DIY MADD Sound Door Design - AVS Forum | Home Theater Discussions And Reviews
post #1 of 24 Old 04-30-2012, 09:52 PM - Thread Starter
235
235's Avatar
The door is the weakest link in the soundproofing efforts. I have dual walls but I couldn't sell the dual communicating doors idea to the Mrs. Here's a crazy design I came up with that involves only opening 1 door but still incorporates the 4 pillars of sound isolation:
M- Mass: Total of 2 door slabs and 1/2 MDF
A- Absorption: 3" of pink fiberglass between layers
D- Damping: Layer of green glue
D- Decoupling: Isolation clips and hat channel between layers
Could this work or am I kind of nuts....don't answer that. After some quick math this assembly should be well under 300lbs which is less than some other designs I have seen. It is kind of thick at 6.5" so would certainly need some type of custom handle assembly.
I am doing fabric walls so I would have fabric covering the inner door wrapping around to cover the gap between the inner and outer doors. The outer door would be finished to match the rest of the basement.
Side View:
Bottom View:
235 is offline
post #2 of 24 Old 05-01-2012, 05:17 AM
Dennis Erskine's Avatar
Quoted: 64 Post(s)
Liked: 111
Basically, you've gone to a bunch of trouble to design what is effectively a communicating door. Structurally, that door isn't going to hold up, the latching, hinges, seals will be brutal to get right. Why not just do a communicating door? You can still add mass and Green Glue (except the Green Glue won't be as effective as it can due to the different flex characteristics of the two materials.
....and what is wrong with a 300+ lb door?
Disclosure...we manufacture sound isolation doors. Here's a 350lb door with an 11" plus jamb (to match wall depth at site) ready for crating at our shop. Damping, mass, and seals and it works.
Dennis Erskine CFI, CFII, MEI
Architectural Acoustics
Subject Matter Expert
CEDIA Chairman
www.erskine-group.com
Dennis Erskine is offline
post #3 of 24 Old 05-01-2012, 07:41 AM
aaustin's Avatar
Liked: 36
That door is really cool Dennis!
Just curious what is the thickness?
The Austin Home Theater:
aaustin is offline
post #4 of 24 Old 05-01-2012, 09:20 AM
tbraden32's Avatar
11"?
tbraden32 is offline
post #5 of 24 Old 05-01-2012, 10:50 AM
dwightp's Avatar
So the hinges would be mounted to the inner door, and the outer door would hang off the inner door? A solid core door, like you propose using for the inner door, isn't designed to take that much weight in that plane. You would end up with 1-3/8" of MDF trying to resist the bending forces exerted by the 100-lb weight of the inner door at the end of a 2" lever. Over time, I would expect the inner door to warp significantly. Even a little warpage would play havoc with the seals on both doors, and as the door continued to warp it would become more and more difficult just to get the door to latch.
I have a vague recollection that someone here rigged up a system of two communicating doors that opened and closed as one. Maybe you could play around with that concept.
dwightp is offline
post #6 of 24 Old 05-01-2012, 01:16 PM
Quoted: 64 Post(s)
Liked: 111
They come in two depths .... 1.75" and 2.25". Well, they can be made to any custom depth but there is little need. The jamb was that deep due to the depth of the wall at the door's location.
CEDIA Chairman
post #7 of 24 Old 05-01-2012, 01:18 PM
aaustin's Avatar
Liked: 36
1.75" and 350 lbs! Wow that is dense!
If you don't mind me asking what material are they made of? I don't think something like plywood would get you that kind of weight.
aaustin is offline
post #8 of 24 Old 05-01-2012, 01:27 PM - Thread Starter
235
235's Avatar
Thanks for the explanation Dwight.
Yes the plan was to have one set of hinges on the inner door so that the whole assembly could be opened at once. I can see what you're saying about the shearing forces causing warping to the inner door over time. Do you think there are alternatives to the inner solid core door that would resist warping under those kind of pressures? What about some type of heavier gauge steel door? Since that door will be covered with fabric maybe I can find a cheap industrial one from a salvage shop.
235 is offline
post #9 of 24 Old 05-01-2012, 01:53 PM - Thread Starter
235
235's Avatar
Thanks Dennis. Has any consideration ever been given to what could happen to children's fingers (or adults for that matter) if they ever get caught in any of these very heavy doors . Any reasonable way to mitigate that risk?
235 is offline
post #10 of 24 Old 05-01-2012, 01:56 PM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Close the door slowly
__________________
Ted
The Soundproofing Company
Ted White is offline
post #11 of 24 Old 05-01-2012, 02:09 PM
Quoted: 64 Post(s)
Liked: 111
Yeah, exactly what would happen when they get slammed into a car door.
...you put a catch on the door that stops it from closing until the pin is moved out of the way.
CEDIA Chairman
post #12 of 24 Old 05-01-2012, 02:10 PM
mcascio's Avatar
Quoted: 78 Post(s)
Liked: 125
Put sharp edges and rubbing alcohol all the around the jamb so it does a clean slice of the finger. Keep your sewing kit handy too.
In all seriousness, Lowe's and other big box stores sell products to help heavy door's slow down as they close.
mcascio is offline
post #13 of 24 Old 05-01-2012, 02:14 PM
Quoted: 64 Post(s)
Liked: 111
Ha! In your dreams. "Product of seven years patient research at the University of Padua" --Bertold Brecht
Here's how you find out ... buy one. Get a very powerful table saw (diamond blade is suggested) and cut it up. Would you like to meet our IP attorney?
CEDIA Chairman
post #14 of 24 Old 05-01-2012, 02:27 PM
aaustin's Avatar
Liked: 36
Haha Dennis! Don't worry I understand.
And if I bought one the last thing that I'd want to do is cut it up!
aaustin is offline
post #15 of 24 Old 05-01-2012, 03:16 PM
dwightp's Avatar
I have never seen an off-the-shelf door that would be a good candidate for resisting this kind of shearing force. The steel doors I'm familiar with are thin steel around a foam core -- no help in this situation.
I'm speculating, here, but it seems possible that one could build a torsion box door that would be stiff enough to resist the shear force we're talking about. Here's an image that shows the basic construction of a torsion box:
Building a torsion box to function as a door would require some woodworking skill and tools capable of a fair degree of precision. For sound control purposes, you would have to find a way to fill the voids in the web with mass -- maybe pieces of MDF cut to fit precisely. Overall, a difficult, fiddly job that might or might not yield good results. If you had to pay a woodworker to make one, it would be expensive.
dwightp is offline
post #16 of 24 Old 05-01-2012, 06:06 PM
Mr.Tim's Avatar
Quoted: 281 Post(s)
Liked: 193
I thought about this a bit and had two different ideas.
One, a sheet of 1/2" plate steel green glued between two sheets of 1/2" MDF. You would have to cut the plate narrower and work some magic with the MDF to give yourself some wood to screw into and bore a lockset. That would easily get you the mass. How effective.. I dunno.
Another idea I though about was creating a door filled with sand. Then I thought that would probably be a bad idea.. but it's kinda like the riser idea, only vertical. Glass bead would probably be a better substrate.. but still. I could imagine springing a leak
In the end.. I'm just gonna buy a Jeld-Wen fire-resistance rated door. Not for the fire rating, but the additional mass... and it will match the rest of the doors in my house.
I don't think the OP idea will work, but there are plenty of innovative ideas and I hope we get to try one out!
Tim
Mr.Tim is offline
post #17 of 24 Old 05-01-2012, 06:52 PM
aaustin's Avatar
Liked: 36
I know that jelloslug filled a hollow core door with sand for his home theater.
Edit: Here you go. (Post #54)
http://www.avsforum.com/avs-vb/showt...6#post17476436
aaustin is offline
post #18 of 24 Old 05-01-2012, 10:26 PM - Thread Starter
235
235's Avatar
Thanks for the suggestions everyone. The only major flaw I see at this point is with the probable warping of the inner door caused by having to support the weight (approx 70lbs) of the outer door. Need more stiffness....maybe Pfizer has something . The torsion box idea sounds interesting or maybe replacing the inner door with something like steel?
Has anyone ever designed and built a single door assembly that incorporates decoupling and absorption? It seems to me something like this could rival the performance of communicating doors without the hassle of constantly opening and closing two doors. My goal was to do this in an affordable manner with commonly used construction materials and techniques. Keep the ideas coming, I haven't given up just yet.
235 is offline
post #19 of 24 Old 05-02-2012, 10:30 AM
Tom Bley's Avatar
Quoted: 711 Post(s)
Liked: 641
What's the price for the 1.75 door in a 30" x 80" size? Do the door come complete with everything?
Tom Bley is offline
post #20 of 24 Old 05-02-2012, 10:46 AM
Quoted: 64 Post(s)
Liked: 111
You can PM me. Prices are no no on the forum. The doors are pre-hung with all the seals, threshold, etc. You have to supply your own latch set. They can come pre-finished (stained & sealed, painted) or not as you wish.
CEDIA Chairman
post #21 of 24 Old 10-03-2014, 08:05 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 789
235 what kind of door system did you end up using?
I'm benchmarking other DIY door efforts and curious your results.
I'm working thru my local Home Depot, using a combination of interior solid core door with exterior framing for sealing, a custom job from Milliken Millwork.
The door is being quoted in 36", 42" and 48" width, both traditional solid core and masonite slab core.
(the interior 90 Minute Fire Rated doors use masonite slab, it will be very heavy)
Currently the 6 foot wide opening is great for multi-use, watching sports while playing pool, but now I desire to have my cake and it it too, decent soundproofing for inside listening (quietness) and external lack of noise transmission, plus still wide opening for multi-use.
I've asked them to include in quote appropriate # hinges to handle the weight, their best dual seal system, etc.
http://www.millikenmillwork.com/comm...style=1&config[]=7-3-10&collection=62
I'm also looking at using Ted's door sealing system as alternative to the Milliken seals
http://www.soundproofingcompany.com/...tom-jamb-stop/
Soundproofing Door Jambs and stops are a critical detail in a soundproofing project. Any gap will reduce your soundproofing efforts. SPC’s soundproofing door solutions are high-grade and will effectively seal the gap around your door.
mtbdudex is offline
post #22 of 24 Old 10-04-2014, 07:06 AM - Thread Starter
235
235's Avatar
I ended up 'settling' with an 80 lb solid core door from Lynden doors. I added a layer of Green Glue and 3/4" MDF over top. The 30" wide door ended up weighing 130 lbs. If you go with a 48" door make sure you have some solid framing to screw your hinges into. Here are a few pics of my framing and door construction.
235 is offline
post #23 of 24 Old 10-04-2014, 09:56 AM
mtbdudex's Avatar
Quoted: 79 Post(s)
Liked: 789
Thx, did you use Ted Whites door seals or?
Via Mikes brain/thumb interface, LLAP
mtbdudex is offline
post #24 of 24 Old 10-05-2014, 06:02 PM - Thread Starter
235
235's Avatar
I used the door bottom from Ted. Cut it down and painted. The side/top were wooden ones from Home Depot that I also painted to match. Worked out very well.
235 is offline
