Drifter Street Studios - Page 2 - AVS Forum | Home Theater Discussions And Reviews
post #31 of 39 Old 06-04-2012, 11:28 AM
stevegravley's Avatar
Originally Posted by AZGAMD View Post
Yesterday I finally got around to taking some pictures of the completed room. I have already posted pictures of the front of the theater so I figured I needed to post a picture of the seats too. The final width of the room ended up being 9'6" after installation of the fabric frames with the first row at 9' and the second row at about 12'.
Those panels are really awesome. Nice job! They really give you the visual feeling of being in the theater, even through they're their for acoustics.
My home theater build thread
LEVEL 4: Center for Entertainment
stevegravley is offline
post #32 of 39 Old 07-10-2012, 09:32 AM
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
Looks like your theater is really coming together. Love the Fabric Frames. Always interesting to see the vibrations on how the frames are constructed. Kreg Pocket holes are a great way to do the joinery. When I built my theater I did not know anything about pocket hole joinery. Keep up the good work. It look great and you will have many many hours of enjoyment watching movies.
GPowers is offline
post #33 of 39 Old 05-10-2013, 10:26 PM
granroth's Avatar
Quoted: 667 Post(s)
Liked: 460
I'm very curious about the HVAC setup. A/C is, of course, of the utmost importance here in AZ. My previous sorta-theater was hot as hades during the summer and so I'm trying to gather as much info as possible to do it right, in my (upcoming) new one.
As far as I can tell, you have an intake vent in the back corner and then two flex-duct outflow vents on each side of the room, roughly in line with the door? Am I reading that setup correctly?
Is this part of an existing zone, or did you create a separate dedicated one for the theater? If separate, is it done via electric dampers or via its own A/C unit?
If it's part of an existing zone, then how well does it track the temperature outside the room? That is, does it get significantly hotter in the theater when a bunch of people are in there?
granroth is offline
post #34 of 39 Old 05-17-2013, 02:41 PM - Thread Starter
AZGAMD's Avatar
The A/C is part of an existing zone with the thermostat in the kitchen. It isn't ideal, but for the most part I knew the negatives before deciding on doing it this way. If we are going to be in the theater during the day I just turn on the recirculating fan and let it run. I have thought about getting a wireless thermostat and just taking it into the theater when we are using it, but so far it hasn't been a problem. In the winter though I usually just turn the thermostat off so it doesn't heat the theater when we are using it. When I had the duct work done I told the installer what the room would be used for and he sized the flex with that in mind. It cools the room off quickly when the A/C turns on, but it also heats it just as fast when the heat turns on. My last theater only had a single vent without an intake so I knew what not to do in that respect. If my theater had an outside wall I may have installed a mini-split. I just didn't want to deal with the water pump. Since my home is a single level I could always add another zone in the future and just move the flex duct in the attic. Hope this helps.
granroth likes this.
DrifterStreetStudios
(A GPowers Inspired Fabric Framed Theater)
AZGAMD is offline
post #35 of 39 Old 06-02-2017, 10:21 AM
bluer101's Avatar
Quoted: 374 Post(s)
Liked: 293
I know this is an old thread but pretty much the exact measurements of my room in our house we close on. Is the OP still around that could provide additional info and photos? What a great theater with little space. With the 7 theater chairs makes it nice over the recliners.
Projector & Screen: Epson 5040ub Elite Screens 100" Electric Video: Oppo 103d Audio: Denon 4520ci Speakers: Infinity RS5 (LW L C R RW) Infinity RS1 (LH RH) Infinity Beta ES250 (SL SR) Subwoofers: 2 SI18d4 Martycubes with iNuke3000dsp and 2 Infinity BU120 Shakers: 4 ADX shakers with Dayton SA230 amp
My Builds--Media console build----Martycube build----ADX Bass Shaker Install
bluer101 is offline
post #36 of 39 Old 06-03-2017, 07:33 AM - Thread Starter
AZGAMD's Avatar
Yes, still around, but haven't been on the forum for awhile.
AZGAMD is offline
post #37 of 39 Old 06-03-2017, 07:35 AM
bluer101's Avatar
Quoted: 374 Post(s)
Liked: 293
Awesome. When you get a chance post up some final photos.
bluer101 is offline
post #38 of 39 Old 06-04-2017, 07:59 PM - Thread Starter
AZGAMD's Avatar
It will be a week or two before I'll be able to get some pictures up. Anything in particular you want to see?
AZGAMD is offline
post #39 of 39 Old 06-05-2017, 09:12 AM
bluer101's Avatar
Quoted: 374 Post(s)
Liked: 293
Like to see you screen wall from back to front and your seating from screen to back wall. Also what did your final measurements end up being? Thanks
bluer101 is offline
