Home-made ceiling tiles - AVS Forum | Home Theater Discussions And Reviews
post #1 of 13 Old 03-19-2012, 07:21 PM - Thread Starter
macadoo's Avatar
Finally, I can give something back to the forum and people that have given me so much inspiration and so many solutions.
So, my problem ceiling. It's short, like 7.5 feet. So dropping a ceiling wasn't an option. I have junction boxes everywhere, something like eleven in just the theater area alone. The pleasures of having a 177 year old house Code says that junction boxes must have access so drywall wasn't an option. Plus, I have committment issues and want to have access to my wiring and plumbing Also, I wanted something light enough that I could hang by myself.
I did some research and found that extruded polystrene, in other words that pink foam insulation board, is code as long as your house is not a rental. So I started cutting up my own tiles, beveling them on the sides for aesthetics. They take roll-on paint well, are light, and better acoustically than drywall or wood. Better, but not great.
I screwed the tiles directly to the floor joists using drywall screws, sinking them into the foam about a quarter of an inch. Then I simply covered the screw holes with 3/8" wood buttons. I painted the buttons before pressing them into the holes.
The tiles looked pretty good but it was a little too utilitarian for my tastes so I thought I'd spruce them up with those little wood accents. But I couldn't find anything I liked, especially sice I wanted a muted art deco look. So here's what I did:
Since I'm a sculptor, I had some oil clay sitting around. This is clay that doesn't harden so that it can be reused after the mold is made. I drew up my design and transfered it to the clay slab (rolled with rolling pin).
I cut out the form with a kitchen knife and began forming the fins into what I wanted.
Once the form was sculpted, I used art silicone from a supplier I use (let me know if you would like the website) to cover the clay. I didn't have enough silicone to just pour it over the form so I used thickener. Note the clay wall surrounding the form. This will contain the plaster.
After the silicone is set, about 12 hours in this case, I used plaster to make a mother mold to hold the silicone mold in the correct shape.
Be sure to use a release agent on the silicone or you'll have a heck of a time separating the silicone and plaster.
Here's the mold in it's mother mold ready for casting.
I used a liquid casting plastic because I'm familiar with it and I had some sitting around. It's a two part resin that can be demolded in 20 minutes, another plus. It goes in clear and turns white after it cures.
The finished cast. Now I just needed to make 39 more.
Next I used gorilla glue to glue the accents in place on the tiles. Some of you that know my small theater may notice that I've changed my color scheme. I was inspired by YW84U's Tanner Ridge Cinema.
And the painted tile
The plastic accents made the tiles quite a bit heavier. I thought about using a two part expanding foam but have had little experience with it. I did try spray foam with disastrous results.
I'm very pleased with the look of the ceiling so far. I have four more tiles with accents to make and many without the accents to hang. but, between school and making art, I'm slowly getting there.
-Mac
macadoo is offline
post #2 of 13 Old 03-19-2012, 07:54 PM
petew's Avatar
Quoted: 25 Post(s)
Liked: 68
OK I'm impressed. That is cool!
All I'd suggest is a darker color.
Building Bass - Subs
Surrounds - Easy as Pi
Storage - unRAID unDELL
Mains - Another piece of Pi
petew is offline
post #3 of 13 Old 03-19-2012, 08:57 PM
cybrsage's Avatar
Liked: 154
VERY nice!!! WOW!
cybrsage is offline
post #4 of 13 Old 03-19-2012, 09:03 PM
White fish's Avatar
nice, glade to see someone trying something different on thier ceilng
I want to do something similar with fabric
been working for awhile and still to shy to post my own build thread
White fish is offline
post #5 of 13 Old 03-19-2012, 09:05 PM
JasonMiller1975's Avatar
Beauty! Great hand-on job. +1 on the darker color.
JasonMiller1975 is offline
post #6 of 13 Old 03-20-2012, 05:06 AM - Thread Starter
macadoo's Avatar
Thanks guys. It is a labor-o-love.
Two reasons for the ceiling color:
1. I've had a dark dark theater for years and it just seems to render the room useless for anything but watching movies, etc. The lighter color illuminates the room better for non-theater type activities. And it doesn't seems to interfere with the picture at all. I should note here that the color is actually just above a medium grey. Not near as white as the picture looks. I flooded it with light and used the flash to get a good picture.
2. If it was a darker color, nobody could see how freaking cool it is! Lol. Which brings me to the only real drawback; I find myself looking at the ceiling more than the screen, lol.
macadoo is offline
post #7 of 13 Old 03-20-2012, 07:23 AM
dRwOOD73's Avatar
Very nice work - elegant look to an otherwise bland tile ceiling.
dRwOOD73 is offline
post #8 of 13 Old 03-20-2012, 07:29 AM
tony123's Avatar
Liked: 38
After more than a decade on the forum, I'm still amazed everyday at the talent of motivated individuals. Great work!
The "Twinseltown" Theater
Construction Thread
tony123 is offline
post #9 of 13 Old 03-20-2012, 09:20 AM
NickTheGreat's Avatar
Quoted: 381 Post(s)
Liked: 255
FANTASTIC
I'm a pretty handy fellow, but I sure couldn't do that. Well done!
NickTheGreat is offline
post #10 of 13 Old 03-20-2012, 10:42 AM
mtbdudex's Avatar
Quoted: 78 Post(s)
Liked: 689
Originally Posted by NickTheGreat View Post
FANTASTIC
+1, I subscribe to this thread for the DIY know how shown here, just in case I want it for some future reason.
Great job macadoo
mtbdudex is offline
post #11 of 13 Old 03-20-2012, 11:09 AM
dwightp's Avatar
-Mac
I would like to know where you get your supplies.
I think this is really interesting. You certainly got a terrific themed look!
dwightp is offline
post #12 of 13 Old 03-20-2012, 01:27 PM - Thread Starter
macadoo's Avatar
A couple of things; White Fish, fabric? Sounds very cool. I'd like to see what you come up with.
And NickTheGreat (and all), everyone seems to think that art is some magical thing ,well...okay it kind of is, but nothing the average person can't try out. I'm actually new to clay. I work mostly in wood and metals. The purpose of this write-up was to show how easy (not cheap) it can be. One of the pictures shows a bunch of fancy clay forming tools. The truth is, I did 95 % of the work with kitchen utensils and my fingers. No fancy tools required. Heck, you could probably use home made salt-dough for the clay and off the shelf 100% silicone for the mold (although the fumes would be dense, and I speak from experience).
I'm actually playing with something called "sculpt-a-mold" which is basically powdered cellulose (like paper-mache). It would be chepaer than the resin and a lot lighter. BUT (and this is one big but) it takes at least 24 hours to cure.
Thanks everyone for the kind words. I did this over my spring break. Talk about not wanting to go back to work. And I love my job! Lol.
-Mac
macadoo is offline
post #13 of 13 Old 03-26-2012, 05:59 PM - Thread Starter
macadoo's Avatar
I've moved this thread to my build thread in my sig. please, make any comments there :-)
-Mac
macadoo is offline
