Thermostat For Projector Hushbox - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 05-20-2012, 01:03 PM - Thread Starter
suffolk112000's Avatar
Hi all,
I have a dedicated room and would like to add a thermostat to my projector hushbox so that when the heat buildup reaches a certain temp, say 85 degrees, it will kick on the cooling fan.
I know its been done before, any idea's, equipment you used would be appreciated.
Domino's donÂt fall all at once, they fall one at a time...
suffolk112000 is offline
post #2 of 6 Old 05-20-2012, 01:30 PM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 778
Coolcomponents has an inexpensive fixed-temp (80 or 88F) solution for their cabinet fan products:
http://www.coolcomponents.com/Basic-...nly_p_311.html
There are others with similar solutions - check Active Thermal Management and Cooler Guys as well...
http://www.coolerguys.com/
http://www.activethermal.com/
Jeff
jautor is online now
post #3 of 6 Old 05-20-2012, 02:17 PM
chinadog's Avatar
Quoted: 21 Post(s)
Liked: 85
I used an attic fan thermostat for the box found at HD and a Nutone inline fan, similar to this one:
http://www.unitron-online.com/nutone...haust-fan.aspx
Bud
chinadog is offline
post #4 of 6 Old 09-03-2012, 01:28 PM
cdika17's Avatar
Liked: 27
I have a Panasonic whisper-ceiling FV-11VQ5 i plan to use in my storage room above my racks, what temp controller should i use?
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #5 of 6 Old 09-03-2012, 02:50 PM
Quoted: 3258 Post(s)
Liked: 2744
attic fan line voltage thermostat. $20
post #6 of 6 Old 09-03-2012, 06:05 PM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 180
If you want secksy:
Middle Atlantic Therm-A:
(as with all things Middle Atlantic, it comes with a matching price tag)
Tim
Mr.Tim is offline
