Dr. G's Humble HT aka "The Escape Pod" - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 12Likes
post #91 of 158 Old 01-15-2014, 11:25 AM
Buckeye10's Avatar
Hahaha.  Yeah, you probably don't want to have the new furniture conversation quite yet!  I look forward to seeing more pictures of the theater coming together.  Hopefully the degree program doesn't get in the way too much.
Chris
Buckeye10 is offline
post #92 of 158 Old 01-19-2014, 09:19 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Okay, it's time for some pictures of the latest. I have the lights and switches in, and I installed the recessed lights and sconces in the theater room, as well as the Grafik Eye QS. It was exciting to turn that on and see everything fade up, and tinker with the zones!
The paint turned out really well. I used the Benjamin Moore Aura Matte paint, except on the ceiling where I used Benjamin Moore Regal Select Flat. Two coats of the Aura, and two coats of the Regal Select (on top of two coats of primer) was all I needed. The colors I posted a few posts back.
I wish the LED recessed lights dimmed lower, but that's only for the cool effect of them dimming perfectly gradually to off. They get to about 9% dim-ness, and if I ever wanted to leave them on while dimmed, I'd never see any reason for them to be dimmer than this. To have LED lights instead of Halogen was worth it even if I have to give up on that perfectly gradual dimming to off. The prices came down recently too, making it quite affordable, especially after the $20/light rebate I should get from my electric utility company for them!
I went with Nora NLEDR-662 series recessed lights from Hanks Electric in CA. I picked the 650 lumen 2700K version with white baffles. I compared them side by side with the Cree CR6 equivalents you can get at Home Depot. The Noras held their color much better when dimmed, and dimmed almost as low (I'd say the HD brand got maybe 2% dimmer but I couldn't tell for sure. The Noras also have superior baffles that keep the glare down compared to the HD brand. They also have a 7 year warranty and 50000 hour life compared to 3 year warranty and 35000 hour life. Also, you only have to remove 3 screws to separate the trim from the driver for spray painting (this is why I got the white baffle version) A clear winner for under 50% more in price. Thanks to Paul at Hank's Electric for introducing me to these gems! (www.hankselectric.com) - you can catch Paul (username: spiwrx) sometimes in the home automation and other forums.
Anyhow, here are some pictures of the current state of the room! I'm in one of them. I don't know if I've been in any up until now, and I haven't been hiding my identity on purpose or anything cool.gif
This first picture is from when I was testing the lighting. I used all incandescents initially, just hanging on the sockets coming from the cans, and the sconces without the covers. I knew it would never again be so bright. I also have my 9000 lumen worklight shining on me too. So my look is the "ta-da" of the super-brightness, kind of like the scene in Lampoons Christmas Vacation when he turns on the lights.
This picture is of the four screen wash lights in the front. They are gimbaled so I can aim them toward the screen. I set them back kind of far and made them gimbal in case I ever want to try acoustically transparent setup in the future. I made them so I could have up tp 14" deep area behind the screen and they'd still be comfortably in front of the screen.
Here is the room after putting in the recessed LED lights and the covers on the sconces. I still have to take the LEDs out and paint the trims black, but I had to at least try them! You can see my trim/casing on the floor. I still have to paint and install that.
Here is the equipment closet. It's painted white inside. And plenty of light. The opening is a rough space sized to fit a Middle Atlantic brand Slim5 model 5-29 29U rack. But I don't know if I can afford the actual rack with the shelves and faceplates, so I might put in some DIY shelves for now. The plastic bags were put over the wires to protect them from drywall and paint.
Here's inside the equip closet looking up at the ceiling. I have a line voltage cool thermostat that I can set at up to 95 degrees. It turns on the fan, when triggered, a super quiet Panasonic fan. There's a switch on the wall that overrides the thermostat if I just want to turn on the fan for any reason.
The grafik eye and other switches. I put the back of the faceplates on but not the front that snaps on. I don't have a cover yet for the remaining empty (future expansion) 4 gang box.
Hardware and System engineer. Enjoy theaters, automation, media and the outdoors.
Love the hobby, but always have to remember to keep family first!
"The Escape Pod" - First Theater Build
danielrg is offline
post #93 of 158 Old 01-19-2014, 09:22 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
I have several things left to do:
- Put down the radiant heat mats in the bathroom and hire someone to tile over it in the bathroom
- Get cabinets, sink, toilet installed, and the rest of the bathtub faucetry.
- Install the doors. They are sitting downstairs right now just waiting for it.
- Paint my casing and baseboard trim
- Cut and install casing and baseboard trim
- Paint door frames and doors
- Patch/touch-up paint trim, casing
- Install closet shelving
[You may note I'm not back to the theater yet - well the trim/doors include the theater tongue.gif ]
- Get carpet installed
- Hang closet doors
- Put weatherstripping around theater door (I bought a solid core door for the theater room)
- Install the rope light. I'm going to be cutting it down to the _exact_ length and do some resistor trickery with the last 2' section to get it the exact length I want.
- DIY shelving in the equipment closet
- Finalize equipment list (receiver, projector, speakers, screen, repeater equipment, bluray player, streaming player, power conditioning, etc.)
- Purchase and install equipment (except for screen)
- Bring down the furniture (wife will cheer!)
- Evaluate various screen materials, all while watching on a sheet. Get a feel for seating distance and screen size we like
- Finalize seating distance and screen size, purchase and install screen
- Build riser for 2nd row of seating and carpet it (going to make it a bass trap)
- Do acoustic measurements (REW or whatever I decide to try)
- Acoustic treatments
@ Chris: The masters program I just started is pretty intense. I had 150 pages of reading and several hours coursework this week alone, and I'm only two weeks into the intro course. eek.gif Plus keeping up work full time. I think I'll only get any significant work done between classes, provided I'm not in a coma by then wink.gif
I have a 2 week break in March and 2.5 month break from the middle of May through end of July. My hope is to have the equipment purchased and rudimentarily installed by the end of July. We'll see how it goes!
I don't expect to have the acoustic treatments up at that point. But I'm hoping the screen and riser can be done by then.
danielrg is offline
post #94 of 158 Old 01-20-2014, 02:11 AM
Tedd's Avatar
Quoted: 933 Post(s)
Liked: 342
Shaping up very nicely. Love the color scheme.
That is one heck of a pile of switches/zones for a single room!
I doubt the riser will be much of a bass trap as the vents aren't in the room's tri-corners,
where the sound pressure is at it's peak, in the room. The insulation in the riser will help
prevent it from becoming a resonant chamber though.
danielrg likes this.
Tedd is online now
post #95 of 158 Old 05-12-2014, 12:16 AM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
I like the color scheme too - my wife and I picked from those 1"x1" swatches with lots of comparisons to colors and so forth. We didn't do any sample painting. The more I look at it the more I like it. The finish on the Benjamin Moore Matte and Flat is excellent too.
Yeah - on heck of a pile of switches. I kind of wonder what I was thinking now when I look at it. It's pretty fun to toy with though, I hope I have fun with the versatility in the future.
Thanks for the notes on the bass trap - speaking of bass trap, my parents just upgraded their bed and put their old mattress in the back of their theater room, it's about 15" thick, about 5" from the back wall. I watched the original Superman in there on Blu-Ray the other night and it sounded fantastic! I've never heard his room sound so good. At first I thought it was due to his new center, but in the end I realized it was the mattress in the back of the room, it was absorbing the back reflections and soaking up the excess bass. Never heard his room sound so good. Maybe I'll just put a mattress in the back of my room wink.gif
danielrg is offline
post #96 of 158 Old 05-12-2014, 12:40 AM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Okay - so my class is finally coming to a close this Thursday - then 2 1/2 months off school!
I want to finish the basement SOOO badly. I have to put up the doors (about 12 of them - they are already sitting in the basement), then paint the doors and trim, then install the trim. The next thing after that - carpet!
Then on to filling the room with the equipment. I've been looking forward to this. I wanted to do acoustics first, but who am I kidding - I want to be watching movies! And my wife. Plus I kind of want to make acoustic improvements slowly, so I can hear the difference with each attempt.
I have been doing some speaker auditioning, and lots and LOTS of reading after hours, after work and homework.
I have auditioned:
  • Def Tech floorstanders - didn't really like that much, don't even remember the model
  • Infinity P series - P363 and their center. I actually bought these on a steal and put them in my dad's theater. I like them quite a bit, but I think I want more. I'll probably give them to him. I have spent some time with them so they are sort of a benchmark for me. $414 for two front floorstanders and a center is a nice price! But as you'll see I'll probably spend much more.
  • Klipsch RF-62 - Too in your face and aggressive for me.
  • Polk TSX-550t - These have crazy model numbers, I had to look it up to remember. I liked these, but they sounded a little harsh/strained in the highs. Bass was ample but a little muddy.
  • Martin Logan - I don't remember what I tried. I liked them, but felt they were too directional.
  • B&W 683 (S1) - I think I'm a sissy. I fell in love with these. I felt like I was being coddled in the womb. Some of my favorite classical recordings made me emotional. They also cost a lot. But I so far they are my favorite.
You may notice that costs vary all over here. I listened to some at Best Buy, some at one local A/V store and some at another.
I also spent about 30 hours making an auditioning CD that I tried to have cover my broad likes in music and throw some complex, deep, and emotional things at the speakers. Now that I have this CD I want to try everything again biggrin.gif
I have a friend with some Axioms so I'll audition those soon, and another friend with Home Theater Direct Level 3 speakers. I'm also planning to try out some Monitor Audio Bronze and Silver. Some KEF if I can find them. EmpTek speakers are manufactured about 45-50 miles north of me, and said they do auditions at their plant. That might be a fun trip, if I find the time.
As far as receivers, I have really only listened to these at Best Buy. Except Marantz, I also listened to that at one of the A/V stores with the B&W speakers. I really liked that too.
danielrg is offline
post #97 of 158 Old 05-12-2014, 02:14 AM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
This is by no means final, but wondered if anyone had any comments. Here's a preliminary equipment list for what I'm considering:
  • Projector: Epson Pro Cinema 6030 UB - I want black chassis, the bulb, the mount, dealer support, and the anamorphic capability (for future experimentation), and the dealer said he'd calibrate for free. So enough reasons to me to go with it over 5030UB. I hope he's good at calibrating!
  • A/V Receiver: Marantz SR6008 or SR7008. Leaning toward splurging on SR7008 for power, 9.2, and Audyssey XT32
  • BluRay Player: Oppo BDP-103D. I've seen a lot of Darbee and think it's cool, for $100, why not get it and try out? It's $300 to add it later, and another box. I love everything else about the Oppo too.
  • Screen: 110" Fixed Frame Carada Criterion Brilliant White 1.3 (actually people say more like 1.1) gain screen
  • Front Speakers: (2) Bowers and Wilkins 683 S2. I loved the S1. All say S2 is better. And I'm becoming an audiophile on the side just auditioning all the speakers.
  • Center speaker: B&W HTM61 S2
  • Side Surround Speakers: (2) Axiom QS4
  • Rear Surround Speakers: (2) Axiom M2 bookshelves
  • Subwoofer(s): (2) SVS SB2000 - I've done a lot of reading and sealed sound more like my style. I might miss out on chest thumping bass in movies, but I still think I'll prefer. Fortunately they have an AWESOME exchange/return policy. I will buy one first then add a second later if I think I should - or still have money.
  • AV Rack: Middle Atlantic Model Slim 5-29, with all the trimmings for my gear. Much more space than I'll use initially, but I already built the room for it! I might go DIY if I run out of money but right now saving the effort sounds nicer.
  • Xantech 789-44 IR Repeater, single zone, with an IR Blaster pointed at rack (maybe if I can figure it out), and other single emitters inside rack (may add a Global Cache Bridge later on for more automation) - this will also connect to the Lutron Graphik Eye QS at some point.
Any gear I'm forgetting?
Power Conditioning? I'm going to start with a surge protector for now. I'm a little wary of the power conditioning, seems like a great opportunity for snake oil. Might get a pure sinewave battery backup for the projector (glad I put the powerbridge in!) - and maybe a $200 or $300 power conditioner for the rest. We'll see.
I plan to add a media PC later as well, and rip my music to FLAC at some point. I might get an inexpensive music server sooner rather than later.
I can get the projector, receiver, bluray player, front/center speakers all locally, from a very nice audio/video store. He indicated he'd get me a good package deal. I might get an inexpensive Screen Innovations Sensation line screen from him, but I read good things about the Carada, we'll see how that goes. He also sells middle atlantic racks, so that's convenient too. He has a great return/support/trade-up policy and having a local dealer sounds really nice for the main equipment items.
danielrg is offline
post #98 of 158 Old 08-21-2014, 11:29 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
I'm still around!
Since school started... ugh.
I had 2 months off in summer but then work went crazy.
I just have caulking, touch up painting the trim, installing shelves in 2 closets - and then theater trim left. Then carpet!! So close - yet so far away.
danielrg is offline
post #99 of 158 Old 11-22-2014, 01:51 AM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Always so close - yet so far away.
It took FOREVER to finish installing all the shelves in the basement. But I have some fine closets! Six of them, lots of good storage space!
Caulking is done. All trim installed, including in the theater - I'll have to post some pics soon.
All holes are putty'd and sanded, but not touched up yet.
So what's left? Need to touch-up paint ALL the trim in the basement, paint the doors, door jambs, and install most of the outlets. Carpet too.
This whole next week, I'll be a painting fool. Painting has been so much work than I ever thought. Oh, if I'd known I'd have learned to mask and spray.
Hopefully after Thanksgiving, with painting complete, I can get the carpet put in. That will be a great milestone, because then I can start filling the room with equipment!
danielrg is offline
post #100 of 158 Old 11-22-2014, 07:11 AM
DavidK442's Avatar
Quoted: 511 Post(s)
Liked: 343
A long process but sounds like things are coming together nicely. Always interested to see what people can do with a narrow room (having one myself) so looking forward to some more pics. That is an impressive, well planned equipment list and I'm sure you will be happy with the BMW speakers. Would be very interesting to do a side by side, level matched, switched comparison with the Infinities you gave your father. Two well respected hi-fi tower speakers miles apart on price.
DavidK442 is offline
post #101 of 158 Old 11-22-2014, 11:08 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Funny - I always thought I'd be faster than those forum posters that take five years. I think I'm going on a little over three. Now I do have an excuse - I'm doing a whole basement - but so are some of those five-year folks.
The narrow room. At first I was upset about it, but I'm pretty used to the idea now, and it will seat three across if I'm creative. I'm interested to see how the acoustics end up as it opens in the back and stuff.
Very excited about the equipment list - though I will be auditioning some other stuff and seeing if there's new stuff before pulling the trigger. Like The new Marantz 7009 - which supports Dolby Atmos Surround processing. Awesome irony - I put in 16 or 17 speaker drops all around the room, trying to future proof. Then the next big thing is speakers in the ceiling. Doh! Don't have any drops for those! Just shows you can never know for sure what the future will bring. Of course I still have ideas on how to get speakers on the ceiling if I want to try Atmos out...
I will bring the Infinity's back for a comparison at some point. My dad is sure liking them, especially for free. But that's once I've got some stuff in and also know how to level match and all that (learn REW or something like that) to try to take as many variables out as possible. I was thinking of getting the SVS Ultra front three speakers too when I buy the subwoofer(s) - they have a 45 day shipping both ways trial period. That would be cool to compare those, B&W 683, and the Infinities, all with the same gear and room.
Thanks for the comments! It's been quiet here (from both me and others )
danielrg is offline
post #102 of 158 Old 11-22-2014, 11:25 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Okay, time for a few pictures.
I put in the black trim. There's white spots where the putty is, I haven't touched it up yet.
It was really neat to see the wide casing and baseboards go in, really like the effect of the black, and it makes the room seem much more...done.
The door jambs will be painted black like the trim. The doors will be painted tudor brown like the ceiling and screen wall.
I installed the equipment rack too! I got a Middle Atlantic Slim 5-29 19 inch deep rack. Got it all squared up and put the casing around it, leaving about a 2mm gap from where the edge of the panels will be to the edge of the casing, the casing overhangs the edges a little. Looks pretty classy.
Also really excited about the rope light tray. That came together nicely with about a 3/4" deep 5/8" wide tray for a rope light. I still am trying to figure out a way to make the rope light exactly the right length - I think I'll have to cut into one of the sections, making it partial, and use a resistor to keep the load for that section right.
Anyhow, here's the pics!
Trim up on sawhorses after being painted - being cut and installed:
Looking toward screen wall:
Looking toward back. The windowsill and casing turned out nicely. It will all be painted black between the window and the casing and black automated shades will be installed.
Equipment Closet with casing!
danielrg is offline
post #103 of 158 Old 11-22-2014, 11:29 PM
DavidK442's Avatar
Quoted: 511 Post(s)
Liked: 343
A lot of great builds these days. I spend too much time on here as it is and still find it difficult to keep up. A lot of people browse but don't leave comments. I'll tag along to see how it all ends.
I always looked at my own build thread as a personal scrapbook. Interesting to go back and remember the "dark days". A good deterrent to ripping it all out and starting 2.0.
post #104 of 158 Old 05-21-2015, 02:35 AM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Short update. It has been too long.
Note to self: Don't get a master's degree and try to finish your basement yourself at the same time.
My basement is ready for carpet, and has been for a couple months. But I am so deep in work and school right now (Master's project) that I don't even have time to clean it out so the carpet layers can come.
Trim is all in, sanded, touched up. Need to put in a few outlets and some light fixtures, some door hardware.
One more month and I can start on it again. BUT - the wife is sick of me working on the basement on breaks between classes. And she made me schedule a vacation.
Vacation? What's that? Actually I'm really looking forward to it now. So sometime in July. I might get carpet in...
danielrg is offline
post #105 of 158 Old 08-01-2015, 11:58 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Finally! Carpet has been installed in the basement (And theater room). Makes it seems so much more done.
But there is still much left to do of course.
I have put in most of the outlets in the rest of the basement but have many to do in the theater room still.
I have to do some spray painting of the trim on the recessed lights, put on blank plates.
Then of course actually start getting equipment...
I have carpet extra for a platform, but I'm going to carpet a platform separately and just set it on the current carpet. That way the room can go to multipurpose in the future (don't know why it would) and also pass inspection - because the platform might be too high and make the ceiling too low for that area. So platform/riser to come later also.
Okay - pictures...
Here's the space ready for carpet... Toward the screen wall:
Toward the back:
With carpet pad installed - toward the front:
Toward the back:
I put up this roll of stiff paper board that is sold in carpet supply stores to cover finished floors in spaces that will be getting construction done. It was hard to put up but worked great to protect the walls! When I removed it there wasn't a scuff or mark on them. One thing that made it a pain to put up was having to keep it 1/2" off the ground so they could still tuck the carpet under the baseboard. The stuff was called "Surface Shields Builder Board".
Okay, so then the carpet went in! Here's toward screen wall with builder board still up:
Removing the builder board was a big pain, because I had taped it to the underside of the baseboard, and the carpet is THICK. So it mostly wanted to tear off and the carpet was crammed under the baseboard very tightly, my forearms got sore from trying to reach through the carpet to pull the tape out from under the baseboard. But I pretty much succeeded. In some places there is still tape down there where it will never be seen.
Here's the theater with the builder board removed... looking toward the front:
And toward the back:
Toward back left:
The carpet is not really this light seeming. It's more of a chocolate. But the camera wanted to expose for a good long time. All the paints are LRV (light reflectance value) of 8 or less, and the carpet really sucks up the light too. With the lights off and at night (since I don't have the shade in yet) it is pitch black in this room! The tiny LEDs on the Lutron Grafik Eye seem almost blinding. Even in the day with nothing on the window, the screen side of the room just soaks up the light.
Need to get the doors up and all the outlets in and blank plates on for all the speaker areas. But things are getting close!
As usual, I have the rest of the basement to finish up too. Been doing this 4 years or so now! How the time flies.
Master's degree is going well, the master's project of death is over, and our group made it through with a good grade (A) and we have 4 electives. May 2016 I'll have a system engineering degree... whatever that means.
Vacation was great too - went to California on a road trip to San Fran, down Hwy 1 to LA. It was crowded, but we had tons of fun, and the people all around make it lively.
danielrg is offline
post #106 of 158 Old 08-27-2015, 11:20 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
I must be crazy, but I pulled the trigger on a Lutron Sivoia QS Wireless blackout shade with side channels and everything for the window in the back of the room. It will operate direct from the seeTouch pad and Grafik Eye QS shade control columns. It sure wasn't cheap though.
I could have done Sivoia QS wired share for a little less, but I may upgrade later to RadioRA2, in which case I'd need it to be wireless. I can actually hook it in right now on the wired QS link, then add the antenna later if I move to RadioRA2.
Since it is custom order, I won't be seeing it for 4-6 weeks - but hopefully it will be worth the wait!
danielrg is offline
post #107 of 158 Old 08-29-2015, 03:20 PM
swanym's Avatar
Liked: 3
Subscribed to your thread. Nice to see someone nearby. Also in SLC. I started a basement "finish" project late last year. Wife wanted it done in 2-3 months. Purpose was / is to have a comfortable place for 1-year-old to play. Of course, this meant not taking shortcuts, sealing drafts, insulating walls and floor, etc. We also made the mistake upstairs of sharing TVs and in-wall speakers via a common wall between great room and bedroom. Loathe to repeat that experience.
So once (the wife, I knew already) realized her initial 2-month goal was completely unrealistic, we're taking it slow and steady. I'm hoping to finish this year. Starting with the important stuff - new furnace and water heater that direct vent outside so I can remove the "fresh air" (aka "heater in the summer and A/C in the winter") duct dumping large quantities of air into the basement that would be a huge source of drafts. As I became obsessed with insulating, I started to think I wanted one room better sound-treated so I could use it as a listening / movie watching room, without disturbing upstairs or next-door playroom with kids, or guest bedroom also downstairs. But it cannot be a completely dedicated theater room. Has to be "entertainment overflow capable" (more lights, flexible seating, etc. than a dedicated theater might have). So I've put a pause on progress while I've been waiting for the new water heater to arrive, and reading furiously through AVS forum build threads. About to start cutting nails and put double drywall and GG on the ceiling between joists to aid in footfall sound dampening and currently horrendous sound leaks from upstairs. How far I go beyond that will be an interesting exercise in compromises, and doing all I can that's worth doing (probably some that's not: I'm a bit perfection-obsessed as an engineer myself).
In any case, I very much enjoy reading threads like yours (as well as the super-elaborate ones) and following the decision process. Looks really, really good. And you're getting so close. Good luck with the degree. And man, if you have a little one come around, progress gets even slower! (now-18-month-old destructo machine at my home).
I may start a build thread myself soon once I get back into active progress if I think I won't get too ridiculed for having to use a [*gasp*] TV as my video source instead of a projector (first major compromise as it must be a normal living space). It sure is nice to be part of this great community. If so far one-sided (receive-only on my part ). Not sure if I'll have anything to add, but my unique constraints, like yours, may give someone ideas who's in the same boat. Lots of folks here willing to take considerable time to share thoughts, experience, etc.
Looking forward to your finished theater.
swanym is offline
post #108 of 158 Old 09-01-2015, 11:18 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Thanks swanym for stopping by. Nice to know there's some looking going on. I hope I can inspire - either for or against my ideas
It is nice to have someone looking that's local. I really haven't found other Utahns around these forums much. Or they're afraid to say so, closet Utahns.
Funny thing is my equipment list I posted a while back is already out of date. I'm looking at more options right now for equipment, but waiting until I pass inspection before doing some serious auditioning.
I was sad not to do soundproofing. But my room was too narrow to build room in room and those power panels made it nearly impossible to benefit from DD+GG and I couldn't get over the look I like of recessed lights, which meant sound boxes for the lights, and the expense and time mounted and mounted to make it too much for me. All I did was put in a solid core door and some weatherstripping, and 5/8" drywall. That all helps a little, but someday maybe I'll have the space for soundproofing.
I can understand the insulation obsession. I spent quite a bit of time working on insulation and airflow. To be an engineer can be fun or torture sometimes.
I'm still watching the tube TV. And for a while, I considered just a big TV at the front, and even wired for it. But with my good light control, a projector is the way to go. My room is somewhat configurable, I wanted to be able to sell to someone not so interested in theaters and feel they could use the room as a family space with just paint and carpet change. That's why my platform will be built separately.
Yeah, I'm excited to be almost there. I need to post some more pictures. The doors are up and the covers are on all the boxes. Need to paint the light cans and paint and put up the vents, then I'm ready to build the platform and get equipment.
After spending some time on that stuff, in a year or so, I want to put in acoustic treatments and do REW in detail on the room. I kind of want to do it progressively so with each year I can upgrade something and notice the improvement, keep the hobby from being too obsessive at any one time.
I hope you do start a thread! That would be great. I like it just as a journal of progress and to show co-workers and friends when we're chatting we can just bring it up. I do enjoy when people post but either way the thread has been good to have.
danielrg is offline
post #109 of 158 Old 09-18-2015, 09:12 PM
swanym's Avatar
Liked: 3
Hey man. Guess I can't reply via PM till I've been more active around here. Suppose it's time to either start my build thread, get start posting instead of just reading all day every day, or both.
It would be great fun to get a group together and swap ideas and see each others' progress. Heck, it would even provide incentive for me to keep going. And, you know, just so those midwestern guys don't have all the fun!
Yeah. I have been a software developer for many, many years. Most recently for a semiconductor factory automation (robotics control) company I co-founded 15 years ago. Your job sounds like a lot of fun. Live in Sandy/Midvale area.
I've taken a rather long basement / theater hiatus as we've waited for funds to come in (and waiting for a specific water heater model to upgrade our plumbing before I cover everything up). About to kick off plumbing and electrical again soon. Week or two away. Then the progress should be constant till finish.
I'd say "hope / plan to finish by the end of the year". But around here those kinds of statements get you automatically "Loganized". I think now it's built into some forum post analysis script that runs nightly.
Sorry for the thread distraction. Post #6 and counting ...
Mark
swanym is offline
post #110 of 158 Old 10-17-2015, 01:01 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Painted my recessed light trims, and thermostat and smoke detector to all be black!
Here's the final results of my efforts. I ended up using Valspar Color Radiance flat black. The cheaper std Valspar was actually flatter, but I didn't want to go back to the store and I kind of liked the satin finish I got with this. Didn't go with the BBQ paint as these are LEDs and trims don't get very hot. I had some and tested it too, they all looked good.
Paint:
Painted Trims:
Here's the LED Light modules - it was nice that with three screws I could remove them do I didn't have to mask anything off:
Installed Trims:
I completely took apart my thermostat and smoke detector too and painted the shells. Worked out pretty well:
So there's the final result. I'm pretty pleased.
Tedd likes this.
danielrg is offline
post #111 of 158 Old 10-17-2015, 01:08 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Here's a few pics of updates!
I got my Lutron shade installed and programmed. Works with the Grafik Eye, wireless remote, and keypad by the door. Super quiet motor, all you can hear is the fabric rubbing the side channels. COMPLETE blackout too. I even caulked around it for any light gaps. I really like how it turned out. And for the money, I needed perfection here
A couple pics of the room. Need to clean it up and get some better pics. All the doors, trims, etc. done. Only thing left is to get the rope light up for the room itself to be complete!
ID:	1001377   Click image for larger version
ID:	1001385   Click image for larger version
ID:	1001393   Click image for larger version
ID:	1001401   Click image for larger version
danielrg is offline
post #112 of 158 Old 10-17-2015, 01:58 PM
DavidK442's Avatar
Quoted: 511 Post(s)
Liked: 343
Very nice. I like the orange colored walls; a nice change from "theater red".
Glad the blind worked out. Not a cheap solution, but elegant.
In the home stretch. Looking forward to seeing it all come together.
post #113 of 158 Old 10-18-2015, 06:54 PM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Funny things about the walls is they don't look that orange in person. I think it's that they tend to absorb so much light that the camera tends to oversaturate to compensate. It's Benjamin Moore Arroyo Red - it does have a hint of orange and brown with the red, and the camera really really seems to pick that up. Pictures with natural light or with the flash look more red and are a little truer to color.
Anyhow, thanks for the post! Really looking forward to it. I've started planning my auditioning.
I put together some fancy spreadsheet with all the options I'm considering, I can filter based on various options and see what the retail price of the equipment will come to - I can also sort by vendor and get vendor subtotals so I can go to them with a budget.
The one thing I don't like is seeing everything left to get added up
danielrg is offline
post #114 of 158 Old 11-11-2015, 12:32 AM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
I've been so busy with school and work (oh, and I had the flu for the last 2 weeks also) that I haven't had time for updates.
Even though I am purchasing equipment, and cables, and whatnot left and right so I can get this theater room up and running during the week of Thanksgiving!
I'm pretty excited.
It is also agonizing to order stuff and wait around for it all to arrive. Of particular agony is waiting for the projector. I ordered a Sony VPL-HW55ES. They are a good price right now ($2999), and I got an even better deal from the local vendor. But the last thing the vendor said was, "Sony has them, they're sending me one, but you just never know when it will get here. I had one time that Sony took 6 weeks to get me a projector. Argh!! That isn't what I wanted to hear.
Especially as the HW55ES is now discontinued, so there is limited stock - to wait weeks and have any trouble means there will not be that many around. So that's the most aggravating waiting game.
More to come. I should have posted my equipment list so people could comment before I ordered, but it was all I could do to get the auditioning done and all the ordering in and school and sickness... well we've all had those busy stressful times
So here's the equipment list:
Sony VPL-HW55ES projector
Marantz SR7009 A/V Receiver
Oppo BDP-103D BluRay Player
B&W 683 S2 front L/R
B&W HTM61 S2 center
Axiom QS4 side surrounds L/R
Axiom M2 rear surrounds L/R
SVS SB2000 subwoofer
I've got a chief RPMA-U mount on the way for the projector
Carl's blackout cloth right now for the screen, so I can experiment with different projected image sizes and so forth
In the end I'm planning to go with a Carada Brilliant White screen, just want to make sure I know what size I want and how I'll do seating. So using the Carl's blackout cloth to figure that out. I have some various screen samples too to try out.
I'm also wondering about getting an HDTV antenna and tuner for local channels, a gaming console, and a streaming device like a Roku. Any suggestions or comments are welcome!
danielrg is offline
post #115 of 158 Old 11-11-2015, 12:42 AM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Mark
I never really responded to your comment. Just know there's no such thing as a thread distraction for me. I like activity on the thread.
I can see you're still around reading stuff, but the post count hasn't gone up for a while. If it's anything like what happens to me - life is always getting in the way
Funny about factory automation. I sat next to some guy at the Utah symphony performance a couple months ago who also did factory automation. He was a EE by trade. I think that would be a fun job too, I like automation (see my sig...)
I hope you've found success in moving forward from the water heater stuff and have been able to get back into plumbing/electrical. You should start a quick and dirty build thread. Just a floorplan and a couple pics would be great to see.
I haven't been Loganized on this thread (I don't think...) but have been threatened with it on other threads
danielrg is offline
post #116 of 158 Old 11-17-2015, 02:05 AM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
I'm starting to debate whether I should get an Ambient Light Rejecting (ALR) type screen for my room.
I started a thread here on the matter:
Do I want an ALR in a dark light controlled room?
Read it and tell me what you think!
Is it worth more money? Would I see benefits in my space in contrast ratio?
danielrg is offline
post #117 of 158 Old 01-13-2016, 01:00 PM
ChadA's Avatar
Quoted: 83 Post(s)
Liked: 88
Your build is great! FWIW, given your total light control, I'd be inclined to go with a white screen. Spend the difference on something "fun" like acoustic panels covered in movie poster prints, RF 3d glasses and converter, or popcorn machine.
What are you doing for a remote control?
ChadA is offline
post #118 of 158 Old 01-13-2016, 03:44 PM
Amateur Audiophile
Quoted: 22 Post(s)
Liked: 3
Thanks for the build thread - I subscribed! Now that I'm caught up (took a bit of reading) I can't wait to see the finished product. Looks like you're so close now! Great job on your sketches too, it really helped me follow the logic & challenges you went through and how you decided on the best solution. What did you decide on for your screen?
Pacific Breeze is offline
post #119 of 158 Old 01-14-2016, 11:27 AM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Haven't seen much activity here lately... I keep meaning to put up more pictures, things have come a ways over the holiday break, and I've watched a few movies at this point.
Still not completely done - haven't built the platform yet - because it's so incredibly cold outside and my garage isn't heated... so I'm waiting on that. So that limits me to one row of seats.
I built a DIY screen out of blackout cloth and some poplar. Made it really big to try different screen sizes. I'm really liking 110" sitting 9' away Technically I can see the pixels a little, but only in computer images. In video content, I can't really make them out. My wife likes the immersion too.
I'm pretty sure I'll go with a white screen. Even on the blackout the picture is awesome, but I can see the texture and uniformity is lacking. So it will be nice to get the final screen in the next month or so. Leaning most toward the Carada now, I'm looking at their two screen materials.
For remote control - right now I have a pile of remotes But the plan is to get an Android table or iPad, and use iRule. I have Ethernet control for the IR/RS232 (Global Cache GC100), my AVR/BluRay and Roku support IP control, and I have an IP controller for the Lutron lighting/shade. I just have to figure it all out, which probably won't happen until I finally graduate in May.
Any suggestions on remote control are welcome though! Right now I just have a Xantech repeater so I don't have to point my remotes behind me at the rack...
Funny thing is, the Marantz, if I use the IR input on the back, still accepts IR from the front. But the Oppo, only accepts it in the back from Xantech if plugged in. So I have to point to the front of the room now for the Oppo.
danielrg is offline
post #120 of 158 Old 01-14-2016, 11:42 AM - Thread Starter
danielrg's Avatar
Quoted: 142 Post(s)
Liked: 55
Thanks for the comments.
My latest challenge was deciding whether to get dual subwoofers. Since I went with a sealed sub, the SVS SB2000 - one of them wasn't really cutting it for the impact in movies. I got a second one, and it seems like I can get 4x the output now, I think because it's enough to properly handle the room size.
My wife certainly noticed the difference upstairs! With one sub she said it sounded like I was rolling wheels on the ceiling, not too annoying. After two she said everything was rattling in the kitchen upstairs, and we had to have a talk about when I'd watch movies with a lot of bass ("I can't even be in the house with that racket!")
I explained I can turn the bass down pretty easy or turn on Audyssey LFC (low frequency containment) and that set her at ease, I was cranking it a bit to see the headroom, and there was plenty for me. Now it's in the scary realm and I'll have to figure out how to stop the rattles. Not that I'm complaining
Too bad I couldn't soundproof the room, but it just wasn't possible with the load centers being in the room, how narrow it already was, and how badly I wanted recessed lighting. I'm not a big bass-head though so I often won't have it loud enough to bother her and when I watch at volumes I like she doesn't complain at all. And I can't really hear her bopping around upstairs either. So I guess it's okay.
I mentioned screens in the post above, but I'll elaborate. I was tempted by the Silver Ticket - the material measures really well for neutrality and uniformity, but I haven't really gone budget on anything and I think I want the nicer frame and fabric texture and build quality of the Carada brand screens. I like them because they are kind of in the middle - between the $1500+ screens and the <$500 screens, and I've been going mid-grade or better for most components, and it's made the process pretty nice.
I forgot to mention this when responding to ChadA - I did get an RF converter for the projector (Sony HW55ES), and one pair of glasses. I used it, and it was nice not to lose sync in the back of the room (I do with the IR glasses). But I have 4 pair of IR right now, so I'll probably use them for the time being, and build my RF glasses count up later, especially since I don't have a platform and can only have one row.
I did succeed in getting RF setup for $66. Much better price than getting the RF emitter from XPAND directly and the converter cable from Sony. The cable alone is $75 Instead, I bought this:
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
a standard RJ45 cable, and some terminal blocks:
http://www.amazon.com/gp/product/B00...ilpage_o00_s02
The terminal blocks I already had around from some of the IR repeater work. Spliced the RJ45 into the Emitter cable using the terminal blocks to avoid any solder work and it worked like a charm.
The XPAND emitter that comes in the kit above is identical to the much more pricey one they sell direct from XPAND (AD025-RF-X1) and you get some glasses to boot!
Can read more here: RF glasses and transmitter for the VPL-HW55ES
It was nice to save $150+ dollars on that little item...
Need to get up some pics. Just never seems to be enough time in the day
danielrg is offline
