Patch Panel/ Wire Management - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-01-2012, 09:26 AM - Thread Starter
fax6202's Avatar
Does anyone have any good recommendations for a patch/termination panel. I would like to have a panel where I can terminate everything right into keystones. That way I can just use short wires/cords from keystone connections to outlets. Thanks.
fax6202 is offline
post #2 of 7 Old 06-01-2012, 09:33 AM
vanice's Avatar
Quoted: 32 Post(s)
Liked: 53
vanice is offline
post #3 of 7 Old 06-01-2012, 10:21 AM
CEO FALCON SCREENS
snickers1's Avatar
Quoted: 81 Post(s)
Liked: 126
Originally Posted by vanice View Post
This is what I plan to use.
i have that and also bought the 4ft relay rack and a couple shelves for the fios router and the home server, they also sell gigabit switches now, but i had a coupon code for newegg and got a much better deal on a switch..
also if plan on streaming movies from a home server or would just like have a faster network or at least one that you can grow into i would think about running cat6 cable...
snickers1 is offline
post #4 of 7 Old 06-01-2012, 11:10 AM
jcorbin's Avatar
I got the Cat6 patch panel from MP, like what vanice posted.
Also got the Cables To Go blank keystone patch panel from Amzn - here.
To hold both of those, I picked up a Tripp Lite 4U hinged patch panel bracket, also from Amzn (they love me). Here is a link.
The trip lite will go directly on the wall, high up in the equipment closet, where everything will terminate. The hinge is nice to be able to get to the rear of the patch panel if needed in the future.
If you are doing a whole house setup, you'll definitely need something larger.
jcorbin is offline
post #5 of 7 Old 06-01-2012, 12:26 PM
scl23enn4m3's Avatar
I fourth the Monoprice panel. I'm using the 12 port cat6 one and a bunch of their keystones with no issues.
scl23enn4m3 is offline
post #6 of 7 Old 06-01-2012, 12:59 PM
GWCR's Avatar
Quoted: 17 Post(s)
Liked: 39
+5?
This is the one I got from monoprice.
12 port patch panel
Had it for over 2 years and no issues.
GWCR is offline
post #7 of 7 Old 06-01-2012, 01:31 PM
carboranadum's Avatar
Quoted: 21 Post(s)
Liked: 24
I used two of these and they worked out really, really well. I have them connected to two routers and we're in business!
carboranadum is offline
