/// Reference Blu-Ray Demo Disc - BD9 (DVD-DL Media + BD50) \\\ - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 22Likes
post #181 of 1433 Old 03-01-2012, 07:58 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Originally Posted by kong View Post
For my panansonic Bdt-350 both discs a no go.
My Sony-370 stutter very bad.
On the Sony I tried the uncompressed files via the USB. The animation works file to file. The bass was a no go. I renamed the bass scenes(added an extra zero in the file name). I then dragged the renamed bass scenes, drug them over to the animation folder, about 1/2 of them worked!
Did you try using the patched files?
If you burn these to 25GB media they should play with no problem, although that would be 1/3 of the space used.
RPCRT-TV Overscan Reduction
superleo is offline
post #182 of 1433 Old 03-01-2012, 12:43 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
BD media no problems in any BR player I've tried (all 3), but the DVD9s I burned won't play even in my new Panny BR (210), unfortunately. One patched, one not patched. Both patched and unpatched play no problem in my Sony BR.
Kalani is offline
post #183 of 1433 Old 03-01-2012, 12:52 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
FWIW, I've now tried the discs in 3 different BR players: one old Panny (BD35), one new Panny (210) and one intermediate Sony.
The burned BR media discs play perfectly in all. The DVD9 AVCHD discs, however, don't. They all play perfectly in the Sony. None work in either of the Panny BRs. I've tried patched and unpatched both.
Again, fortunately, the BR version works no problem, so the impatient can just burn to BR if they have Pannys (BD25 to save money, perhaps, over the dula layer BD50s), or wait for the full BR version to be released, which will work no problem in the Panny players.
Kalani is offline
post #184 of 1433 Old 03-02-2012, 03:55 PM
smick6's Avatar
I am a bit confused on using win rar. What exactly has to be done with the downloaded rar folder. I am assuming win rar unpacks it or un compresses it before being able to burn it. Just dont know how to use win rar I guess. Any help would be greatly appreciated.
smick6 is offline
post #185 of 1433 Old 03-02-2012, 04:16 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Try Winzip instead, I find the interface easier and it does RAR just fine. Open the first file in Winzip and it will automatically decompress the whole chain into the files that you actually burn to disc.
Kalani is offline
post #186 of 1433 Old 03-02-2012, 04:17 PM
tomd51's Avatar
Smick6,
You're on the right track. WinRAR is just another form of compression. You can download a free utility like 7-Zip to uncompress all of the RAR files, which will create a single folder with the contents of the disc... -TD
Emotiva XPA-2, XPA-5 | Yamaha CX-A5000 | Mitsubishi WD-73742 | Epson 8700UB
Boston Acoustics VS 336s, VS 325c, Emotiva ERD-1s (x2) | 15" TC-2000 DIY Sub
Dish Hopper with Sling | Oppo BDP-93 | AppleTV v4 | Roku 3
tomd51 is offline
post #187 of 1433 Old 03-02-2012, 04:32 PM
shadowcaster's Avatar
Interesting, I stopped using Winzip years ago because it would not decompress a series of files.
You had to do each one individually. Bout time they caught up to Winrar.
"Talk to me Goose"
shadowcaster is offline
post #188 of 1433 Old 03-02-2012, 05:32 PM
smick6's Avatar
Thanks guys, in the process of using win zip now.
smick6 is offline
post #189 of 1433 Old 03-02-2012, 06:33 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Yeah, I remember when they didn't do it, too. I came across that situation (multiple RAR files are so 1990s) so rarely I never really worried about it. The one day I forgot, and opened files up in Winzip, and it all worked, easy-peasy.
Kalani is offline
post #190 of 1433 Old 03-02-2012, 11:10 PM
dRwOOD73's Avatar
Finally got around to unRARing the bass files, was just letting them all seed for a while since I didn't have any DL DVD's to burn these with... question, does Alcohol 120 work for burning this or am I missing something??
dRwOOD73 is offline
post #191 of 1433 Old 03-03-2012, 12:16 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
I'm not sure about alcohol 120, if it has the option of UDF 2.5 then it's fine, but why not just use imgburn when it's free and you know it has what you need. It is essential for the burning software, what ever you choose to be able to use UDF 2.5, otherwise it won't work, for Macs there is a post earlier with recommendations with what works.
superleo is offline
post #192 of 1433 Old 03-03-2012, 07:51 AM
dRwOOD73's Avatar
Thanks superleo, I guess I was just trying to avoid installing another program..
dRwOOD73 is offline
post #193 of 1433 Old 03-03-2012, 08:22 PM
BrownTown's Avatar
Just got a Pioneer BD burner so I cannot wait until the 50GB torrent hits the torrent streets!!
BrownTown is offline
post #194 of 1433 Old 03-03-2012, 09:51 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
Imgburn is free, no ads or spyware, and won't clutter up your computer with useless junk. Feel free to install and then uninstall it when finished if you don't want it.
That said, installing some small programs like that aren't going to slow down your system. There is no continuously-running memory resident subprogram, just the fast and lean main program.
Kalani is offline
post #195 of 1433 Old 03-04-2012, 07:22 AM
McStyvie's Avatar
Liked: 78
Just started downloading these...hope it goes quicker soon, set to take 1yr 34wks at the download speed it is at now...does utorrent speed up with time?
Also, can I use Nero 11 to burn these, and they should all fit on one disc right? Or do I need to burn 3 separate blu rays for this?
Thanks in advance,
McStyvie
McStyvie is offline
post #196 of 1433 Old 03-04-2012, 07:30 AM
BrownTown's Avatar
Thanks in advance,
McStyvie
you will need 3 separate DVD9
post #197 of 1433 Old 03-04-2012, 07:44 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Thanks in advance,
McStyvie
How fast you download depends on two main factors, how many seeders there are and how fast your bandwidth is. The more seeders and the wider bandwidth the quicker it goes.
The first part of the project consists of 5 segments/discs. The segments are small enough to fit into a double layered DVD (DVD+DL), thus if you want to burn all five segments, once they are out, then you would need 5 disc.
The discs can of course also be burn to 25GB blu-ray media instead of DVDs. When burned to blu-ray media there are no compatibility issues with any player.
superleo is offline
post #198 of 1433 Old 03-04-2012, 07:54 AM
cybrsage's Avatar
Liked: 154
Anyone still need the animation disc? I am seeding it again.
cybrsage is offline
post #199 of 1433 Old 03-04-2012, 08:25 AM
McStyvie's Avatar
Liked: 78
Thanks Superleo, I will be burning them to Blu Ray, my bandwidth is about 750k/sec download speed, or what they call 8mb/s here oO
If anyone would like to seed them to help speed up my download, would be highly appreciated!
Looking forward to demoing these!
Mcstyvie
McStyvie is offline
post #200 of 1433 Old 03-04-2012, 09:18 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Just checked the trackers for the discs that are out, while getting the new disc ready, there are good seeder numbers for all the discs so downloads should be fairly fast.
superleo is offline
post #201 of 1433 Old 03-04-2012, 12:37 PM
McStyvie's Avatar
Liked: 78
hmm 5 hours in and .2% downloaded, I have tried to change all the settings on this, it is enabled on my firewall...maybe it doesn't like UK servers...
Cheers,
McStyvie is offline
post #202 of 1433 Old 03-04-2012, 12:40 PM
Kalani's Avatar
Quoted: 110 Post(s)
Liked: 26
I'm still seeding all three discs. The only one seeing significant activity at the moment is the Bass disc.
Kalani is offline
post #203 of 1433 Old 03-04-2012, 12:55 PM
nickbuol's Avatar
Quoted: 553 Post(s)
Liked: 613
I will restart seeding all three again this afternoon.
nickbuol is offline
post #204 of 1433 Old 03-06-2012, 09:47 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
There is still activity/interest in all disc. If you download as courtesy to others seed for a couple of days... good torrent etiquette.
We started getting the next segment ready.
superleo is offline
post #205 of 1433 Old 03-06-2012, 06:46 PM
BrownTown's Avatar
I can seed the 50gb once ready. I do have a Comcast Cap but will seed as much as I can before they cut me off for the month.
post #206 of 1433 Old 03-06-2012, 09:29 PM
cybrsage's Avatar
Liked: 154
I have FiOS 35/35 and am still seeding the one part I did not accidently delete, a 6.73 to 1 ratio. No one is downloading, though.
cybrsage is offline
post #207 of 1433 Old 03-07-2012, 08:41 AM - Thread Starter
superleo's Avatar
Quoted: 77 Post(s)
Liked: 301
Originally Posted by cybrsage View Post
... No one is downloading, though.
There are currently 8 downloading the Music disc, 4 downloading the Animation disc and 1 downloading the Bass disc form me. The seeders had drop to the single digits on all discs.
superleo is offline
post #208 of 1433 Old 03-07-2012, 09:35 AM
carboranadum's Avatar
Quoted: 21 Post(s)
That makes sens. After the initial flood of folks downloading, interest would taper off. Our community is not that large...
Thanks for putting the disks together. Can't wait for the full BR.
carboranadum is offline
post #209 of 1433 Old 03-07-2012, 04:20 PM
fight4yu's Avatar
Liked: 43
Time to release the next one, I guess.
I am awaiting the All in one blu-ray
fight4yu is offline
post #210 of 1433 Old 03-09-2012, 04:07 AM
kchill's Avatar
So putting this to a usb stick will not work patched to a ps3?
I don't have a blueray burner. Is any of you making copies to " donate" ...will be glad to pay for shipping. Paypal anyone?
And if so by special request any custom screen that can be made. Like when you put the disk in something personal like a theme for your home theater comes on. Just to impress your friends. Let me know, thank...by the way i use little of my comcast cap so i will seed for a few weeks if it helps.
kchill is offline
Blu Ray Movies , Blu Ray Players , Panasonic Dmp Bd50k 1080p Blu Ray Disc Player , Sony Bdp Cx960 400 Disc Blu Ray Disc Changer , Playstation 3 160gb System
