Living Room Theater. Ceiling Fan? - AVS Forum | Home Theater Discussions And Reviews
Old 02-17-2012, 10:46 AM - Thread Starter
darenm's Avatar
Hello all,
I'm forced to build my theater in my main living room. I have a ceiling fan dead center of the room. It's also an open floor plan and there is no back wall to mount the projector. So i need to get a short throw projector to place it in front of the fan or i need to get a long ceiling mount to put the projector behind the fan but low enough to clear the fan. any ideas?
darenm is offline
Old 02-17-2012, 10:53 AM
Quoted: 3256 Post(s)
Liked: 2743
The Chief mounting system uses a down pole, The pole is a common size and thread such that you can walk into a Home Depot and they will cut you the exact length and thread it for you, Take it home clean and spray paint black.
Don't overlook the opportunity to raise the fan.
Depending on the make and model projector the required mounting height will vary. Some will need to be even with the top edge of the screen, some can go a percentage higher. A few had a fixed vertical offset that required the projector to be a fixed percentage of the screen height above the screen. So you need to know.
Old 02-17-2012, 12:51 PM
alittletank's Avatar
Liked: 26
If redirecting the pj heat isn't effetive then I will be installing for a low profile ceiling fan in my theater. There are low profile fans that you can install that only extend down 9" from the cieling.
just another option...
alittletank is offline
