MA slim 5 20" or 26" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 15 Old 03-04-2012, 04:09 PM - Thread Starter
radchad3's Avatar
Hello all! I am going to be ordering a Slim 5-29 rack very soon. I see they have both the 20 and 26" depth racks. My deepest component is 17 3/4" so I am thinking the 20" model would do just fine. Any reason I would need to go to the 26" model. I am very new to rack systems so just wanting to make sure I get the correct one! Thanks! Chad
radchad3 is offline
post #2 of 15 Old 03-04-2012, 05:20 PM
Tedd's Avatar
Quoted: 1147 Post(s)
Liked: 437
26" is the safer/better choice. Better cooling, more room for cabling, and for future proofing.
Tedd is offline
post #3 of 15 Old 03-04-2012, 05:26 PM
jautor's Avatar
Quoted: 1330 Post(s)
Liked: 852
Where will it be located? Do you have lots of space? If so, go with the deeper one. Many amplifiers are 19" deep which when you add the cable exits can be a problem for 20" racks.
Jeff
NOTE: If you find dead photo links in any of my posts, please PM me and I will fix it.
jautor is offline
post #4 of 15 Old 03-04-2012, 06:15 PM - Thread Starter
radchad3's Avatar
Thank you both for the replies! The rack will be going inwall with plenty of space on the back end. Pardon my ignorance but how would the 26" be better on the cooling aspect? They both will be open on the backside. Also, if I end up with a 19" deep amp in the future (which will happen at some time) cant I just do 4" off set lacing bars for cable management. Again, I am new so slap me if I am way off base!
PS: The 20" is $75 or more cheaper so that is why I would like to get it to work. If it isnt the right choice, I am happy to pay more. Thanks!
radchad3 is offline
post #5 of 15 Old 03-05-2012, 03:51 PM
Tedd's Avatar
Liked: 437
If you have lots of space behind the rack, then you're fine. There's lots of ways to install a Slim5 and often the backside is closed off, either by a MA door, or it's built into a closet. Active cooling is via a tower effect, with fan/fans up top exhausting heat.
So you're making no attempt at any sound isolation?
Tedd is offline
post #6 of 15 Old 03-05-2012, 06:30 PM - Thread Starter
radchad3's Avatar
The MA is going into an inwall space which will be 8-10 feet from the listening area. Currently I only have on amp with a fan. The whole setup is very quiet.
radchad3 is offline
post #7 of 15 Old 03-05-2012, 07:22 PM
jautor's Avatar
Liked: 852
If you're not planning on putting a rear door on, no benefit to the 26" depth except, well, the depth.
I've got an MA 20"-deep rack in-wall, and the amp shelf protrudes an 1" beyond.
Jeff
jautor is offline
post #8 of 15 Old 03-06-2012, 04:51 AM
Tedd's Avatar
Liked: 437
You use the term "currently". Does that imply future electronic upgrades? I have the 20" deep Slim5 also and already two upgrades are pushing the rack depth.
Tedd is offline
post #9 of 15 Old 03-06-2012, 05:50 AM
NJ Jackals's Avatar
20" is usually fine for electronics components. It is not usually fine for computer components. If you are planning on putting in a rackmount server (HTPC) or storage array, best to know what cases you'll be using before deciding on 20" or 26". Also, the 20" MA rack I have(AX-SXR) is more like 19.5" useable. I had to slightly modify 20" rails for my disk array. I do have about a 5" space available behind my rack. I'm glad I do too for ventilation. Those components get quite hot. I have a cooler guys Fan Controller at the top of my rack (http://www.coolerguys.com/840556091677.html) which is hooked to a 12V relay that runs a Fantech inline duct fan (located in unfinished storage area) that exhausts all the heat. Works great but only wished the coolerguys 1U faceplate came in the same brushed aluminum as the MA faceplates.
If you are interested a HTPC or storage array, here are the ones I use in a 20" rack.
Silverstone Black Aluminum HTPC case. Loos great because it matches the brushed black aluminum of the MA faceplates.
http://www.newegg.com/Product/Produc...82E16811163117
Norco 12 Bay hot swappable Disk Array. Shallow depth, holds 12 drives (36TB) and is only 2U.
http://www.norcotek.com/item_detail....0db23094bf2ba7
NJ Jackals is offline
post #10 of 15 Old 03-06-2012, 07:04 AM - Thread Starter
radchad3's Avatar
Thank you all for the replies! I went with the 26" model. I had plenty of room in my unfinished area so I couldn't think of any real negatives for going with the deeper rack. This will give me the most room should I ever upgrade to components that are deeper. Thank you for the advice!
radchad3 is offline
post #11 of 15 Old 03-06-2012, 09:18 AM
judsonp's Avatar
I have the Silverstone case in a MA Slim5 20" and wish I had the additional depth. I think you made a good choice.
As a side note, I did buy the rack mount kit for the htpc case which saved a little space on the backside of the rack.
judsonp is offline
post #12 of 15 Old 03-06-2012, 09:35 AM
NJ Jackals's Avatar
I bought the rackmount ears as well. I didn't like the look of the handles so I wound up just putting it on a shelf.
This is an old pic but you get the idea.
post #13 of 15 Old 03-06-2012, 01:30 PM
Neurorad's Avatar
Quoted: 235 Post(s)
Liked: 145
The extra depth is also good for mounting odd shaped stuff, e.g. router, modem. And, patch panels can be mounted on rear rails (if there is room). The patch panels don't need to be in the front of the rack, and can be hidden away in back.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #14 of 15 Old 03-06-2012, 05:23 PM
NJ Jackals's Avatar
I agree. Reverse mount what you don't need to see. (Even with a 20" rack)
I have my Cisco 16 port switch reverse mounted.
http://www.amazon.com/Cisco-SR2016T-.../dp/B003AVN1PM
I also have a Middle Atlantc PD-2015R-HH-NS power strip reverse mounted
http://www.middleatlantic.com/power/multimount.htm
I'm thinking about reverse mounting my Control4 HC300 to reclaim 2u in my rack. That or replace it with the new HC800 which only takes up 1u.
post #15 of 15 Old 03-09-2012, 03:43 AM - Thread Starter
radchad3's Avatar
Got my 26" rack in today! I got it from smarthome.com for $271.11 shipped! This was the cheapest by at least $30 than any other place I looked. It was drop shipped directly from MA. I just wanted to post so others looking at this rack know what deals are out there. Thanks!
PS: I used a coupon code for 5% off.
radchad3 is offline
