Living the dream - Upstairs Theater build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 10Likes
post #91 of 357 Old 12-28-2012, 09:10 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Spaceman, I agree, that's what I'm going to do.
wraunch is offline
post #92 of 357 Old 12-30-2012, 08:47 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Small update. We have a little over half of the soffit done. I am thinking about doing two arcs on the front soffit. The first would be at the regular soffit height abd it would step up one time. Anyone done that and have tips on the best way to do it? How do you layout the arc(s) on the ceiling? Is there any reason I wouldn't want to just drywall the soffit? I don't need it to run wire, hide HVAC, etc. I have thought about leaving the drywall off the bottom abd stuffing the soffit with insulation to act as a bass trap but I don't know if I will run into issues with my inspector if I do that.
wraunch is offline
post #93 of 357 Old 01-08-2013, 01:34 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Quick update. I just found a ridiculous deal on a MA rack. Not that I need it now but I found the following rack on Craigslist locally.
http://customavrack.com/Products/274-middle-atlantic-erk-4020-40u-rack-enclosure.aspx
It's a 40 U rack that's 74" tall. Way bigger than I need but I figure why not have some headroom?!?! Here's the kicker, it's slammed full of shelves, extra rails, screws, etc, all for the price of $50!!! It has a little bit of paint around the edge of it but I can clean that up in 15 mins. I guess I need to go by some Powerball tickets today!
wraunch is offline
post #94 of 357 Old 01-08-2013, 06:00 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
This thing is a beast!
wraunch is offline
post #95 of 357 Old 01-09-2013, 04:19 AM
hamptonht48's Avatar
hamptonht48 is offline
post #96 of 357 Old 01-09-2013, 07:40 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Yeah the only problem is if I need to change any configurations the rack faces into the theater so I don't know how much help the monitor would be back there. I would love to be proven wrong on that though. One small issue, I measured the rack and it is 20" deep and I have about 22" from the front of the stud wall to the angled ceiling behind it. Is there any issue with the rack top running right against the angled ceiling? It should still get plenty of airflow I think. Here is a small drawing of it I did in paint.
wraunch is offline
post #97 of 357 Old 01-09-2013, 08:53 AM
I think as long as you have adequate airflow from the roof soffits past the rack, shouldn't be an issue. However, it's probably going to be pretty warm there in the summer! You could bring it forward a bit, and fur out the front where it goes into the wall, either with studs or with a decorative frame of sorts, adding some more space behind it. Or cut off the top and shorten it some....!
post #98 of 357 Old 01-09-2013, 10:06 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
I wonder how difficult it would be to cut the top at the same angle as the ceiling? I thought about just furring it out some but I wouldnt want it to stick out too much.
wraunch is offline
post #99 of 357 Old 01-09-2013, 10:23 AM
Since it's not going to be seen from the back by anyone else, probably not too hard. You could then strengthen the top with some cross bracing screwed into it, either metal or wood, and you'd be set. A good metal cutting jigsaw blade, or even sawzall would do it.
post #100 of 357 Old 01-10-2013, 08:02 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
I think it'll fit right up against the drywall. I'll probably do 1/2" in there anyway to save money.
Edit: just realized this was post 100, time to get to work!!!
wraunch is offline
post #101 of 357 Old 01-26-2013, 09:16 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Ok, working on lighting. Trying to figure out how much power I need. My electrician seems to think I can get by with 60 amps. I will have 23 6" cans, 14 3" cans, 7 keyless lights, 2 fluorescent fixtures in closets, one dedicated 20 amp circuit to my av rack, a mini fridge, countertop microwave, led rope in the soffit and various wall outlets. How do I calculate the amount of amps I will need?
wraunch is offline
post #102 of 357 Old 01-29-2013, 04:39 AM
Hey! Did your electrician figure in the upstairs HVAC, also? If you know what kind of unit it is, he'll be able to figure out total amperage necessary (the HVAC will be on a separate circuit, of course). If I remember right, it's a value based on total wattage plus a percentage for instant loads, etc. like when the AC unit starts up. Bad news is, you'll have to use arc fault breakers for all but the ground fault circuit to a wet area (i.e. bathroom), and they are pricey! Lowe's had them for just as cheap as I found elsewhere. There are online calculators for the circuit loads, but he probably already has that. That will help you with the wiring size, too, for the incoming main wire. Of course, I"m assuming you're wiring a brand new panel serviced from the first floor main panel.
Good luck!
post #103 of 357 Old 01-29-2013, 08:16 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Tobe, the HVAC guy told me what amperage he will need for the condenser and air handler. I need about an additional 30 amps between the two of them. He has me going to an 8 kW heatstrip from my 5kW. I am wondering if that is really necessary. The only time I have ever seen my aux heat come on was this past week with the ice we got locally.
Did you have to get a change of service to add your sub panel upstairs or did you have more than 200 amps coming in? If you did get a change what did that run you? We are about to make some big progress once I get my bonus in February. I plan on being rough-in ready in March.
wraunch is offline
post #104 of 357 Old 01-29-2013, 11:47 AM
No, didn't have to have change of service, probably because the house was designed with the option of having the second floor finished prior to buying it. It had one line upstairs already (an outlet and the couple of lights), so they had planned for upgrades.
You can take the information you got from the HVAC guy and the electrician will be able to figure out the load for either an 8 kW or 5 kW heatstrip. There will be a couple of numbers for peak load values, etc. (I think, from memory, so don't hold me to it!) for the unit you'll get that he can calculate from. It might be neglible, and if so, better to have a little more than you need. Of course, your insulation will be top notch, so that will help! smile.gif I got a pretty good deal in that it was the last year for the energy improvement deductions (not sure if they still have that for your current year taxes) and I was able to get a higher SEER rating AC unit for about the same price as the next one down after the deduction.
post #105 of 357 Old 01-29-2013, 02:08 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
On another note I just missed on two GEs the past two days on Ebay. One I was bidding on went for $150 and I wasn't watching the auction closely enough and I just had another new one go for $300. I need a six zone if anyone sees a great deal. I'm going to hold out until I find one for <$300.
wraunch is offline
post #106 of 357 Old 02-01-2013, 07:05 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
All, I wonder if there are any code issues with me mounting my rack as I described above? Also, my studs are 16" O.C. in this space and the rack is 18" wide on a load bearing wall. I imagine I will have to add some studs and header it off in order to build this into the wall? Do you just flush the face of the rack with the drywall or should I bring it out further to flush it up with some casing?
wraunch is offline
post #107 of 357 Old 02-01-2013, 01:20 PM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
I would recess the rack into the casing at least 1/2" or 3/4".
LeBon is offline
post #108 of 357 Old 02-01-2013, 01:26 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
So the idea is to get the edge just behind the casing?
wraunch is offline
post #109 of 357 Old 02-01-2013, 01:47 PM
LeBon's Avatar
Quoted: 184 Post(s)
Liked: 86
That would be a nice look -- similar to the picture above. However, you can recess as much as you want, for example to accomodate a door.
LeBon is offline
post #110 of 357 Old 02-07-2013, 11:47 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Small update, sub panel is going in next week and we will be installing HVAC the following week.
I hit the jackpot on some dimmable LEDs for my can lights today. I picked up 30 of these bad boys by CREE>
http://www.cree.com/lighting/products/indoor/downlights-us/lr6-dr1000
These things retail for $120 each but I found a freight shipper that was stuck with some for $15 each!!! I am trying to get him to sell me the whole shipment of 100 but he is resisting. We'll see.
wraunch is offline
post #111 of 357 Old 02-08-2013, 11:06 AM
NicksHitachi's Avatar
Quoted: 182 Post(s)
Liked: 189
Hi Wraunch,
I recommend at least 40A to the rack if your going to do a serious audio setup. Depending on your sub choice(s) they could easily max out a 20A line.
NicksHitachi is offline
post #112 of 357 Old 02-09-2013, 10:18 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Thanks for signing up Nick. On the road to Wilmington as I speak.
wraunch is offline
post #113 of 357 Old 02-10-2013, 07:53 AM
Quoted: 182 Post(s)
Liked: 189
^cool man, if your ever bored hit me up!
post #114 of 357 Old 02-11-2013, 08:29 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Where do you guys do your research to decide on what speakers to get? I plan on looking through the audio forums here first. I haven't ever really had high quality bookshelf or floor standing speakers but I know it when I see/hear it. I don't want to blow the bank account but I do want some good stuff as I plan on having these speakers for 5-10 years or longer. I am a deal hunter by nature and I will definitely look for a good deal on slightly used speakers if that is the best option but I'm really just trying to get some opinions on what you did to make your decision. Yes, I will be going to the local hi-fi shops to listen to tons of them before I make a decision. I will have an AT screen so I can use bookshelfs, floorstanding, anything I choose.
wraunch is offline
post #115 of 357 Old 02-12-2013, 08:50 PM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Ok I found a good deal locally on a full set of Klipsch icon set including LCR, two sets of side surrounds and rear surrounds. Do you think these are powerful enough for my large room?
wraunch is offline
post #116 of 357 Old 02-13-2013, 04:37 AM
Which model of the Icons were you looking at? I can't speak authoritatively on the nuances of speaker matching to room size, there are folks here far more knowledgable than I on that. But, I do have a set of Klipsch RS-41 rear surrounds that work very well with the rest of the group, which is the Atlantic Technology 4400 series and 642e subwoofer. I've read that some folks find Klipsch's on the "brassy" side, due to the horn tweeter construction, but, like anything, it's a matter of personal preference. You want to make sure that they can be driven safely by your AVR or Pre/Pro at the levels you wish without clipping or distortion, but the best bet is to listen to (like you said) speakers in environments close to what you might be hearing in your own room. Also, of course, budget is a major consideration! I listened to quite a few speakers, not knowing anything about the higher quality sound from better built ones, but I took some material I was familiar with (Iron Man bluray) so I could compare more accurately. Also, room correction and other factors from your sources will alter the sound, sometimes greatly. Check out reviews from various sites such as this one, or Hometheater.com, HomeTheaterShack.com, etc. which helps you see where you might consider . Keep in mind placement will be very important, since you will need to build for that. Since you're going with an AT screen, floor standing models can work, though you may have to elevate those, too, to get them to face the audience correctly.
Better to have a little headroom and have a little more than you need than come up short wishing you went with that next step up! the speakers, projector and AV equipment were almost half my upstairs budget! And I still got a pretty good deal, I think!
Good luck!
post #117 of 357 Old 02-13-2013, 07:28 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Here are the Klipsch speakers I have found the deal on.
WF-35
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780082
WS-24
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780087
WC-24
http://www.newegg.com/Product/Product.aspx?Item=N82E16882780086
WB-14
http://www.amazon.com/Klipsch-WB-14-Furniture-Grade-Bookshelf-Cabernet/dp/B001CDX7D6
I would get two WF-35s, 2 WS-24s, a WC-24 and two pairs of WB-14s for $1000. My only concern is that I was planning on using in ceiling speakers for my rear channels so I dont know that I will use the WS-24s. Would they be better used as my side surrounds? I was thinking of using the two pairs of WB-14s for my sides.
Thoughts?
wraunch is offline
post #118 of 357 Old 02-13-2013, 07:29 AM
J_P_A's Avatar
Quoted: 591 Post(s)
Liked: 443
Chalk me up as another that's missed this thread somehow. Maybe you should change the thread title to, "The Knockers Thread," and put some pictures of door knockers in your first post. I be that would get some traffic smile.gif
I'm signed up now, keep the progress posts coming!
The Plains Theater Has Begun
J_P_A is offline
post #119 of 357 Old 02-13-2013, 07:40 AM - Thread Starter
wraunch's Avatar
Quoted: 122 Post(s)
Liked: 39
Come on in, the water's just fine!
wraunch is offline
post #120 of 357 Old 02-13-2013, 07:56 AM
Quoted: 182 Post(s)
Liked: 189
