Proper way to install a star ceiling? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 05-24-2012, 03:15 PM - Thread Starter
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
I am still contemplating a FOSI star ceiling, but dont fully understand if the finished proper method of install creates a triple leaf.
I would have clips, channel, DD+GG on the ceiling. Does the fiber panel (assuming a pre-made one with the fibers already connected) go on as the last layer? If so, my understanding is that it needs a furring strip on the ceiling to offset and give room for the fibers. Does this create a triple leaf effect?
So the finished ceiling would be clips, channel, drywall, furring strips (air gap), FOSI panel?
Or do you have to order the DIY kit if you want a soundproof ceiling, so you can route all the fibers through both the drywall/GG and the OSB? That seems to me the only way to keep from creating a triple leaf... but I am not sure I can stomach all that work..... and obviously GG would get on the fibers this way..guess it can be cleaned....
I am probably missing something...please enlighten me.
hifiaudio2 is offline
post #2 of 7 Old 05-26-2012, 10:24 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
Good question...Ted?
I assume not a problem because the star ceiling is not "sealed" around the ceiling???
Larry M is offline
post #3 of 7 Old 05-27-2012, 11:13 AM
stockmonkey2000's Avatar
Liked: 29
I did not worry about any triple leaf effect on my ceiling. I wanted a star ceiling and there is no practical way not to have a gap for the fibers. I have a triple layer sandwich of OSB-GG-DW-GG-DW and am very pleased with the results. I think the additional layer of the star ceiling only made the soundproofing better. My suggestion would be to have 2 layers of drywall or a layer of OSB and drywall (its really nice to be able to screw the star ceiling in anywhere) and do the star ceiling over that with a 3/4" gap for the fibers.
stockmonkey2000 is offline
post #4 of 7 Old 05-28-2012, 01:08 PM - Thread Starter
hifiaudio2's Avatar
Quoted: 363 Post(s)
Liked: 110
Is substituting a layer of OSB for the first layer of drywall pretty much a necessity for a star ceiling?
post #5 of 7 Old 05-28-2012, 03:04 PM
Larry M's Avatar
Quoted: 29 Post(s)
Liked: 45
I'm going that route but I don't believe it is a necessity. It just makes things a lot easier not having to look for a joist
Larry M is offline
post #6 of 7 Old 05-28-2012, 11:02 PM
jcs2000's Avatar
I am also considering a FOSI star ceiling
Looking for feedback from members who have purchased
Looking at a 8x10 size using two of the standard 4x10 panels
jcs2000 is offline
post #7 of 7 Old 05-29-2012, 09:37 AM
Liked: 29
Not a necessity but I was very glad I had the OSB.
