The SuperNoVA Theater - Planning & Build - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 172 Old 12-13-2013, 08:19 AM - Thread Starter
ozziegt's Avatar
You hit the nail on the head...he has too much time on his hands and he overcomplicates things. I have had to reel him in many times when he has been helping me with this project. smile.gif The thing is he overcomplicates stuff which is really simple but the stuff which needs extra time and attention to detail he wants to gloss over. Story of his life.
Anyway, yeah he has had bad experience with tapcons and says grouted bolts are how heavy machinery is secured in concrete. I don't really have the knowledge to argue with him so if it will work I'll just let him do it I suppose. I doubt he has any kind of special technique, is just going to drill a hole, put in a bolt and fill with grout.
My approach here might be that unless we can get our hands on some anchor bolt grout, we should probably stick with tapcons. Or at least try a tapcon and see how strong it is.
ozziegt is offline
post #152 of 172 Old 03-20-2014, 06:05 PM - Thread Starter
ozziegt's Avatar
So after quite a hiatus I am back on this. What do you guys think about 5.1 vs 7.1? A couple of people have told me the theater isn't really large enough to need a 7.1 set up. If I do 5.1 I can put up some sconces, if I do 7.1 I am going to avoid the sconces...so it has an impact on the wiring I am doing for the lighting.
Also what is the best strategy for roughing in recessed lights for inspection? I am going to do backer boxes so I don't want to buy new work lights since the backer boxes use old work lights.
ozziegt is offline
post #153 of 172 Old 03-20-2014, 07:29 PM
Quoted: 1222 Post(s)
Liked: 1107
Are you planning on having the clips and channel up for the inspection? if yes, go ahead and hang the boxes and leave a coil of wire in each box. You may need to explain what your are doing and be convincing when you describe it. I've had plenty of dangling wires pass inspection.
BIGmouthinDC is online now
post #154 of 172 Old 03-20-2014, 08:11 PM - Thread Starter
ozziegt's Avatar
I wasn't planning on having clips & channel up, as I would have to take them down again to install insulation. Would it be better to have them up?
ozziegt is offline
post #155 of 172 Old 03-20-2014, 08:25 PM
Liked: 1107
no, it raises more questions. How were you planning on hanging your backer boxes?
Lets assume no boxes, you can try just hanging coils of Romex in the appropriate locations and explain your plans to the inspector. I have done this in the past and it passed. Can't guarantee yours will. If all the rest of your electrical rough in looks neat and to code he will assume you know what you are doing. If he has a bad feeling he may want more evidence that you can do it correctly. Everything needs to be secured/supported and not prone to being pieced by screws, Grounds need to be bonded in the electrical boxes (twisted with crimp connectors) .
post #156 of 172 Old 03-21-2014, 11:18 AM - Thread Starter
ozziegt's Avatar
Hmm, good point. I guess I could put up the channel just where the backer boxes will be.
ozziegt is offline
post #157 of 172 Old 05-14-2014, 01:16 PM - Thread Starter
ozziegt's Avatar
Big, how did you like the QuietBox that you used in one of your recent builds? I am thinking for $40 each, it's a lot easier than building my own. I will probably need 6.
ozziegt is offline
post #158 of 172 Old 05-14-2014, 01:48 PM
Liked: 1107
I hate building backer boxes and with my time and materials it is probably a wash to my clients. A couple arrived damaged and they shipped replacements. I do prefer a wider bottom edge but you can easily tack one on. Lastly you need to consider if the size fixtures you want will fit, I prefer remodel cans for ease of drywall installation and only the smallest fit in those boxes.
post #159 of 172 Old 05-15-2014, 04:59 AM
kmhvball's Avatar
Quoted: 207 Post(s)
Liked: 89
Hello,
Post #27 in my 'build' is an idea I plan to use which I hope to be lower cost & less effort than a traditional backer box.   To be fair, I haven't yet done it - so, can't speak from experience, but it is definitely my plan.  My inexperienced 'logical' (although maybe faulty) thinking is that this should be at least no worse sound reduction than a comparable Backer Box.
http://www.avsforum.com/t/1524856/hall-o-cinema-theater-construction-design-questions
After some feedback expressing some slight concern about using MDF as the base layers, I may reconfigure and use either Fire rated drywall and/or cement board for the assembly vs MDF.   Edit... I have decided that my 'very back' layer will be the 3/4"MDF,  the next layer (still solid other than wire hole) will be 5/8" fire rated drywall, then the 'layer' with the drilled out circle will be two sheets of 3/8" Fire Rated Drywall.   Then the two 'in room' 5/8" layers of drywall.
The actual light I plan to use  is probably both a 4" & 6" version of this, I am planning to use the 90 CRI (color render index) version vs the 80.  In another thread, I think Cinemar, the lights used were 'warmer' (2700 vs these at 3000) and they had a 90 CRI:
Halo SLD405830WH 4" Surface LED Downlight
Pasted from <http://www.readywholesaleelectric.com/hasl4suleddo.html>
The one I purchased to 'test' I bought from Menard's, and have never purchased from the above place - but they appeared to have the best price in the 10 minutes I looked.
Kevin
kmhvball is offline
post #160 of 172 Old 05-19-2014, 08:05 PM - Thread Starter
ozziegt's Avatar
It looks like these 6" cans will fit in the quiet box. Just leaving this link here so I don't lose it. Either these or some 4" cans.
ozziegt is offline
post #161 of 172 Old 05-19-2014, 08:31 PM
Liked: 1107
That 6 inch can will just barely fit. you need to be really accurate in your meausurement.
post #162 of 172 Old 05-20-2014, 02:19 PM - Thread Starter
ozziegt's Avatar
Yeah, I will definitely get a QuietBox and measure both the box and the can before buying the cans. If the can is 7.5" high, and the box is 8" high, there should be over an inch of clearance once you include the drywall and a wider flange around the base of the quietbox. It would be much simpler if I just went with 4" lights. 4" LED lights have about 50 watts effective output, which should be enough if I use 6 of them in my theater. I am just concerned that it might not have enough spread. Have you used 4" can lights?
ozziegt is offline
post #163 of 172 Old 05-20-2014, 05:56 PM
Liked: 1107
all the time. But I would want more than just 6 in the ceiling. I would do screen wash and some perimeter soffit down lights.
post #164 of 172 Old 05-21-2014, 07:52 AM - Thread Starter
ozziegt's Avatar
Those are just accent lights, right? Based on the square footage of the room, the space needs about 350W of lighting. The accent lights are also not going in the ceiling so I don't need quietboxes for those.
ozziegt is offline
post #165 of 172 Old 05-21-2014, 10:51 AM
Liked: 1107
Bacon Race is lit entirely with perimeter "accent lights", no ceiling lights
post #166 of 172 Old 05-22-2014, 11:38 AM - Thread Starter
ozziegt's Avatar
Yeah I know you built quite a few theaters only with soffit lighting. What I mean is that if I have 350W of recessed lighting, any additional lighting is purely for aesthetics.
ozziegt is offline
post #167 of 172 Old 05-22-2014, 12:40 PM
24Changer's Avatar
Quoted: 86 Post(s)
Liked: 101
ozziegt, would you be willing to share the link on the QuietBox? If Big hates to build backer boxes then so do I.
Creekside Stone Cinema
24Changer is offline
post #168 of 172 Old 05-22-2014, 03:15 PM
24Changer's Avatar
Quoted: 86 Post(s)
Liked: 101
I believe I found the link in another post ~ thanks
http://soundisolationstore.com/shop/product/quietbox-recessed-light-soundproofing/?gclid=CPDohcyA_LsCFYZi7AodexcAxg
post #169 of 172 Old 05-23-2014, 06:48 AM - Thread Starter
ozziegt's Avatar
ozziegt is offline
post #170 of 172 Old 09-21-2014, 02:05 PM - Thread Starter
ozziegt's Avatar
This project has been on the far back burner since my son was born, but now I am finally getting time to work on it again. Any suggestions on how to do the fireblocking while maintaining sound isolation?
ozziegt is offline
post #171 of 172 Old 09-21-2014, 03:19 PM
Liked: 1107
moderately stuff the gaps with mineral wool (roxul insulation) some inspectors will say "fine".
post #172 of 172 Old 12-16-2014, 11:47 AM - Thread Starter
ozziegt's Avatar
So, just hear about this Dolby Atmos thing. Speakers in the ceiling? I have absolutely now idea how to plan for this now before I get the walls up. I already have surround speakers and they aren't Atmos capable, and if I install speakers in the ceiling I am going to be messing with the soundproofing. I am not sure I even want to go to the Atmos route now but I want to be prepared to do it later when Atmos movies are more widely available.
Edit: It looks like there will the possibility of addon Atmos speakers which can be placed above the front speakers to reflect off the ceiling. Pretty easy, just gotta make sure I have an extra pair of speaker wires going to the front speakers.
ozziegt is offline
