New construction underway - AVS Forum
post #1 of 16 Old 02-15-2012, 11:31 AM - Thread Starter
rogerssa's Avatar
Been working on my new house. I've doing much of the basement right now with some help from the framers. Thought I'd put up a few pics to show progress.
Sorry for crappy photos did them with my iPhone.
From the back looking forward to where screen will be.
The bulk head that is killing me in the middle of the back row. Have some work to do here, can't get rid of it, but think I can save a lot of room if I get rid of the 2x4 framing boards and put drywall right up to the pipe.
Picture of my rack in the back of the room.
Still lots to do. Have columns up now just need a new pic of that. This is a home theater room but back of the room will be open to the basement, because we host a lot of sports parties and we like the room to watch from the bar as well. (I'm having an custom Irish bar built for other end of basement.)
rogerssa is offline
post #2 of 16 Old 02-15-2012, 11:49 AM
Quoted: 107 Post(s)
Liked: 508
I see a HUGE amount of wasted headroom in the pictures of the bulkhead hanging down. You are right, bridge the bottom with drywall hanging just below the lowest hanging obstacle.
post #3 of 16 Old 02-15-2012, 11:58 AM - Thread Starter
rogerssa's Avatar
It was how we had to setup septic to on that side of the house. Made the one run for all bathrooms for that septic pipe come right accross there. Only option I had. Trust me I argued with plumbers a lot. They moved it 3 times for me and this was best setup. Framers just didn't follow directions very well. So now I'll just bridge the drywall. Should get at least 6 more inches of head room.
rogerssa is offline
post #4 of 16 Old 02-15-2012, 02:27 PM
AVS Club Gold
Dennis Erskine's Avatar
Liked: 43
You'll have to build a platform for that rack. You cannot set it down that low. And, while I'm thinking about it, just how are you going to get behind the rack to manage the wiring?
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Board of Directors
www.erskine-group.com
www.CinemaForte.net
Dennis Erskine is offline
post #5 of 16 Old 02-15-2012, 03:59 PM - Thread Starter
rogerssa's Avatar
Why can't it be that low may I ask. How far should I build it up? I don't have that much room to build it up.
I plan on doing a remote IR.
Also it's hard to tell but I can fit behind the rack. I also thought about trimming it out so hat I could push it out or put it on casters.
rogerssa is offline
post #6 of 16 Old 02-15-2012, 04:18 PM
Glimmie's Avatar
Quoted: 36 Post(s)
Liked: 163
Well it can, it's just not typically done. Dirt, getting kicked, etc. Most commercial racks have a three to four inch base built in.
FWEIW, I put my Slim5 rack group on a 4x4 frame and glued standard cove base to the front to finish it off.
BTW, are you using pressure treated lumber sitting on that bare concrete?
Glimmie's HT Page
Being redone - comming soon!
Glimmie is offline
post #7 of 16 Old 02-15-2012, 06:13 PM - Thread Starter
rogerssa's Avatar
It's sitting on 2x4's right now. They are pressure treated. I can add another 2x4 to raise it up no problem. So it's near the 4x4 you talk about.
rogerssa is offline
post #8 of 16 Old 02-16-2012, 04:56 AM
AVS Club Gold
Liked: 43
Ventilation is one; but, let's forget about that for a moment ...
If that rack ever has to come out...for any reason...you want the base of the rack higher than the baseboard and trimmed in such a manner as to make it easy to move out.
Finer points ... you may be able to fit behind the rack; but, can you actually work behind the rack? Stand up, sit down, strip cables, reach tools, etc.?
Back to ventilation ... how are you going to circulate air and remove hot air from that cavity?
It's your room, you can do what you want; but, that will be a problem for you. I would have suggested an AXS type so it can actually be pulled out and worked on.
www.CinemaForte.net
post #9 of 16 Old 02-16-2012, 05:09 AM
tony123's Avatar
Liked: 25
Can you post a plan?
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #10 of 16 Old 02-16-2012, 05:28 AM
J_P_A's Avatar
Quoted: 74 Post(s)
Liked: 188
+1
I'm not sure if you're looking for advice or not, but it would certainly help everyone get a better idea of what your space looks like, and help keep everyone's interest. I'm fairly certain we all have a touch of AD... SQUIRREL!
The Plains Theater Has Begun
J_P_A is offline
post #11 of 16 Old 02-16-2012, 06:13 AM
Quoted: 107 Post(s)
Liked: 508
On the rack, I like to have it high enough so that you can at least run your baseboard molding underneath. Looking at the picture it is not obvious how you intend to finish the outside corner of the cut out, In other words is there room to drywall around the corner or to add something to finish it off.
post #12 of 16 Old 02-16-2012, 07:15 AM - Thread Starter
rogerssa's Avatar
I see what you are saying, and I didn't think about that till now. So glad I posted this info. Anyway I'm going to raise it up this weekend to give room to run trim around the full thing. I had planned on just trimming it out with 3" trim.
rogerssa is offline
post #13 of 16 Old 02-16-2012, 07:45 AM - Thread Starter
rogerssa's Avatar
Here are a few more pics of the plans of the basement
Here is the sketch I drew up to start with. (sorry for the poor quality didn't scan into the PC so well after I drew with with pencil)
This is the basement floor layout.
Here is the bar drawing that my cabinet builder sent me.
rogerssa is offline
post #14 of 16 Old 02-16-2012, 07:57 AM
Tedd's Avatar
Quoted: 12 Post(s)
Liked: 58
Column sconce aisle four seats aisle sconce column in fourteen feet of width?
Tedd is offline
post #15 of 16 Old 02-16-2012, 08:48 AM - Thread Starter
rogerssa's Avatar
I removed the back column it didn't work. Didn't update the drawing.
rogerssa is offline
post #16 of 16 Old 04-17-2012, 06:36 AM - Thread Starter
rogerssa's Avatar
Thought I'd post a quick update to my theater build. Here is Picture I took on Friday.
rogerssa is offline
User Tag List
