLC or WMC?
_________________________________________________
JVC RS4810, Screen Excellence 4K 115 inch wide
Lumagen Radiance 2021
Onkyo 818, Emotiva Amp
B&W CT700 Series Speakers, (2) PowerSound Audio XS30s
HTPC running Emby, 12TB Server for storage
colleycol is offline
post #1097 of 1433 Old 02-04-2013, 06:24 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
I did some research on this one and it shows two main results for this error. Usually the most common thing is a problem reading from the harddrive, it is recommended to run scan disk or an utility like this to correct bad sectors etc. The next suspected fault is cheep media.
My recommendation for this would be first to run the hardrive scan, correct any error if any and then burn with out verifying (verify box un-checked) and at lower speed. I always burn at 2X.
Hope this helps.
superleo is offline
post #1098 of 1433 Old 02-04-2013, 06:32 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Not an HTPC user, but I do all the testing for the discs on the computer. As far as I know, and those that use HTPCs please jump in, WMC or VLC can not play Blu-rays. They can play the individual m2ts files but not a bluray with menus. Also, in order for these programs to play correctly you would have to have the necessary audio and video codecs.
The easy way to play any video and audio file is to install Total Media Theater of PowerDVD, either of these programs will play Bluray disc, from the harddrive or the player and include all the codecs that are needed.
As far as VLC, the last time I read anything on it there was a version working on playing BDs, not sure if the latest version actually does or not, since I installed TMT that is pretty much all I use.
superleo is offline
post #1099 of 1433 Old 02-04-2013, 10:56 AM
24tate's Avatar
Thanks Superleo, I will try the scan disc. It's a 500GB external hard drive that I had laying around.
Does the extraction time and file/folder size sound right to you ?
I was a little concerned about the 7 hour extraction....
24tate is offline
post #1100 of 1433 Old 02-04-2013, 12:27 PM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
The unpacking seems extremely slow unless its connecting at USB 1.0 speeds. Don't have the details on the number of files and folders with me but that seems correct.
Under normal circumstances the unpacking should be around 1 hour (depending on your CPU, more or less) but not 7 hours.
superleo is offline
post #1101 of 1433 Old 02-04-2013, 01:22 PM
ed3120's Avatar
Originally Posted by LastButNotLeast View Post
I'm confused. Is there a single BD9 (that will fit on a DVD-DL) that contains a subset of each of the 5 discs on one single disc? All I see are 5 full separate BD-9 images.
ed3120 is offline
post #1102 of 1433 Old 02-04-2013, 04:43 PM
Slingblayde's Avatar
Liked: 64
This sounds unbelievably slow, is your computer a newer PC? Maybe multicore CPU? I unzipped and burned it on my Intel i7-950 quad core in about 25 minutes and that PC is almost 3 years old. If your PC is old that may be part of the problem.
Optoma HD33, Onkyo TX-NR818 in a 9.2 setup, Emotiva XPA-5 G2, UPA-700 for eventual 11.2 setup
Oppo BDP-103, , Middle Atlantic Slim 5-37-26
F - Klipsch RB-61 II, C - Klipsch RC-62 II, Side/Rear Surrounds - Klipsch RS-42's, Heights - Klipsch RS-41's
Dual - PSA XV15's, Fractal Designs Node 605 HTPC
Slingblayde is offline
post #1103 of 1433 Old 02-04-2013, 05:23 PM
Liked: 1144
No. Each of the BD9 discs is one "chapter" of the BD50. So you can burn each section onto one DVD-DL (5 total) or burn the whole thing onto one BD-DL.
You can download each individual chapter (starting in post 2), or get the whole thing where you see this link: Reference_Links_Complete.zip.txt and follow the directions in post 2 and elsewhere.
For the whole thing, you'll want "Reference_Links_Complete/RAR_Reference_BD50.torrent" that you'll see after unzipping.
post #1104 of 1433 Old 02-08-2013, 11:44 AM
24tate's Avatar
So I deleted my folder and re-extracted the files form the torrent and burned to a 50 Gb disc and it works perfectly.
This is one great disc. Thanks SuperLeo and anyone who contributed to this project
24tate is offline
post #1105 of 1433 Old 02-09-2013, 06:03 AM
Liked: 1144
You're welcome.
Now please continue to seed for others who've come late to the party.
And stay tuned for the next one.
Michael
post #1106 of 1433 Old 02-15-2013, 05:23 PM
pmiking1983's Avatar
I am trying to download the full BD50 disc but having trouble with the torrent. It is a .txt file? How can my torrent app use this?
pmiking1983 is offline
post #1107 of 1433 Old 02-15-2013, 05:45 PM
Liked: 1144
Which is why I won't give you too much of a hard time about not bothering to read the directions and other posts. wink.gif
This is the important info you overlooked in post 2:
"The link is zipped file that needs to be un-zipped first. The zip file is also password protected. The password to un-zipped the file is "AVSFORUM" (with out the quotes of course).  This file includes ALL the links for ALL the discs."
So, after unzipping, you take the link you want and put it in the torrent app of your choice.
Good luck.
post #1108 of 1433 Old 02-15-2013, 10:54 PM
dborgill's Avatar
Quoted: 43 Post(s)
Downloading full BD50 torrent now and will seed. A few questions though:
1 - Now that XBMC supports full HD audio, can I just play from there?
2 - I don't have a Blu-Ray burner. Can I pay someone just for the service and disc or what is the best way to get this to physical media?
Thanks in advance!
TV: Sony 75" X940D
Receiver: Pioneer LX-501
Blu-Ray: *Searching*
Speakers: SVS Satellites
Sub: SVS 10 / Pioneer 10
dborgill is offline
post #1109 of 1433 Old 02-16-2013, 05:55 AM
Liked: 1144
Without a burner, the idea is to download the 5 "segments," each of which fits on a DL BD and *usually* plays in a BD player as an AVCHD.
Otherwise, just use your HTPC.
Enjoy.
post #1110 of 1433 Old 02-16-2013, 08:26 AM
shadowcaster's Avatar
You have to rename the file by removing the "txt" extension, then unzip and it will show the torrent files for all links.
"Talk to me Goose"
shadowcaster is offline
Blu Ray Movies , Blu Ray Players , Panasonic Dmp Bd50k 1080p Blu Ray Disc Player , Sony Bdp Cx960 400 Disc Blu Ray Disc Changer , Playstation 3 160gb System
