#### The ULTIMATE Bass Demo Disc #### - Page 29 - AVS Forum | Home Theater Discussions And Reviews
 124Likes
post #841 of 1308 Old 04-03-2014, 04:08 PM
nickbuol's Avatar
Quoted: 553 Post(s)
Liked: 613
Originally Posted by LastButNotLeast View Post
Actually, I just bought more. I was surprised at how much the price has dropped over time:
http://www.amazon.com/gp/product/B0056DUNLW/ref=oh_details_o02_s00_i00?ie=UTF8&psc=1
They haven't arrived yet, so I can't swear for them, but, yes, it's still a strong recommendation.
Michael
Wow that IS cheap.
I stopped burning to disc once I got my media server set up. I made .ISOs of everything and then the rare times that I want to watch one, I mount the .ISO on my HTPC and play it. Works well. Just need to spend about 30 minutes to get it more integrated with the frontend software, but that is low priority since I am about the only one using them.
nickbuol is offline
post #842 of 1308 Old 04-03-2014, 05:08 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Just burnt the first volume works great. Burning second volume right now.
bori is offline
post #843 of 1308 Old 04-03-2014, 07:28 PM
04rex's Avatar
Quoted: 117 Post(s)
Liked: 26
Hey guys, how do you go about burning each of the volumes properly? What software is recommended and steps?? Also, is there a specific Blu Ray I should be using?
Sorry if this has been asked before.
04rex is offline
post #844 of 1308 Old 04-03-2014, 08:31 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Is there any bluray copy software that's free?
bori is offline
post #845 of 1308 Old 04-03-2014, 08:35 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
bori is offline
post #846 of 1308 Old 04-03-2014, 08:39 PM
bori's Avatar
Quoted: 187 Post(s)
Liked: 125
Use imgburn all you have to double click the file you want to burn. That will automatically open imgburn. Than select the burn to discuss option. That easy
bori is offline
post #847 of 1308 Old 04-03-2014, 09:18 PM
LastButNotLeast's Avatar
Quoted: 1475 Post(s)
Liked: 1069
@bori: See, now you're an expert.
Leo put together a nice how-to here:
http://www.avsforum.com/t/1391873/reference-blu-ray-demo-disc-bd9-dvd-dl-media-bd50
bori likes this.
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #848 of 1308 Old 04-03-2014, 09:22 PM
Kevin12586's Avatar
What would I have to do to convert the ISO so that it can be moved to a flash drive to play on my PS3?
I downloaded the files for the first disc and converted them using MultiAVCHD and am ready to move them to a flash drive. The second disc is an ISO so I am unsure what to do.
Kevin12586 is offline
post #849 of 1308 Old 04-11-2014, 10:19 PM
Kevin12586's Avatar
I need some help, I downloaded disk 1 from the torrent, not the iso but the individual files, used MultiAVCHD to convert them, put them on a flash drive and inserted it into my PS3. I can see the files and the clips in the stream folder play but I have no audio, not sure what am did wrong.
post #850 of 1308 Old 04-12-2014, 07:15 PM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
Use MediaInfo to get details about the file. I suspect you didn't mux the audio in, just video.
http://mediaarea.net/en-us/MediaInfo/Download/Windows
shpitz is offline
post #851 of 1308 Old 04-12-2014, 07:18 PM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
Just mount the ISO using Daemon Tools or Virtual CloneDrive, then you have full access to the files on the 'disc'...
shpitz is offline
post #852 of 1308 Old 04-13-2014, 07:02 AM
Liked: 1069
Not all the files on a disc are playable. Some are created as part of the mastering process. Are you having a problem with ALL the files you have?
post #853 of 1308 Old 04-30-2014, 02:25 PM
wyattroa's Avatar
Quoted: 165 Post(s)
Liked: 117
really wish I had a blue-ray burner. Would like to try this out on the system now and then on the new system when finished to see the difference.
Sub build http://www.avsforum.com/forum/155-di...et-r-done.html
Center - JBL LC2
Mains - JBL L820
Surrounds - JBL L820
Sub - Dual UXL'18 enclosures,iNuke6000dsp
wyattroa is offline
post #854 of 1308 Old 04-30-2014, 02:35 PM
nickbuol's Avatar
Quoted: 553 Post(s)
Liked: 613
Blu-ray (no 'e') burners are fairly inexpensive. $60 or less if you wait for NewEgg to have a good one on sale. Get some blank media (like a 10 pack on 50GB Verbatim at Amazon for $35, or single layer 25GB for less) and you can burn all sorts of demo discs. If you did only larger 50GB discs, that is still just $9.50 per demo disc, and everyone that you do after that just costs less and less per disc.
OK. So some people don't want to drop that much even... I get it. I just mentioned that it isn't horribly expensive.
nickbuol is offline
post #855 of 1308 Old 04-30-2014, 07:20 PM
Liked: 1069
Re-writables:
http://www.amazon.com/gp/product/B0056DUNLW/ref=oh_details_o03_s00_i00?ie=UTF8&psc=1
Don't bother with 25GB unless you're using them for your own backups.
nickbuol likes this.
post #856 of 1308 Old 04-30-2014, 08:14 PM
nickbuol's Avatar
Quoted: 553 Post(s)
Liked: 613
Re-writables:
That is what I meant (rewritables). $35 at Amazon.
There are some 25GB demo discs out there, but you are correct and that is why I mentioned the 50GB first. biggrin.gif
nickbuol is offline
post #857 of 1308 Old 05-01-2014, 06:27 PM
sawzalot's Avatar
Quoted: 17 Post(s)
I am not very tech savvy with the use of utorrent but I installed it and tried to download the ultimate bass demo disc 1 and it took 14 hours and finished incomplete, parts missing , I started it again but it is even slower than the first try. I must be doing this wrong , any tips would be appreciated, sawz.
sawzalot is offline
post #858 of 1308 Old 05-01-2014, 07:02 PM
Liked: 1069
You're probably not doing anything wrong, you're just two years too late. ;)
There probably aren't a lot of people seeding, but, if you ask, you may get someone to fire it up for you.
Try downloading something more current.
See my sig for suggestions, just check the dates and activity of the appropriate threads.
sawzalot likes this.
post #859 of 1308 Old 05-01-2014, 09:53 PM
socal swagger's Avatar
Quoted: 53 Post(s)
Liked: 25
Does anyone make demo disc for a fee?
socal swagger is offline
post #860 of 1308 Old 05-02-2014, 05:31 AM
Quicksilv3r's Avatar
Liked: 24
nope that is illegal to do so! You have to download and figure it out yourself (of course with the help of us) wink.gif
Quicksilv3r is offline
post #861 of 1308 Old 05-14-2014, 04:04 PM
SVS & Mirage Fanboy
stikle's Avatar
Quoted: 641 Post(s)
Liked: 595
Aw man...I'm late to the party too. I haven't yet tried, but I'm betting the torrents are dead now.
Anybody have these available still? Or are able to directly FTP the ISOs?
Seth-o-Plex featuring Atmos/DTS:X 7.2.4 & 4K! - Vizio | Denon | Oppo | Onkyo | SVS | Mirage
stikle is offline
post #862 of 1308 Old 05-14-2014, 05:21 PM
megdagooch's Avatar
Quoted: 22 Post(s)
Liked: 38
Ill start seeding
Sorry I left without starting it. I will tonight
megdagooch is offline
post #863 of 1308 Old 05-14-2014, 06:57 PM
Boxozaxu's Avatar
Quoted: 455 Post(s)
Liked: 295
Originally Posted by megdagooch View Post
Ill start seeding
You're seeding the two torrent files in the very first post, correct?  I'd like to grab a copy too but I'm also late to the party.  :)
Boxozaxu is offline
post #864 of 1308 Old 05-15-2014, 05:03 AM
jollyguy23's Avatar
I started the download last night from the two links that is on the master thread. You should too. There are about 4 to 5 people seeding each version. I am not done with the download but hopefully by tonight it will be done and i will be seeding this as well. So it is not too late smile.gif
jollyguy23 is offline
post #865 of 1308 Old 05-15-2014, 09:00 AM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
Spreading the love as well.
EDIT: Not sure why i wasn't seeding vol.1, I just added it as well smile.gif
shpitz is offline
post #866 of 1308 Old 05-15-2014, 09:49 AM
Boxozaxu's Avatar
Quoted: 455 Post(s)
Liked: 295
Thanks! that's great!
I guess it's time to turn down the steaming quality on netflix.  I'm already getting fun data overage emails from my ISP and these downloads are not going to help :rolleyes:
Boxozaxu is offline
post #867 of 1308 Old 05-15-2014, 10:17 AM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
Haha, same here, got a 1TB/mo limit with Mediacom in the Chicago area...
shpitz is offline
post #868 of 1308 Old 05-15-2014, 12:44 PM
Boxozaxu's Avatar
Quoted: 455 Post(s)
Liked: 295
WHAT!!!  Cox gives me 250GB per month :mad:  If I upgrade to their 'Ultimate' package I could get 400GB.
Boxozaxu is offline
post #869 of 1308 Old 05-15-2014, 01:27 PM
shpitz's Avatar
Quoted: 66 Post(s)
Liked: 55
Ouch! I think it's 500gb if you have under 50mbit, and 1TB with 50mbit or faster. They charge $10 for each 50gb extra.
shpitz is offline
post #870 of 1308 Old 05-15-2014, 02:10 PM
SVS & Mirage Fanboy
stikle's Avatar
Quoted: 641 Post(s)
Liked: 595
Thank you! I've started Vol 1 now.
stikle is offline
Blu Ray Movies , Black Hawk Down Blu Ray , Inception Two Disc Edition Blu Ray , Master And Commander The Far Side Of The World Blu Ray , Iron Man Blu Ray , Irobot , Live Free Or Die Hard Blu Ray , Cloverfield Blu Ray , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Flight Of The Phoenix Blu Ray , Terminator Salvation Two Disc Directors Cut Blu Ray , The Incredible Hulk Blu Ray , Transformers Blu Ray , The Dark Knight Bd Live Blu Ray , Jurassic Park Ultimate Trilogy Blu Ray Digital Copy , Tron Legacy Two Disc Blu Ray Dvd Combo
