#### The ULTIMATE Bass Demo Disc #### - Page 28 - AVS Forum | Home Theater Discussions And Reviews
 142Likes
post #811 of 1330 Old 03-30-2014, 05:49 PM
gskinusa's Avatar
Quoted: 76 Post(s)
Liked: 32
Originally Posted by bori View Post
How long did it take to make it a mkv?
As I had the ISO on the NAS and and my Mac was connected through wifi, it took me close to 2.5hrs / disc. If I had the iso in the mac and run the MakeMKV process I think it would have been faster.
HT Setup: http://www.avsforum.com/t/1520044/ou...ts-of-pictures
For Sale:
Nothing at this time.
gskinusa is offline
post #812 of 1330 Old 03-30-2014, 06:09 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
So u took all 45gb and converted to mkv? Or did u select some of the file? Also do u still get the HD Audio?
bori is offline
post #813 of 1330 Old 03-30-2014, 06:45 PM
gskinusa's Avatar
Quoted: 76 Post(s)
Liked: 32
Yes I converted the entire 45gb in to MKVs. Basically had the entire iso selected in MakeMKV and it will spit out each clip as individual MKVs. Yes I do have hi-def audio.
bori likes this.
For Sale:
gskinusa is offline
post #814 of 1330 Old 03-30-2014, 06:46 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
Thanks for the help
bori is offline
post #815 of 1330 Old 03-31-2014, 12:27 PM
shpitz's Avatar
Quoted: 72 Post(s)
Liked: 57
Originally Posted by LowBudget5.1 View Post
Too bad I can't get it to run on my media server over wifi. I get a max throughput of about 45 mbits/s and that definitely isn't enough. Need to drop a ethernet jack to my HT cabinet.
If ethernet is not an option, and you have a COAX outlet near the server, you can try a MoCA adapter or a DECA adapter that will give you a solid 100mbit over coax.
LowBudget5.1 likes this.
shpitz is offline
post #816 of 1330 Old 03-31-2014, 10:57 PM
CrazyNurse's Avatar
Liked: 42
Please seed Volume 2 if you get a chance, anyone.
Panasonic TC-P60ZT60, Denon 3311CI, Oppo BDP-93, Emotiva XPA-5, Definitive Mythos ST, Mythos 8, Gem XL, SVS SB-13 Ultra
CrazyNurse is offline
post #817 of 1330 Old 03-31-2014, 10:58 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
I will seed when I get home
bori is offline
post #818 of 1330 Old 04-01-2014, 02:36 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
Seeding now
CrazyNurse likes this.
bori is offline
post #819 of 1330 Old 04-01-2014, 02:39 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
Cant burn the ISO with imgburn keep getting error.
bori is offline
post #820 of 1330 Old 04-01-2014, 07:30 AM
LastButNotLeast's Avatar
Quoted: 1793 Post(s)
Liked: 1404
Try formatting the disc. Yes, it will take forever. Take a long lunch.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
Don't guess, measure: Getting Started With REW: A Step-by-Step Guide
LastButNotLeast is offline
post #821 of 1330 Old 04-01-2014, 07:33 AM
shpitz's Avatar
Quoted: 72 Post(s)
Liked: 57
I see you're on latest firmware for the burner. Does it even start burning then fails? or fails while doing initializations?
Got latest imgburn?
Searching for the error you got leads to this: http://forum.imgburn.com/index.php?/topic/18606-power-calibration-area-error/
...and from there to this: http://forum.imgburn.com/index.php?showtopic=8000
Try with other blank media.
shpitz is offline
post #822 of 1330 Old 04-01-2014, 09:08 AM
shpitz's Avatar
Quoted: 72 Post(s)
Liked: 57
Do you know if he's trying a BD-RE disc? if yes, it's re-writable and can be formatted. If he's using a BD-R (write-once) then formatting is not an option.
Bori, you can also try to burn at lower speed. What speed are you discs rated?
shpitz is offline
post #823 of 1330 Old 04-01-2014, 09:14 AM
CrazyNurse's Avatar
Liked: 42
Seeding now
Thanks, bori.
Volume 1 is almost done.
I just left my computer on and hopefully it will be done when I get home from work today.
post #824 of 1330 Old 04-01-2014, 10:03 AM
Liked: 1404
His error message shows BD-RE.
Any luck yet, bori?
post #825 of 1330 Old 04-01-2014, 10:34 AM
megdagooch's Avatar
Quoted: 22 Post(s)
Liked: 38
We are seeding vol 2 ....maybe vol 1 by now smile.gif looks like 4 people seeding. Get Em while the getting is good smile.gif
megdagooch is offline
post #826 of 1330 Old 04-01-2014, 11:46 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
Any luck yet, bori?
No. Will try formating
bori is offline
post #827 of 1330 Old 04-01-2014, 11:59 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
My disc say they are Bd-r
bori is offline
post #828 of 1330 Old 04-01-2014, 01:09 PM
Liked: 1404
Then please DON'T format them.
:eek:
:D
post #829 of 1330 Old 04-01-2014, 01:23 PM
shpitz's Avatar
Quoted: 72 Post(s)
Liked: 57
That's the name of the burner under Windows, not necessarily the disc type he used smile.gif
EDIT: and he stated above he used a BD-R...
Try burning at lower speed, if doesn't work either, get a decent brand (Verbatim is usually good quality).
shpitz is offline
post #830 of 1330 Old 04-03-2014, 01:10 AM
LowBudget5.1's Avatar
Just wanted to say thanks for the tip. I bought a Actiontec ECB2500C and plugged it into my Sony BDP-BX510 using a CAT6 cable. It now streams seamlessly from my media server. It's literally plug and play with the FiOS router.
LowBudget5.1 is offline
post #831 of 1330 Old 04-03-2014, 09:12 AM
shpitz's Avatar
Quoted: 72 Post(s)
Liked: 57
Oh yeah, very easy and smooth. The nice thing about MoCA (Actiontec in this case) is that is plays well with cable/Fios, while DECA is made for satellite tv and therefore operates at cable frequencies which prevent you from using DECA in coax lines that need to be used for cable.
Keep in mine that current MoCA v1 is good for 100mbit, v2 (which is still in the works, and some say it will be available commercially, as in non-residential, only in the beginning) should be good for gigabit.
shpitz is offline
post #832 of 1330 Old 04-03-2014, 09:34 AM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
Getting some new disc today to see if that was the issue with imgburn.
bori is offline
post #833 of 1330 Old 04-03-2014, 09:59 AM
superleo's Avatar
Quoted: 83 Post(s)
Liked: 312
I'm surprised LastButNotLeast (Michael) has not come to remind us all -- BUY at least one BD-RE tongue.gif
I would have to agree, $15 well spent. Test your burn, then BURN.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
post #834 of 1330 Old 04-03-2014, 10:03 AM
Liked: 1404
Actually, I just bought more. I was surprised at how much the price has dropped over time:
http://www.amazon.com/gp/product/B0056DUNLW/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
They haven't arrived yet, so I can't swear for them, but, yes, it's still a strong recommendation.
Michael
post #835 of 1330 Old 04-03-2014, 11:20 AM
CrazyNurse's Avatar
Liked: 42
I recently used these with imgburn to burn both volumes:
http://www.amazon.com/gp/product/B0056DV0L4/ref=oh_details_o01_s00_i00?ie=UTF8&psc=1
No problems whatsoever on my internal LG BD-RE.
Thanks everyone for seeding and for the OP for putting these discs together. They're awesome!
post #836 of 1330 Old 04-03-2014, 01:38 PM
bori's Avatar
Quoted: 194 Post(s)
Liked: 126
Got the verbatim today disc burning so far with imgburn. U guys were right it was the cheap disc.
bori is offline
post #837 of 1330 Old 04-03-2014, 01:53 PM
shpitz's Avatar
Quoted: 72 Post(s)
Liked: 57
Haha, nice! It's very hard to determine the quality of discs, only way is to do research in forums and read reviews. Even for the same brand, some discs are great and some are not.
Can't stand optical media myself, I rather buy HDDs...
shpitz is offline
post #838 of 1330 Old 04-03-2014, 02:01 PM
RJW1966's Avatar
I have the torrent file downloaded and am presently seeding. Question: is there a way to burn the iso to BD-R without having a BD burner? My laptop has a BD player but it will only burn standard DVDs. Am I stuck buying an external USB BD burner?
RJW1966 is offline
post #839 of 1330 Old 04-03-2014, 02:08 PM
CrazyNurse's Avatar
Liked: 42
Yeah, you need a BD-R.
Even so, you'll need DL discs unless you convert the ISOs or remove clips.
DL discs are 50GB.
post #840 of 1330 Old 04-03-2014, 02:38 PM
RJW1966's Avatar
Yeah, I have the correct 50GB discs. Guess I have to order the external burner.
RJW1966 is offline
Blu Ray Movies , Black Hawk Down Blu Ray , Inception Two Disc Edition Blu Ray , Master And Commander The Far Side Of The World Blu Ray , Iron Man Blu Ray , Irobot , Live Free Or Die Hard Blu Ray , Cloverfield Blu Ray , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Flight Of The Phoenix Blu Ray , Terminator Salvation Two Disc Directors Cut Blu Ray , The Incredible Hulk Blu Ray , Transformers Blu Ray , The Dark Knight Bd Live Blu Ray , Jurassic Park Ultimate Trilogy Blu Ray Digital Copy , Tron Legacy Two Disc Blu Ray Dvd Combo
