Living the dream - Upstairs Theater build - Page 12 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #331 of 357 Old 07-28-2014, 11:10 AM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
Originally Posted by wraunch View Post
BIG/et al, What do you recommend using for the black wall panels around the screen? Mine need to be AT but I want them to black it out as much as possible.
Originally Posted by BllDo View Post
I just used some black GOM FR701 for the side/top/bottom panels. The Rose brand speaker cloth would also work for a little less $$. I used it to cover the back wall behind my screen. It's not quite as thick, but I would say it's passable.
Should I use Velvet above the screen to black out the crown then use the speaker cloth or something similar on the sides and the bottom?
From an aesthetics point of view, I don't know that I would use different fabrics. Are you asking about the crown behind your screen or the crown above it?
If it was me, I would be looking at covering the wall behind your screen anyway with some sort of absorptive material. You could use that opportunity to mask the crown behind your screen. Alternatively, you could fill the empty area in the top panel with cardboard or foam insulation to prevent light reflecting through.
I am mostly focused on blacking out the area immediately around the screen for now. I agree the area behind the screen needs to be darkened in areas also. Should I just wrap the crown above the screen in black velvet or speakercloth?
Moving this discussion over here...
Looking through your pics, honestly, I don't think i would worry about covering the crown on the soffit just right now. I think it's a nice detail and it would be easy to do later if you found to be bothering you.
BllDo is offline
post #332 of 357 Old 07-28-2014, 11:19 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Good point. What should I use for the sides and bottom? I'll post updated pics soon.
wraunch is offline
post #333 of 357 Old 07-28-2014, 11:28 AM
roccoleach's Avatar
Quoted: 109 Post(s)
Liked: 52
My soffit ceiling and walls all have acoustimac dmd. Good price and very forgiving easy to work with fabric
roccoleach is offline
post #334 of 357 Old 07-28-2014, 12:06 PM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
An acoustically transparent fabric like GOM would be the first choice. I'm not familiar with DMD, but that also looks like it should work well. Speaker cloth like the Rose brand stuff will do too. It will be a little thinner so more acoustically transparent, but also more light transparent. If you are planning to put your speakers behind your side panels, I would go this route. If they are going behind your screen, then look at GOM. Velvet will block all the light and most of the sound. I've been happy with GOM for my screen surround.
BllDo is offline
post #335 of 357 Old 07-28-2014, 12:10 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
The bottom panel will cover my sub(s), the LCR will be behind the screen. I could make the side panels out of velvet as they do not truly need to be AT.
wraunch is offline
post #336 of 357 Old 07-29-2014, 06:16 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Name:	Blank screen.JPG
ID:	185690Click image for larger version
Name:	Dark of Moon Screen.JPG
ID:	185698Here are two updated pics to see what I'm working with. I did not have the doors closed for the pics so there was a fair amount of ambient light so excuse that and I had light shining in behind the screen which illuminated the vertical screen supports.
wraunch is offline
post #337 of 357 Old 07-29-2014, 08:48 AM
kevin g.'s Avatar
Quoted: 334 Post(s)
Liked: 145
Wraunch,
Love the room thusfar. Quick question, If you are doing AT with that door on the left, how do you plan to close off the side (behind the screen) while keeping a border around the screen itself?
"Once you learn good English...Can't nobody take it away!"
Xbox LIVE Gamertag: KEVIN G 40
kevin g. is offline
post #338 of 357 Old 07-29-2014, 08:55 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
I will have a panel to the left of the screen that will have a slight L to it to wrap around the corner and give the screen a 2-3" border on the left edge while creating a panel to seal off the back of the screen. That panel will be attached with velcro. At least that is my plan currently but I'm open to ideas.
wraunch is offline
post #339 of 357 Old 07-29-2014, 09:31 AM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
I think this is a solid plan. The only thing then will be keeping the velvet clean. You can usually get coupons for Jo-Ann fabrics and save a little.
Love the progress pics. Looking very nice.
wraunch likes this.
BllDo is offline
post #340 of 357 Old 07-29-2014, 10:04 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Do you think I should just get the stretch velvet?
wraunch is offline
post #341 of 357 Old 07-29-2014, 11:55 AM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
I'll have to defer to someone else on velvet qualities. I got nothing on that one. But I did see this thread pop up the other day. I haven't read it, but it may have some good info...
VELVET CLOTH for screen side wall and front ceiling
BllDo is offline
post #342 of 357 Old 07-29-2014, 11:59 AM
cw5billwade's Avatar
Quoted: 328 Post(s)
Liked: 184
triple velvet from syfabrics.com comes highly recommended (Mississippi Man for example, who has done a lot of builds with a lot of different fabrics/velvets) - I bought it, but haven't installed it yet.
this is what I used comes out cheaper than JoAnns even with coupon. High quality stuff
BllDo likes this.
cw5billwade is offline
post #343 of 357 Old 07-29-2014, 12:12 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
And it's Acoustically Transparent?
wraunch is offline
post #344 of 357 Old 07-29-2014, 12:23 PM
Quoted: 328 Post(s)
Liked: 184
No Velvet is but subwoffer does not care about that if you are putting them back there.
post #345 of 357 Old 07-29-2014, 12:44 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Yep that is what will be behind it.
wraunch is offline
post #346 of 357 Old 07-29-2014, 12:49 PM
Quoted: 328 Post(s)
Liked: 184
should be good to go then or so I have been told I am by no means an expert
post #347 of 357 Old 08-02-2014, 05:45 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Ok. I have everything up and running. I'm finding out that my Onkyo 705 might be a little under powered to run my M&K 750 THX LCR and 550THX surrounds, also the bass from the v1250 is inadequate. I really want to wait to upgrade to a new Dolby Atmos compatible receiver but I hate buying new tech before the bugs are worked out of the first generation. So what should I do? I'm leaning towards getting a 2-3 channel amp to provide the needed power to my lcr. Ideas?
wraunch is offline
post #348 of 357 Old 09-09-2014, 05:20 PM
JVoth's Avatar
Quoted: 304 Post(s)
Liked: 152
Wraunch, love the room. Carpet is really nice, and of course you have excellent taste in speakers. I would look at getting multiple subs. I'm an SVS fan myself. I recommend sealed but some people love ported. I tried it and I just like sealed much better. A 3 channel amp from Emotiva would be great. Also try looking on Audiogon for a good deal on a nice 5 channel or 7 channel amp for your surrounds if you can swing it. If not, then the 3 channel from Emotiva will make a noticeable difference. Also, I would look at buying an SPL meter from Radio Shack if you don't have on already.
JVoth is offline
post #349 of 357 Old 09-30-2014, 06:36 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Time for an update. We have been enjoying the theater for a month now and it is quite awesome. I have had a few side projects like building a cabinet for my built in football display case and I recently finished my DIY most posters that will double as acoustic panels once I get some OC703.
TMcG and Boomassiv like this.
wraunch is offline
post #350 of 357 Old 10-02-2014, 01:46 PM
RedLefty's Avatar
Quoted: 32 Post(s)
Liked: 32
Just dropping in to say well done on a great build.
We did our conversion of a basement room into a HT last year which included 8 DIY acoustic posters like yours. Those get more comments than anything else when friends come over.
Your KISS approach to the false wall and AT screen are exactly what I have in mind for our next upgrade (right now just projecting onto painted drywall). The spandex and surrounding velcro panels really look sharp and clean, and I bet the immersion factor is nice.
Rock on.
wraunch likes this.
RedLefty is online now
post #351 of 357 Old 10-07-2014, 06:35 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Thanks Red! I am going tomorrow to pick up my wet bar cabinets then all that will be left is to install them and the granite and build my bar seating behind the riser. The posters make a huge difference in the feel of the room. I haven't put OC703 behind any of them yet but I think I will get a pack of it to start experimenting with which ones need it or not. I also need to get some blank cover plate for my MA rack at some point.
wraunch is offline
post #352 of 357 Old 10-07-2014, 06:37 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Once I'm done I plan on detailing pics with prices paid for various things to really blow everyone's mind. This has been a 2 yr project but I have gotten some steals by taking my time.
wraunch is offline
post #353 of 357 Old 05-05-2015, 08:46 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Ok, need some help configuring my rack. I know I need to swap the flat black panels with brushed ones but what else?
ID:	701498   Click image for larger version
wraunch is offline
post #354 of 357 Old 05-16-2015, 08:09 PM
Liked: 0
@wraunch
My husband is nearing the final stages of finishing our basement HT and I've been stalking this forum and stumbled upon your set-up. If you don't mind could you send me some info?
1) Where did you end up ordering your carpet from?
2) Where did you get your Berklines from? We want reclining sofas and they are breaking the BANK!!!!
Thanks! Love your room!
mama24dudes is offline
post #355 of 357 Old 05-17-2015, 02:41 AM
JRock3x8's Avatar
Quoted: 754 Post(s)
Liked: 197
Originally Posted by mama24dudes View Post
@wraunch
craigslist and patience. I regularly see used theater recliners on craigslist for 50% off retail. Set up an alert at IFTTT so you'll be the first to know when they're listed.
JRock3x8 is offline
post #356 of 357 Old 05-17-2015, 05:49 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
@wraunch
Thanks Mama. It's been a long journey but we enjoy it. Are you in Raleigh? If not for the carpet you'll need to go to some higher end carpet stores in your area to get anything like this. I had a great deal through a contractor supply place called ProSource. I got it for about 1/3 of retail.
On the recliners I bought mine on close out from a local distributor is the only reason I was able to afford them. Patience is the key here. I literally would get on Craigslist daily for about a year and a half looking for stuff I knew I would need eventually. Then I stored it until I was ready to use it.
wraunch is offline
post #357 of 357 Old 05-17-2015, 08:39 AM
Liked: 0
Thanks for your response... I'll keep looking and be patient! I'm in STL, MO.
@wraunch @JRock3x8
