Question about center channel placement - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 02-04-2012, 06:37 AM - Thread Starter
alex014's Avatar
Quoted: 16 Post(s)
Hi. I was wondering if someone could tell me if it was better to put my center channel above or below my screen? The screen is 106 diagonal. If I put it above the screen it's about 5 inches from the top of the speaker to the ceiling. If I put it below it will be about 20 inches off the floor. Unfortunately an at screen is not possible at this moment. Also although I have two rows of seating the second row is rarely used. Thank you for any help.
alex014 is offline
post #2 of 7 Old 02-04-2012, 07:25 AM
SierraMikeBravo's Avatar
Quoted: 339 Post(s)
Liked: 215
Above the screen is the next "best" place. However, unless you can place it in the vertical, which it doesn't appear you can, get a speaker with only a single woofer rather than the misused MTM design center channel. Best wishes!
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is offline
post #3 of 7 Old 02-04-2012, 07:57 AM
thebland's Avatar
Quoted: 1498 Post(s)
Liked: 851
Keep your center at a height that is no more than a couple feet vertically away from your LCRs. If your LCRs are near the floor and your center above the screen, you'll have imaging issues across the front. Personally, I'd keep away from the ceiling... but if you must, make sure you have absorption at the first reflection point and have your L and R speakers up there, too. Ideally, get an acoustically transparent screen and place your speakers behind it. Always better to have dialog coming from the actors mouth than above or below the picture.
It's back!! Wine of the Week! Clos Martinet Tinto, Priorat DOCa, Spain ~$60. If you've not had a good Priorat, you've not truly tried Spain's smallest, yet most unique terroir.
My Home Theater of the Month- Le Petit Trianon
thebland is offline
post #4 of 7 Old 02-04-2012, 08:28 AM
Bigus's Avatar
Quoted: 229 Post(s)
Liked: 254
There have been multiple recent threads asking this same question in this very forum. The search feature should turn them up and provide more discussion and explanation for you to consider.
Bigus is online now
post #5 of 7 Old 02-04-2012, 08:45 AM - Thread Starter
alex014's Avatar
Quoted: 16 Post(s)
Honestly I have looked at most of the threads that deal with this and it seems everyone has a unique situation. I was trying to find out the lesser of two evils for my situation since I do not have the space to go with an at screen
alex014 is offline
post #6 of 7 Old 02-04-2012, 08:50 AM
Theresa's Avatar
Liked: 51
All you can do is try each of the positions, above, below, and none (phantom)
Theresa is offline
post #7 of 7 Old 02-04-2012, 06:35 PM
Stew4msu's Avatar
Mine is above the screen (it's about 9' high) and angled toward the seating area. Dialogue sounds like it's coming right from the screen.
If you have more than one row of seating, putting it below the screen will block the sound to the second row.
Stew4msu is offline
