/// Reference Blu-Ray Demo Disc - BD9 (DVD-DL Media + BD50) \\\ - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #91 of 1433 Old 02-13-2012, 01:05 PM - Thread Starter
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
Originally Posted by shadowcaster View Post
I'm still curious how all of you that have downloaded the Bass disc are overcoming the data transfer rate limitation of a standard DVD. The media just can't support the high bitrate of Blu-ray, whether or not your BD player supports AVCHD.
I think here is where it get real tricky and confusing at the same time. If you look at the DVD specs that is correct the bit rate for the specs can't support the lossless higher bit rate, however... is this for the DVD specs for reproduction or is it limited too by the media? Remember we are dealing with bits of digital data, so for the media itself is just data.
When we tell the player that this is a BD disc it uses the laser pickup circuitry/electronics for the "Blue laser" which supports a higher bit rate, provided here that the player recognizes this a bluray media. There are some markers on the media itself and how it gets recorded that some players check and some others don't. This is the only explanation of why some players play the discs with no problem and some others don't.
RPCRT-TV Overscan Reduction
superleo is offline
post #92 of 1433 Old 02-13-2012, 01:26 PM
shadowcaster's Avatar
Originally Posted by Kalani View Post
snipped...shadowchaster, playback simply depends on your player. My old Panny BD35 (oldest player I own) chokes and dies, while my Sony S570 (newer, but still a couple (few?) years old) plays it no problem.
I had read that re your players in a previous post. I just find it unusual that any player capable of playing avchd can get a standard dvd to transfer those high BD bitrates, when every avchd site that I found, claims that it just can't be done.
Just did some further testing and the Terminator Salvation clip played fine, while the U-571 stuttered like crazy, during the opening depth charges.
So I am now
"Talk to me Goose"
shadowcaster is offline
post #93 of 1433 Old 02-13-2012, 01:52 PM - Thread Starter
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
So I am now
It isn't really an AVCHD disc either, even the disc structure is of a true Blu-Ray disc, but due to the media (DVD) the player thinks or recognizes the disc as being AVCHD (in some players) which is not. If there where no checks for the media the disc should play as a BD disc, which in reality is. You could burn the disc to a BD25 and it will play no problem in any player... but that would be wasting lots of space.
superleo is offline
post #94 of 1433 Old 02-13-2012, 02:05 PM
Hi SL, yes I realize that. My Pioneer recognizes it as an AVCHD because of the media (BD and AVCHD structures are very similar). However, standard dvd media has a theoretical max transfer rate @ 18Mbps and BD media @ 40Mbps. EVERY AVCHD disc I own (most are BD structure BTW) plays perfectly, as long as BR is within that spec.
So theoretically these clips shouldn't play smoothly. Thus, my fascination that some players are able to play them without incident. (BTW, I like the little SL Logo at the top center of the menu screen.)
"Talk to me Goose"
post #95 of 1433 Old 02-13-2012, 02:15 PM
JTR7's Avatar
Close, "Leechers" is the correct term. http://answers.yahoo.com/question/in...3224743AA5GEky Refers to people who are downloading from the seeders (people with the whole file). Once they get the whole file, they become "seeders", too... and hopefully remain that way for a while, to be good netizens. Edit: Shadowcaster is correct, of course, that "peers" is the nicer term for leechers, but both are the same thing, in the end. I suppose the negative connotation of leechers may be due to the large numbers of people who DON'T re-seed, and simply grab and run... leeching off the goodwill of others rather than contributing back by continuing to seed after their download finishes.
I'm still seeding the part 1 disc (Bass), and others are still downloading it, so I'll leave that running for now, although I'm not going to bother taking it to the office for a speed boost at this point. Perhaps if the releases start to get more popular, but with the (relatively) low numbers at this point, it doesn't seem worth the effort.
The next part, disc 2, is still trickling out to the seed group... I'd agree with SL that at the pace I'm seeing, perhaps another day and we'll be ready. I may bring that one to the office to boost the initial push, once I have the full disc.
shadowchaster, playback simply depends on your player. My old Panny BD35 (oldest player I own) chokes and dies, while my Sony S570 (newer, but still a couple (few?) years old) plays it no problem. I just got a new TV, so I may be upgrading that old Panny soon, since I won't need the analog capabilities it offers anymore. I'll probably get a newer Panny (110 or 210), so it will be interesting to see if the newer players of the same brand do any better.
I have an S570. Did you burn yours straight from the download or did you use the patch?
JTR7 is offline
post #96 of 1433 Old 02-13-2012, 02:23 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
I used the patch, since I was going to try it on my Panny as well.
Note that I have not tested each and every clip, I just spot-checked it. I suppose I should give it a shot when I think about it.
Btw, my player is actually the BX57, which is just the Costco-only version of the S570. Only difference, from what I understand, is the label, and the included HDMI cable. Most people are more familiar with the S570, though, so that's how I generally refer to it...
Kalani is offline
post #97 of 1433 Old 02-13-2012, 08:58 PM
cybrsage's Avatar
Liked: 154
I have FiOS 35/35 service, and I still have the Bass disc up. I will see the next disc for a long time after getting it as well.
I want the full on, everything combined, huge blue ray.
EDIT: Just noticed I do NOT have the bass disc seeding...wonder what happened to it?
cybrsage is offline
post #98 of 1433 Old 02-14-2012, 05:44 AM
Ronin2k's Avatar
I need the Tracker pls
Ronin2k is offline
post #99 of 1433 Old 02-14-2012, 06:04 AM
cybrsage's Avatar
Liked: 154
It is in post 2, but here it is again:
http://www.mediafire.com/?hrs1keap8uwa9xs
It is currently only the bass disc.
cybrsage is offline
post #100 of 1433 Old 02-14-2012, 09:57 AM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
There will be a separate tracker for the next disc, when it's ready. We still have a little ways to go due to slow upload speeds, but we're getting closer.
Kalani is offline
post #101 of 1433 Old 02-14-2012, 12:01 PM
pokekevin's Avatar
Quoted: 16 Post(s)
Liked: 102
If I can get my server to connect to the tracker everything would be perfect...
pokekevin is offline
post #102 of 1433 Old 02-14-2012, 05:38 PM - Thread Starter
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
Care to elaborate? Maybe we can help
superleo is offline
post #103 of 1433 Old 02-14-2012, 11:03 PM
alittletank's Avatar
Liked: 26
Never mind , i just read the drama involved with the other demo disc thread...
I guess I have to buy a burner and learn..
alittletank is offline
post #104 of 1433 Old 02-15-2012, 08:52 AM - Thread Starter
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
Animation Disc tracker is on the first page post #3
superleo is offline
post #105 of 1433 Old 02-15-2012, 09:30 AM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Yup, finished last night and I'm seeding away now.
I'll bring the files to work to help with the initial push.
Hope to test it out this evening.
Kalani is offline
post #106 of 1433 Old 02-15-2012, 09:53 AM - Thread Starter
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
This project is a little different...
If you have a DVD burner you could give it a try, no results guaranteed though, but you wouldn't know unless you try it.
You need DVD-DL (double layered media DVDs) and a DVD burner. Follow the instructions on the first post.
Also, if you have Total Media Theater or Power DVD software installed you could play it directly from your computer.
superleo is offline
post #107 of 1433 Old 02-15-2012, 12:25 PM
nickbuol's Avatar
Quoted: 659 Post(s)
Liked: 690
I will D/L it and start seeding it (with the Bass one) tonight. Thanks Leo!
nickbuol is offline
post #108 of 1433 Old 02-15-2012, 01:44 PM
manthatsnice's Avatar
Ditto
Cory
manthatsnice is offline
post #109 of 1433 Old 02-15-2012, 02:58 PM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 64
landshark1 is offline
post #110 of 1433 Old 02-15-2012, 07:01 PM
treads's Avatar
Another vote for music demo next. Great job by the way. I'm looking forward to demo-ing the animation DVD with the kids this weekend. We own every movie on the animation disk, but it will cool to have them together on one disk.
treads is offline
post #111 of 1433 Old 02-15-2012, 07:45 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Seeding Animation Disc at home and work. Nice job! I, too, own each of those titles already, but it is indeed nice to have them assembled together.
Works great on my Sony BR. I'm going to assume it, like the Bass disc, won't work on my old Panny BR, but I'll confirm here once I can test it. FWIW, I didn't bother swapping out the alternate files before burning this time, and the Sony still did great.
Kalani is offline
post #112 of 1433 Old 02-15-2012, 08:33 PM
nickbuol's Avatar
Quoted: 659 Post(s)
Liked: 690
The animation disc came down pretty quick. Seeding away...
nickbuol is offline
post #113 of 1433 Old 02-15-2012, 09:04 PM
drpete12's Avatar
Quoted: 105 Post(s)
Liked: 44
Downloading now. Will leave it seeding till Monday or Tuesday. Thanks
drpete12 is offline
post #114 of 1433 Old 02-16-2012, 03:26 AM
drpete12's Avatar
Quoted: 105 Post(s)
Liked: 44
Just checked and its all done. I am opening upload speed to max. Will keep it that way till wife tells me no more. Enjoy guys. And thanks again.
drpete12 is offline
post #115 of 1433 Old 02-16-2012, 04:38 AM
Donald2B's Avatar
downloaded and seeding in multiple locations.
I own almost all of these movies and it is NICE to jump between the different clips without waiting for each disc to load up!
Thanks again Leo!
Donald2B is offline
post #116 of 1433 Old 02-16-2012, 07:59 AM - Thread Starter
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
Just a tad of new information and differences between the first two disc.
The bass disc download after unpacking has two main folders the BDMV folder and the folder for the patched files while the animation download after unpacking has an additional CERTIFICATE folder.
All the information I've ever read about the certificate folder is that is not really needed, but just for compatibility sake I've included it in the animation disc. In case your player is having trouble playing the files you can try including the CERTIFICATE folder... once again no guarantees that all players will work.
superleo is offline
post #117 of 1433 Old 02-16-2012, 07:47 PM
Liked: 26
I'm downloading both discs and have my upload set to unlimited.
post #118 of 1433 Old 02-16-2012, 08:07 PM
mookie b's Avatar
Quoted: 17 Post(s)
Liked: 26
Total Newbie here to bit torrent and all of this stuff. Leo was nice enough to give me a little private tutoring via PM and BAM it worked tonight on my first try burning. I'm using a fairly new Mac and thought I'd pass out what I did if there's anyone else like me that's "never done this before".
My Blu Ray player is an Oppo BDP-93.
First off, I found using Google Chrome to download the files worked better than Apple's Safari as Safari was saving the Target files as a text file. Chrome left it as a torrent file.
After that, I downloaded uTorrent at:
http://www.utorrent.com/downloads/mac
Used that program to download the big torrent files related to the downloaded target file.
They download as .rar files. From there I downloaded UnRarX at:
http://unrarx.en.softonic.com/mac
Used that to extract them to useable files for the burning.
Mac's default burning software as far as I can tell didn't have an option for UDF so I have no idea if it would do it correctly. I don't think so, but maybe. Anyway, I gambled and downloaded a burning program that ended up working so lucky me. Burn Program was at:
http://burn-osx.sourceforge.net/Pages/English/home.html
Selected "DVD (UDF)" as the option at the top, dragged the BDMV folder from the extracted RAR files to the Burn program window and that was it. I used a Verbatim DVD+R DL at 6x burning speed. Threw the finished product in the oppo, Menu screen popped right up.
I only did the LFE one, as the animation one is on my work computer and I did this LFE one at home. My son and I had a kick out of the bass scenes, and it was fun to see a few I hadn't seen the movie but had read on here people recognized the scene as good for LFE.
All in all, thanks Leo. Easy, painless and fun. Nice touch too with the Avatar THX trailer playing as the background menu, DTS-HD MA and all!
mookie b is offline
post #119 of 1433 Old 02-17-2012, 07:26 AM - Thread Starter
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
Originally Posted by mookie b View Post
Total Newbie here...
Not anymore...
Great post and very useful information for Mac geeks!!!
Glad you got it to work.
superleo is offline
post #120 of 1433 Old 02-17-2012, 03:53 PM
Liked: 26
I need a little help. I used imgburn to create an ISO file but cant get it to play in VLC. either I used the wrong files to create the ISO or vlc is the wrong player to use...
I thought that VLC would play ISO files. I am downloading TMT to try the trial. that should tell me if the ISO is good or not.
Blu Ray Movies , Blu Ray Players , Panasonic Dmp Bd50k 1080p Blu Ray Disc Player , Sony Bdp Cx960 400 Disc Blu Ray Disc Changer , Playstation 3 160gb System
