Tennessean Cinema build - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 2Likes
post #91 of 116 Old 01-31-2013, 02:50 PM
warrenP's Avatar
Liked: 60
Originally Posted by hifiaudio2 View Post
These cans:
Very happy with all of them.
The cans do not rattle at all, which is nice, as that would be a big annoyance to diagnose and fix.
Thanks for the links! Do you control the color of the rope lights or does that automatically change?
Every man dies. Not every man really lives.
warrenP is offline
post #92 of 116 Old 01-31-2013, 03:16 PM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
They can change automatically at a set interval, I can pick a specific constant color from the remote, make my own "custom" color, or they can change to the beat of the music. Its a rave in a box. smile.gif
Pretty fun little kit. I bought more than just what is on the link below but that is the main unit. I have the circuit that these are plugged into wired to a Lutron RadioRa2 switch so I can turn it on and off with the main Lutron keypad by my door or my Roomie remote on the Ipad. For now I just use the remote that came with it to control the light. Someday I might get the Roomie IR control add on so I can put these into Roomie as well, but I kind of doubt I will take it that far.
http://www.ledwholesalers.com/store/index.php?act=viewProd&productId=834
hifiaudio2 is offline
post #93 of 116 Old 02-20-2013, 03:15 PM
sportsfan14's Avatar
One thing I can say I am really liking are the "in soffit" Triad LCR surrounds that Dennis suggested. So far with surround music they totally disappear but have GREAT ambiance. If I am facing the screen I hear things all around, but if I turn my head to look at where I know the speaker is, I no longer hear anything coming from it. Not localized or pointed out at all, yet not a diffuse dipole. Very cool.
Point of clarification?
As far as I'm aware, Triad doesn't make a "LCR surround"
Are you talking about the Triad InWall Bronze LCR?
http://triadspeakers.com/products/iwb4lcr.html
Or the Triad InWall Bronze Surrounds?
http://triadspeakers.com/products/iwb4sur.html
And were these 4 place in ceiling or in walls?
Thanks, much appreciated. Envious of the HT.
sportsfan14 is offline
post #94 of 116 Old 02-20-2013, 03:46 PM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
Here is the speaker:
http://triadspeakers.com/products/icb8lcr.html
They are in my soffits with the speaker face pointing toward the floor. The drivers are angled, though, so they shoot toward the listening position.
post #95 of 116 Old 02-21-2013, 12:02 PM
Thanks very much.
Curious why you chose direct over dipole for surrounds? I am struggling with this myself. (leaning toward direct).
Triad was a pioneer at angled baffle, and I'm sure the inCeling LCR sounds like not from whence it came.
post #96 of 116 Old 02-21-2013, 01:46 PM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
The short answer is because Dennis specified them. I assume it has to do with the fact that I have a bit of space on each side and putting them in the soffit also gets them further away from all listeners, even those close to that side. I am sure Dennis can expound on this if he notices the question and has time.
post #97 of 116 Old 06-15-2013, 06:21 PM
johnrm321's Avatar
johnrm321 is offline
post #98 of 116 Old 08-02-2013, 06:57 PM
SKINSnCANES's Avatar
Liked: 25
have you put handles on the door yet? im curious how you did it. Im debating making my own thick door as well
SKINSnCANES is offline
post #99 of 116 Old 08-03-2013, 03:32 PM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
Yeah I just ended up going with a pretty normal black knob. Just got a 5 inch extension for the inner cylinder piece so it would fit the thick door.
post #100 of 116 Old 08-03-2013, 08:51 PM
jedimastergrant's Avatar
Quoted: 660 Post(s)
Liked: 412
Was the extension piece something that you bought as an accessory from the manufacturer or did you make your own? I saw in your thread that you purchased a set from Emtek. I have seen sets for up to a 3'' door but not a 5'' door like yours. Those sets are at least $100 and I have 2 doors so that might get pricey.
I had considered buying a normal 1 3/4 set and splicing in an extension myself. I am not sure what kind of metal rod I would need to do that yet. But, it should be able to be welded in as far as I know. I have seen a thread here in which it was done.
Really interested in what others have done so I can come to an affordable solution.
jedimastergrant is offline
post #101 of 116 Old 08-04-2013, 08:12 AM
Mfusick's Avatar
Quoted: 608 Post(s)
Liked: 2696
Mfusick is offline
post #102 of 116 Old 08-04-2013, 07:17 PM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
My door is slightly over 3" thick total, the extension piece I got was around 5", I believe, to go into the handles on each end. It ended up that my neighbor owns the hardware store down the street from me that I ordered the knob for. He also ordered the long piece for me, separately, from Emtek. I dont even recall what that part is called.
Here is the knob I got... pretty boring and standard, but well made and nice... I got the flat black finish.
http://emtek.com/Passage-Privacy-Knobs/providence-knob
post #103 of 116 Old 08-04-2013, 07:18 PM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
I will try to get a few more pics up sometime soon. I STILL have not purchased the 7 Fusion chairs, so I only have three. I was waiting until I get them all to post "final" pics.
post #104 of 116 Old 02-19-2014, 10:43 AM
BrolicBeast's Avatar
Quoted: 1288 Post(s)
Liked: 1381
W
I got most of the drywall off and hauled away, and construction on turning the stairwell that comes down into the back of the room has started. We are turning it 180 degrees and building a wall along the back. We ran into a headroom issue with that new stairwell, so unfortunately that means I will have to move the back wall of the theater in a few inches to give enough room for an adequately sized landing on that stairwell. But the room should still be around 27' long (a little less after clips and DD). Dennis says the length reduction should not affect my acoustic plan nor will the slight size reduction of the riser affect the bass trap riser.
I will also be adding a new LVL to the ceiling so I can decouple it from the floor joists above. Currently the ceiling is 2x6 and has multiple 2x4's coupled to the above floor joists for support.
Even then though, we MAY have to install 2x8s for the ceiling due to the span. Its about 15.5 feet and the feeling is that that may be too long for 2x6 joists.
Hopefully all these items will be finished at the end of this week.
Was turning the stairs an expensive project? Would you mind PMing me with the costs? I wouldn't mind turning my stairs to generate a bit more room at the rear.
BrolicBeast is online now
post #105 of 116 Old 02-19-2014, 10:54 AM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
Well I can't really say because it was just one of the many things done by the handyman /men that did some of the work for me. Main issue was dealing with the ceiling height once the stairs turned back on themselves and making sure one wouldn't hit their head.
The finished stairs turned out nicely, though.
post #106 of 116 Old 04-11-2014, 07:50 AM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
We are putting the theater on the market and the house comes with it. smile.gif Come buy my place!
post #107 of 116 Old 04-11-2014, 08:57 AM
COACH2369's Avatar
Quoted: 910 Post(s)
Liked: 736
Wish I was in the market....great theater and the house would be a nice bonus.
COACH2369 is online now
post #108 of 116 Old 10-24-2014, 07:33 PM
Liked: 0
I am in the process off building my theater. Have some questions on the walls. Did you cover all the walls with fabric? If you did, how did you go about doing it? Thanks
rajkwarrier is offline
post #109 of 116 Old 10-25-2014, 09:00 AM
audiovideoholic's Avatar
Quoted: 654 Post(s)
Liked: 215
Search fabric track systems. That is the easiest way but also the most costly. Many theaters just use ripped pine that is deep enough to house the panels and use staples. There are many builds in this section with fabric panel walls. A search in this section will also provide many detailed pictures of builds.
Welcome to the forums!
audiovideoholic is offline
post #110 of 116 Old 01-27-2015, 01:05 PM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
Hey sorry I should have answered this a long time ago. AudioVideoholic is right, though. You can use fabrictrack with costs a few bucks a linear foot for the most "refined" install, or just use ripped studs and staple around the edges. In mine I used fabrictrack. Its pretty much one long piece for the upper and lower edges (where the soffit meets the wall on the upper and where the chair rail is on the lower) and then one vertical fabrictrack piece wherever I had to make a break (for the door and where the walls meet).
post #111 of 116 Old 03-11-2015, 09:29 PM
txmxer's Avatar
Quoted: 20 Post(s)
wow! you have a gift. its the meld between style and substance.
I'm an engineer (typical engineer you might say).
To pull together a build like this is very special. I know you had guidance, but the gift is in pulling it all together.
Thanks for sharing and I look forward to vault 2.0.
txmxer is offline
post #112 of 116 Old 03-12-2015, 09:06 AM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
post #113 of 116 Old 03-28-2015, 03:32 PM
Frank D's Avatar
Quoted: 325 Post(s)
Liked: 86
Hi,
Very amazing room!
You mentioned in the DIRAC Full XMC-1 thread that your room is quite dead. What treatments do you have and where?
Also I believe you went with sealed subs right? Did you consider ported at all and if yes why did you pick sealed over ported?
Frank D is offline
post #114 of 116 Old 03-28-2015, 03:59 PM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
Some of my subs are in alcoves so there would be minimal room for the port to breathe if they were not front ported if I went that route. But I dont really even know if that matters. Really I went with sealed because that is what Seaton sells and they are incredible and somewhat of the gold standard in subs!
I have Quest treatments all over the room. Locations and which treatments were designed by Dennis.
post #115 of 116 Old 10-18-2015, 08:16 PM
jumarapol's Avatar
Quoted: 46 Post(s)
Liked: 53
What's your viewing distance from the first row? I have a room of 22x17 and am looking into 150 ft wide screen but im not sure if 160 ft is a little bit of a stretch. I have 12-13 ft viewing distance?
jumarapol is offline
post #116 of 116 Old 10-19-2015, 11:20 AM - Thread Starter
hifiaudio2's Avatar
Quoted: 422 Post(s)
Liked: 113
I'd have to measure, but it is between 12-13 feet. I LOVE it. It's perfect imo.
