Plasma pedestal help.. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 8 Old 02-26-2012, 11:37 AM - Thread Starter
PRO710HD's Avatar
Quoted: 55 Post(s)
I'm not sure if this is the right forum to post in but it seemed like the most logical fit.
I just bought a Panny 50" plasma for the bedroom but sitting on the stand it's too low for viewing height. The center pedestal is about 17" x 14"
I'm trying to think of an off the shelf box or platform that I could buy that could boost the height of the TV by anywhere from 4-6 inches?
PRO710HD is offline
post #2 of 8 Old 02-26-2012, 11:45 AM
lovinthehd's Avatar
Quoted: 4588 Post(s)
Liked: 4783
I googled briefly and came up with http://www.amazon.com/OFC-Express-St.../dp/B0035L90FW
lovinthehd is offline
post #3 of 8 Old 02-26-2012, 12:11 PM - Thread Starter
PRO710HD's Avatar
Quoted: 55 Post(s)
That looks like it would work but it's way too wide. I just want something close to the dimensions of the base (17" x 14")
PRO710HD is offline
post #4 of 8 Old 02-26-2012, 12:37 PM
lovinthehd's Avatar
Liked: 4783
Like I said, I hardly tried. You could always get three pieces of wood for exactly the dimensions you require and make your own...
post #5 of 8 Old 02-26-2012, 12:43 PM
gregzoll's Avatar
Liked: 33
Go to the hardware store, and look at what they have there. Ikea is another place to look, if you have one. All that you need, is a drawing of the dimensions, take that to Lowes, Ace Hardware, Menard's, and they can cut a sheet of plywood, or pine board or such for you. Take that home, and paint or stain and put together with some screws. keep in mind, that you will need a drill and some drill bits, so you can put in the screws.
Even better, look and see if you have any mill or cabinet shops in your area, they may have something, or make something for you.
gregzoll is offline
post #6 of 8 Old 02-26-2012, 01:47 PM - Thread Starter
PRO710HD's Avatar
Quoted: 55 Post(s)
Thx for the suggestions guys!
I do have an Ikea and I think I'll try there first
PRO710HD is offline
post #7 of 8 Old 02-26-2012, 01:50 PM
gregzoll's Avatar
Liked: 33
Check the area that has the damaged or missing pieces first, since you can usually find stuff down there to make it work.
gregzoll is offline
post #8 of 8 Old 02-27-2012, 07:56 AM
NickTheGreat's Avatar
Quoted: 432 Post(s)
Liked: 307
Wall mount?
NickTheGreat is offline
