Kinetic River Cinema - Page 20 - AVS Forum | Home Theater Discussions And Reviews
post #571 of 597 Old 12-06-2012, 07:08 PM - Thread Starter
fax6202's Avatar
Wow, almost the bottom of page 3. A little over a week feels like a year!
A few small updates.....
I had to make a small modification to the entry door to the HT, due to the thickness of the door and the amount of treatment and finishing on the inside of the door I had to rebuild the interior door frame. I pretty much just ripped out the 2x4 on the hinge side and will replace with a 2x8 ripped down to 6". This will let me run the wainscoting run right across the inside of the door in the room.
On a few side notes:
I decided to go with Quest Acoustic panels for the Theater, much more to come on that later!
And I thought I would post a piece of furniture that was built by a friend and someone I really lean on when it comes to woodwork, especially finishing. This was done several years ago for one of his customers in Miami. I think it is one of the finest custom pieces you will see, it is hypo bleched bleaced walnut crotch and highly figured walnut to imitate antique bleached french walnut polished to a mirror finish using a French Polishing technique.
fax6202 is offline
post #572 of 597 Old 12-08-2012, 05:57 AM
xjagox's Avatar
Quoted: 42 Post(s)
Liked: 39
Are you swinging your door into the room, or out?
Have you looked around yet locally for door suppliers?
xjagox is offline
post #573 of 597 Old 12-18-2012, 05:14 PM
TMcG's Avatar
Quoted: 1185 Post(s)
Liked: 1000
How did your door modification turn out?
TMcG is offline
post #574 of 597 Old 12-20-2012, 08:27 PM - Thread Starter
fax6202's Avatar
Completely missed your question Tim as it has been a while since I posted. Demo is done, I just need to frame the rough opening on the hinge side.
FWIW...Im still in a holding pattern with the HT and the basement as well. Between my wedding and xmas I have had no time to get anything done. Nevertheless, I will be hitting it hard right after the new year.
fax6202 is offline
post #575 of 597 Old 01-03-2013, 11:20 AM - Thread Starter
fax6202's Avatar
Make that after duck season
fax6202 is offline
post #576 of 597 Old 01-04-2013, 06:03 PM
Unknown_Epiphany's Avatar
Dave,
Good to see another Marylander around. My wife and I are saving up for a house and are gearing up for the home theater. Your woodworking skills are impressive, I am not much of a woodworker or a construction guy myself, so threads like yours inspire me. Subscribed!
Unknown_Epiphany is offline
post #577 of 597 Old 01-09-2013, 03:22 PM - Thread Starter
fax6202's Avatar
Thanks for chiming in. Just keep reading as much as you can here on AVS, you would be surprised how much you learn and can accomplish yourself. Good luck
fax6202 is offline
post #578 of 597 Old 03-17-2013, 07:42 PM - Thread Starter
fax6202's Avatar
Update:
I have taken an extended break to accommodate the waterfowl hunting season. Having said that, there have been a few changes since I last picked up the hammer. One was the decision to go with Qwest panels for sound treatments, thus I hired the Erskine Group and more specifically Shawn Byrne (aka SierraMikeBravo). He is designing the room and I will post plans when available and what Shawn gives the OK on.
More to come
fax6202 is offline
post #579 of 597 Old 03-18-2013, 02:59 AM
NGiovas's Avatar
Quoted: 16 Post(s)
Liked: 44
Originally Posted by fax6202 View Post
Update:
More to come
I cry FOWL!  You have been DUCKing your theater responsibilities lately!
Sorry, as stupid as that sounded, I just couldn't resist.
I just noticed that you have a Kreg router table.  How do you like it?  Do you have a lift with it?  I recently upgraded from an older Porter Cable bench top table to the Kreg with a lift and I can't believe I didn't do it much sooner.
Can't wait for more theater updates.
Nick
NGiovas is offline
post #580 of 597 Old 03-18-2013, 07:40 AM - Thread Starter
fax6202's Avatar
I love the kreg table. It's been awesome. I don't have a lift but I manage just fine without it. But a great table nonetheless.
And yes I have been neglecting the HT. but it will be picking up again in no time
fax6202 is offline
post #581 of 597 Old 04-13-2013, 07:43 PM - Thread Starter
fax6202's Avatar
I got my drawings back from Shawn (aka SierraMikeBravo) at Erskine Group. These are the stripped versions for viewing
fax6202 is offline
post #582 of 597 Old 04-14-2013, 04:58 PM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
Why are your L and R speakers outside of your screen?
BllDo is offline
post #583 of 597 Old 04-15-2013, 07:18 AM - Thread Starter
fax6202's Avatar
I would need a 140" wide screen to accommodate the proper spacing. And at my max throw distance there is not an affordable PJ I can find to project on that size screen. The speakers will be in the left and right columns on the front stage
fax6202 is offline
post #584 of 597 Old 04-15-2013, 07:32 AM
HopefulFred's Avatar
Quoted: 521 Post(s)
Liked: 484
So the speaker positions were determined based on room size/dimensions, then a screen was designed to fit around (or your case - due to budget - between) the left and right speakers. Do I have that right?
HopefulFred is online now
post #585 of 597 Old 04-15-2013, 07:53 AM
J_P_A's Avatar
Quoted: 650 Post(s)
Liked: 483
Is the screen frame the issue? Seems like you could get that 140" screen and then mask down with AT panels in order to get the speakers where you want them. That's assuming you are not using a high dollar screen.
The Plains Theater Has Begun
J_P_A is offline
post #586 of 597 Old 04-15-2013, 09:20 AM - Thread Starter
fax6202's Avatar
Correct
fax6202 is offline
post #587 of 597 Old 04-15-2013, 09:26 AM - Thread Starter
fax6202's Avatar
The original plan was for a baffle wall, but I have some issues up front that would not work with a baffle wall, such as two support posts from the I beam. So, with my limitations up front and limited length of the room, the LR speakers had to come out from behind the screen. In the picture, they are on the back wall, in the design they are actually a bit forward and the L and R are toed in a bit. To what degree, im not sure. This is one of the earlier drawings, little has changed except the front wall. I'll have more details on the final position of the speakers after Shawn calibrates the room.
fax6202 is offline
post #588 of 597 Old 04-15-2013, 09:27 AM - Thread Starter
fax6202's Avatar
forgot to mention that I already had a great deal for an SMX screen in place which is 120" wide 235
fax6202 is offline
post #589 of 597 Old 04-15-2013, 09:50 AM
Spaceman's Avatar
Quoted: 43 Post(s)
Liked: 150
I'm assuming you are you getting this used from a 3rd party and aren't planning on getting it directly from SMX.
Spaceman is offline
post #590 of 597 Old 04-15-2013, 11:21 AM - Thread Starter
fax6202's Avatar
Yes sir
fax6202 is offline
post #591 of 597 Old 06-04-2013, 03:45 AM
BllDo's Avatar
Quoted: 596 Post(s)
Liked: 397
Just want you to keep this in mind. Any updates?
BllDo is offline
post #592 of 597 Old 06-12-2013, 06:29 AM
Quoted: 521 Post(s)
Liked: 484
Dave hasn't posted since 4/16. There's gonna be a lot of dead kittehs.
post #593 of 597 Old 07-04-2013, 06:51 PM - Thread Starter
fax6202's Avatar
I am not dead, just getting back into the basement now. Things have really slowed down, but I am back at it, nonetheless
fax6202 is offline
post #594 of 597 Old 09-02-2013, 07:38 PM
Jeff in Canada's Avatar
Quoted: 167 Post(s)
Liked: 62
Audio: Denon AVR-4520, Fusion 12 Tempest (LCR), Fusion 8 Alchemy (4xSurrounds+2xWides+2xHeights),4 x 15" Dayton Ultimax
Video: Sony VPL-HW40ES, Darbee Darblet, SMX 2.35:1 Screen
Seating: Fusion Lagoon Chairs
Theater Build
DIY Speaker / Sub Build
Jeff in Canada is offline
post #595 of 597 Old 09-02-2013, 07:41 PM
Quoted: 167 Post(s)
Liked: 62
Your theater looks great. Was the legend deleted? Looking at other designes, it would appear that:
1) Panels with circles are absorbtion? Q-Flector?
2) Panels with X is diffusion ? Q-Perf?
3) Panels with angled line, dot, angled line are likely what? diffraction? Perhaps Quest Q-Fractor?
Theater Build
post #596 of 597 Old 12-21-2013, 06:45 PM
xjagox's Avatar
Quoted: 42 Post(s)
Liked: 39
Dave, any new progress on the theater?
xjagox is offline
post #597 of 597 Old 01-11-2014, 10:21 AM
Quoted: 167 Post(s)
Liked: 62
Any update?
Theater Build
Displays , Speaker Systems , Triad Inroom Gold Sub , Qsc
