Need help urgently lost sound - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 05-23-2012, 11:31 PM - Thread Starter
Bryceo's Avatar
I have lost sound in my left channel any idear why that's happend?
Bryceo is offline
post #2 of 18 Old 05-24-2012, 02:27 AM
audiovideoholic's Avatar
Quoted: 588 Post(s)
Liked: 186
Trouble shoot man.
Try hooking that speaker up to a different channel first.
Then trace every other step after that. Then post back.
audiovideoholic is offline
post #3 of 18 Old 05-24-2012, 03:03 AM - Thread Starter
Bryceo's Avatar
I did that it worked fine changed the Cabbles and it still didn't work
Bryceo is offline
post #4 of 18 Old 05-24-2012, 03:06 AM
vzphoneman's Avatar
Quoted: 82 Post(s)
Liked: 78
does it do it on all sources?
The lazy man finds the easiest way ... Ben Franklin
Rouge Audio Cronus Magnum II integrated amp, Goldenear Technology's Triton 2+ speakers, Schiit Bifrost Multibit Dac, Technics SL-1200MK2 turntable with Audio Technica 440ml cartridge, Teac X-1000R reel to reel, custom computer as main music source
vzphoneman is online now
post #5 of 18 Old 05-24-2012, 03:08 AM - Thread Starter
Bryceo's Avatar
Yes it does
Bryceo is offline
post #6 of 18 Old 05-24-2012, 03:12 AM
Quoted: 588 Post(s)
Liked: 186
Doesnt sound good.
Have you ran a pink noise test? If that channel fails to play the test on any of the speakers then sounds like a bad channel on the AVR
post #7 of 18 Old 05-24-2012, 03:14 AM - Thread Starter
Bryceo's Avatar
I did run that's test and all the channels worked fine it's just the left side isn't picking up any input from optical RCA or hdmi
Bryceo is offline
post #8 of 18 Old 05-24-2012, 03:15 AM
Quoted: 588 Post(s)
Liked: 186
So it plays when run the test?
post #9 of 18 Old 05-24-2012, 03:17 AM - Thread Starter
Bryceo's Avatar
Yeh, witch is Probley a god save in its self, just dosnt get signal
From any other channels or input selectors
Bryceo is offline
post #10 of 18 Old 05-24-2012, 03:24 AM - Thread Starter
Bryceo's Avatar
It's being difficult it now will not play the test tone out of the left channel
Bryceo is offline
post #11 of 18 Old 05-24-2012, 03:37 AM
Quoted: 588 Post(s)
Liked: 186
If it wont play a test tone I would think that something caused that channel to go bad. Most AVRs carry a 1 yr warranty at minimum so I would take it back to where you bought it and go from there.
post #12 of 18 Old 05-24-2012, 03:43 AM - Thread Starter
Bryceo's Avatar
I've hadmy reciver for a lot longer then one year is there any way I can have a Play with out destroying the amp completely
Bryceo is offline
post #13 of 18 Old 05-24-2012, 04:09 AM - Thread Starter
Bryceo's Avatar
Can I buy pass that channel with another reciver?
Bryceo is offline
post #14 of 18 Old 05-24-2012, 05:34 AM
Quoted: 3255 Post(s)
Liked: 2743
Depends on what receiver(s) you have. I use my receiver as a pre-amp only taking the signals to a separate amp. If your receiver in question has direct RCA plug inputs for all channels you can probably take the pre-amp outputs from one receiver and use the analog inputs of the second. You never told us if your diagnostic included swapping speakers around Left for Right.
If the the left channel amp in the receiver in question is bad your piggy back arrangement won't help.
post #15 of 18 Old 05-24-2012, 10:24 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
This doesn't sound like a question that would be asked by someone familiar with pink noise. I smell post count building.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #16 of 18 Old 05-24-2012, 10:53 AM
jautor's Avatar
Quoted: 1216 Post(s)
Liked: 777
First 83 posts in 11 days, ya think???
jautor is offline
post #17 of 18 Old 05-24-2012, 06:00 PM - Thread Starter
Bryceo's Avatar
No that's an asumpshion witch I don't appriceate, I've tried a few diffrent things for this and it will not pick up a signal in any of the inputs only on the left side, I swapped the left speaker over with the right speaker and the left speaker that was plugged in to the right channels worked the right speaker in the left channel did not work, how's that any idears as to why this happens I did nothing diffrent I put a movie on and all the sound was coming from the right side..
Bryceo is offline
post #18 of 18 Old 05-25-2012, 08:35 AM - Thread Starter
Bryceo's Avatar
So I had my local tech come out today, and he was hear
For about 40 45 minutes and he pulled the casing off had a fiddle and it come back online all channels working again left channel fixed, it went offline due to a fault it the soldering from the factory
Bryceo is offline
