speaker locations - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 04-25-2012, 03:02 PM - Thread Starter
txmxer's Avatar
Quoted: 20 Post(s)
We closed in the garage to make a theater/family room. The overall room is ~20 x 20', and the layout is primarily dedicated to the theater.
My speakers are Swans/Diva series for L/R/C and surrounds. I have a set of Optimus/Linnaeum LX5's that I think I'm going to add as rear effect speakers.
What I really want to address is mounting the LX5 speakers. I was thinking about mounting from the ceiling, but this would be easiest if I turn them upside down--tweeter facing the floor.
Any opinions on this type of mounting for this speaker? Would it be better to mount them lower--closer to the listening position?
thanks
Mike
txmxer is offline
post #2 of 3 Old 04-26-2012, 07:34 PM
Brad Horstkotte's Avatar
Liked: 69
The L/C/R speakers should be roughly at (seated) ear level - flipping them is usually fine, if you can still do so.
Brad Horstkotte is offline
post #3 of 3 Old 04-27-2012, 10:18 AM
dwightp's Avatar
thanks
Mike
I doubt there would be any problem with mounting the LX5's upside down. If anything, getting the tweeter away from the ceiling and closer to ear level would probably be a good thing.
In terms of mounting height, the usual recommendation for surround speakers is to mount them with the tweeters slightly above standing ear height. Ceiling mounted LX5's would be higher than that, I think, so you might want to angle them down a bit.
dwightp is offline
