Jedi Theater (JR) - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 04-29-2012, 09:00 AM - Thread Starter
Ziether's Avatar
I've been working on my Star Wars theater over the last year. This forum has been invaluable in coming up with ideas on how to put it together. I built the theater in a 2nd floor bed room which was a nice space, but smaller than my previous house theater. This time around I wanted a screen wall but posed some difficulties, because I needed to conserve every bit of seating area I could. After looking at some various minimalistic screen walls, my dad and I came up with a screen wall that hid the speakers, but also prevent loss of screen to chair distance.
All right phase one. Paint and carpet. Lost the battle to replace the newer carpet in the room, so I just ended up carpeting the riser and front. I went with a flat Micky Mouse Ears paint for the ceiling and Mick's shadow (Nice gray) for the walls. I had to cover a window, and removed a door to swing outward to make space for the riser
Riser Construction:
Ziether is offline
post #2 of 17 Old 04-29-2012, 09:05 AM - Thread Starter
Ziether's Avatar
Here is the riser that we kind of free formed to fit the space, and allow enough room for the speakers.
Ziether is offline
post #3 of 17 Old 04-29-2012, 09:11 AM - Thread Starter
Ziether's Avatar
Came up with a plan to mount the screen directly to the wall and build the screen wall out to surround the screen. From all the posts advice the recommendation was to build a screen wall with plenty of depth, but I just didn't have the space.
We used Linacoustic RC for the back wall.
Ziether is offline
post #4 of 17 Old 04-29-2012, 09:21 AM - Thread Starter
Ziether's Avatar
At this point I stopped for some time, before proceeding with the screen panels. I ended up going pretty simple using 1x2's, Black GOM, and lots of glue and staples. I used industrial grade velcro to attach the panels. It wasn't until towards the end of framing the front wall that my Dad came up with an idea on how to hide the front speaker. Turned out pretty nice.
I used blue LED rope lights for the front and riser. Not sure I like them yet, hopefully when I install my Grafik Eye, I can tone them down a bit.
Ziether is offline
post #5 of 17 Old 04-29-2012, 09:36 AM - Thread Starter
Ziether's Avatar
I really wanted some other design element and went with the Retro Buck Rogers looking theater I saw online. I spent a huge amount of time on them. The fins didn't come out as clean as I wanted, and the pillars just ended up taking up to much space, so I scrapped them. This is a memorial to them
Ziether is offline
post #6 of 17 Old 04-29-2012, 09:54 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
I like the columns with the fins. Too bad you couldn't find a home for them.
Spaceman is offline
post #7 of 17 Old 04-29-2012, 03:54 PM - Thread Starter
Ziether's Avatar
Here is what things look like today. I still need to replace the door, install Grafik eye controller (4 zones), install 6 recessed lights, finish baseboard moldings.
I have to open issues, one is to block off the closet (Thinking heavy theater curtains), open for thoughts and ideas. Second is the wall space, It needs some type of treatment/design element...any thoughts????
Ziether is offline
post #8 of 17 Old 04-29-2012, 06:02 PM
Chimera2345's Avatar
Looks great, and love the Master Replicas stuff at the back (and the Yoda). Mine will have something similar, along with spaces for a few helmets etc.
Chimera2345 is offline
post #9 of 17 Old 05-28-2012, 11:12 AM - Thread Starter
Ziether's Avatar
Built four simple wall panels, mostly for look, but they should serve as acoustic panels as well.
Almost done now:
Grafik Eye install needed + New door + Lights
Ziether is offline
post #10 of 17 Old 03-16-2013, 02:31 PM - Thread Starter
Ziether's Avatar
Ok, finally done (Except door knob and a couple patches)
Added down lights, and Lutron Grafik Eye, new door, Jedi Theater sign
Ziether is offline
post #11 of 17 Old 03-17-2013, 08:05 AM
willmo's Avatar
Nice
willmo is offline
post #12 of 17 Old 03-17-2013, 08:37 AM
alittletank's Avatar
Liked: 26
I really like your screen wall, it looks great! What size screen is that and what are your room dimensions?
alittletank is offline
post #13 of 17 Old 03-17-2013, 08:55 AM
SKINSnCANES's Avatar
Liked: 25
Do you have any construction pics of you making the panels for the screen wall? Im about to order my fabric and do something similar. Your room looks great!
SKINSnCANES is offline
post #14 of 17 Old 03-17-2013, 11:26 AM - Thread Starter
Ziether's Avatar
Its been a while since I put up the screen, but I believe it was about 110".
I'll see if I can find some photos of the screen wall construction. The small bedroom didn't have enough space to build a deep screen wall, so I had to adlib with what I had.
I'll look back on my drawings for the room size.
Front row is a little to close, so they are my IMAX experience seating. :-)
Ziether is offline
post #15 of 17 Old 03-17-2013, 11:27 AM
Rodrigues_Brazil's Avatar
Quoted: 269 Post(s)
Liked: 18076
Outstanding! Congrats!
Rodrigues_Brazil is offline
post #16 of 17 Old 03-18-2013, 08:12 AM
jedimastergrant's Avatar
Quoted: 546 Post(s)
Liked: 270
I love how the design graphic on the side walls gives the room a 3 dimensional feel. It makes the room look larger too I think.
I dig the custom sign too. How was it made?
jedimastergrant is online now
post #17 of 17 Old 03-18-2013, 06:42 PM - Thread Starter
Ziether's Avatar
Originally the posters on the wall looked kind of plain, so I came up with the pattern on both sides of the frames to give the posters a sense of motion and sci-fi look. I just used some 1/2" MDF, routed the edges and covered it with a heavy black felt that I picked up at Hobby Lobby. I used picture rails to mount them on the wall.
For the sign, I found a free star wars font, by googling it. Then had a local sign shop make and paint the signs using a cheaper sign foam board. Turned out great. Still wasn't super cheap, I think it was about $275.
Ziether is offline
