Need materials information for theater construction... - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 04-01-2012, 06:32 AM - Thread Starter
FuzzyReets's Avatar
Quoted: 219 Post(s)
Liked: 24
HI folks. I'm getting ready to finish a portion of my basement for dedicated theater usage. The area is 11 x 25 and is currently unfinished. I was looking for recommendations for materials to use to finish it that will provide the best possible sound. Looking for recs on things like type of ceiling tile, wall material, any specific type of insulation, and flooring. Any help would be appreciated. Thanks!
Denon x2300w
XBox One S
Sony BDP-S6500
Apple TV4
LG OLED65B6p
FuzzyReets is offline
post #2 of 11 Old 04-01-2012, 06:40 AM
airscapes's Avatar
Quoted: 381 Post(s)
Liked: 304
You may want to do a wee bit more research before you start your project. Your question is fairly unanswerable.. you have given no details on your space other than length and width. Read some of the existing threads and note the info provided and if more info was requested prior to the answers..
I can't really help you with the answers, but I do know that others will need a boat load more info before they can give you the help you are looking for.
Good luck with the project!
Doug
Planar PD8150 with DC4 DMD paired with a Dalite HP 2.8 110"
http://www.airscapesart.com
airscapes is online now
post #3 of 11 Old 04-01-2012, 06:43 AM - Thread Starter
FuzzyReets's Avatar
Quoted: 219 Post(s)
Liked: 24
What other information is needed? I'll be glad to add it. THanks for the reply.
Denon x2300w
XBox One S
Sony BDP-S6500
Apple TV4
LG OLED65B6p
post #4 of 11 Old 04-01-2012, 07:00 AM
airscapes's Avatar
Quoted: 381 Post(s)
Liked: 304
Like I said, read some of the other projects and see how they start out.. for instance.. Ceiling height? will you be using a front projector? What are the walls made of? current floor? Windows? water issues? Layout floor plan of what you want to build? Sound proofing? BUDGET FOR BUILD, Budget for equipment, location (cold or hot)? Will there be cooling and heating needed? Room in a room? The list goes on and on..
Since you only mention sound, have you started to read this thread on sound treatment?
http://www.avsforum.com/avs-vb/showthread.php?t=255432
It is the first one at the top of the forum in the sticky section. Lots of answers to frequent questions can be found in the sticky section.. Also the forum kind of dies on the weekend so you can probably get some of your questions answered faster doing searches of the forum and reading.
Doug
post #5 of 11 Old 04-01-2012, 08:09 AM
Quoted: 3732 Post(s)
Liked: 3155
For a good sounding room you want to think about keeping sound out. So the first thing to do is learn about how to build the room with soundproofing techniques and products. You want to decouple the framing and hang double layers of drywall on a whisper clips and channel. You can read about it at soundproofingcompany.com.
You also want to address the duct work and how to cool this room without letting the sound travel to other rooms of the house
post #6 of 11 Old 04-01-2012, 08:18 AM
Liked: 3155
If you want a product list here you go
IB3 clips
whisper clips
hat channel
acoustical caulk
Green Glue
5/8 OSB
5/8 drywall
Drycore floor tiles
carpet and pad
paint
1 1/4 drywall screws
2 inch drywall screws
2 1/2 inch deck screws
3 inch deck screws
Carlon adjustable depth electrical boxes
Romex
Step lights
3 inch recessed lights
3/4 MDF
1/2 MDF
Rope light
1 3/4 thick solid core door(s)
Mouse ears black flat paint
Linacoustic
Acoustical Cotton
OC703
Fiberglass wall/ceiling insulation
GOM Fabric
Staples
bunch of miscellaneous nails of various sizes
Air compressor and an assortment of tools
2x4 premium studs, 2x12s and 2x10s as needed per plan
Sand
plastic sheeting
I'm Just getting warmed up.
post #7 of 11 Old 04-01-2012, 08:24 AM
jdanforth's Avatar
Liked: 25
Big makes a really good suggestion here. The articles at that website are well written and informative.
jdanforth is offline
post #8 of 11 Old 04-01-2012, 08:41 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 145
I'll add 1) bandaids and 2) beer. Of course, you can reduce the amount of #1 by buying less of #2.
Spaceman is offline
post #9 of 11 Old 04-01-2012, 09:47 AM
jdanforth's Avatar
Liked: 25
Respectfully, I disagree. Buy MORE beer.
post #10 of 11 Old 04-01-2012, 09:52 AM - Thread Starter
FuzzyReets's Avatar
Quoted: 219 Post(s)
Liked: 24
Haha. THnaks for all the replies. I was just looking for specific tiles to use in the ceiling and specific type of drywall (if any). Just very specific things for the basic stuff, ceiling, floor, walls. Thanks. Budget is about 5k for the space.
Denon x2300w
XBox One S
Sony BDP-S6500
Apple TV4
LG OLED65B6p
post #11 of 11 Old 04-01-2012, 10:08 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 145
That's a pretty tight budget if you are starting with an unfinished space. Obviously, the more you can do yourself, the better. My drywall estimate alone for a 12.5'x19' space was around $5k. I think it's extremely high, but it gives you an idea of where your money starts to go as soon as you start hiring help.
Spaceman is offline
