#### The ULTIMATE Bass Demo Disc #### - Page 38 - AVS Forum | Home Theater Discussions And Reviews
post #1111 of 1119 Old 04-25-2015, 09:03 AM
LastButNotLeast's Avatar
Quoted: 686 Post(s)
Liked: 493
That would mean remuxing with TsMuxeR.
http://www.videohelp.com/software/tsmuxer
Did you really need to quote that entire post in your reply?
Downloadable FREE demo discs: Demonstration Blu-Ray Discs (Independently Authored)
Welcome to AVS - Get out while you still can!
LastButNotLeast is offline
post #1112 of 1119 Old 04-25-2015, 12:44 PM
bouf0010's Avatar
Quoted: 37 Post(s)
Originally Posted by zeez View Post
K, seems it's not possible to do that right now. Interestingly enough, all the files will play on the PC using Media Player Classic (but not Windows Media PLayer) so I know the files work.. I just have to figure out why some work on the PS3 and some don't. Going to try do some research and experimentation with settings on ps3 media server.. but i'll also check back here to see if someone has a solution =)
take a look through this - i believe you can stream an ISO file directly to the PS3
bouf0010 is offline
post #1113 of 1119 Old 04-30-2015, 07:22 AM
thebland's Avatar
Quoted: 602 Post(s)
Liked: 268
Originally Posted by Jindrak View Post
I know I've read elsewhere, but you can google the rest. Zeev, for files to play on the ps3, they have to be in a certain format with certain options. I learned that when I tried copying over files with ps3 media server several years ago. I don't know about now as I don't use that anymore, but you will likely have to re-encode the video for it to work. Also, you can't bitstream DTS-HD MA and Dolby TrueHD with ps3 media server, at least from a quick google about it.
@Bland
You don't need to pay for a burning program. Download Imgburn, it's free and works just fine. It's what I've used for several years now.
IMGBURN is designed for Mac?
My Home Theater of the Month- Le Petit Trianon
There are more than a handful of [op amps] that sound so good that most designers want to be using them as opposed to discreet transistors. Dave Reich, Theta 2009
thebland is online now
post #1114 of 1119 Old 04-30-2015, 08:53 AM
Quoted: 686 Post(s)
Liked: 493
IIRC, I've used this:
http://burn-osx.sourceforge.net/Pages/English/home.html
post #1115 of 1119 Old 05-01-2015, 09:09 AM
thebland's Avatar
Quoted: 602 Post(s)
Liked: 268
Originally Posted by LastButNotLeast View Post
Great. I'l try it. Thanks!
post #1116 of 1119 Old 05-01-2015, 11:42 AM
superleo's Avatar
Quoted: 45 Post(s)
Liked: 242
If you would like to play the video files right from the PS3 these need to be changed to TS files. TsMuxer can do this for you. The process is literally just changing the type of container. The TS file will still have exactly the same characteristics, video and audio, just a different file extension.
Once the m2ts files are converted to TS files these can be streamed, copied or even played from an external device.
RPCRT-TV Overscan Reduction
Reference Blu-Ray Demo Disc
superleo is offline
post #1117 of 1119 Old 05-01-2015, 02:48 PM
Quoted: 686 Post(s)
Liked: 493
Link in post 1111, above.
post #1118 of 1119 Old 05-13-2015, 03:56 PM
the_abbot's Avatar
Quoted: 145 Post(s)
Is there cover art available for disc 3? I would like to create a menu based disc of the files.
the_abbot is offline
post #1119 of 1119 Old 05-15-2015, 06:42 PM
shpitz's Avatar
Quoted: 29 Post(s)
Liked: 41
Please share if you do
shpitz is offline
Blu Ray Movies , Black Hawk Down Blu Ray , Inception Two Disc Edition Blu Ray , Master And Commander The Far Side Of The World Blu Ray , Iron Man Blu Ray , Irobot , Live Free Or Die Hard Blu Ray , Cloverfield Blu Ray , Avatar Three Disc Extended Collectors Edition Bd Live Blu Ray , Flight Of The Phoenix Blu Ray , Terminator Salvation Two Disc Directors Cut Blu Ray , The Incredible Hulk Blu Ray , Transformers Blu Ray , The Dark Knight Bd Live Blu Ray , Jurassic Park Ultimate Trilogy Blu Ray Digital Copy , Tron Legacy Two Disc Blu Ray Dvd Combo
Gear in this thread - Avatar by PriceGrabber.com
