Star Ceiling - Twinkle White Color Wheel or 6 Color Twinkle Wheel - AVS Forum | Home Theater Discussions And Reviews
Old 06-14-2012, 03:54 AM - Thread Starter
ultra100's Avatar
Hi!
My name is Alex, and I am new to AVS Forum.
I am planning on ordering and installing star ceiling kit in on of my rooms and I am not professional in this field, so any help would be much appreciated.
The product which I would order is HXL-328 (with LEA-501) - 240pcs 0.75mm+80pcs 1.0mm+8pcs 1.5mm with 8pcs crystal ceiliing end fixtures. It would cover around 10sq meters of ceiling.
Which particular wheel should I chose for the best star ceiling effect - "twinkle white color" or "6 color twinkle wheel"? Does "6 color twinkle wheel" produce the same effect as "twinkle white color" but additionally has 5 more colors to switch?
Alex
ultra100 is offline
Old 06-14-2012, 02:51 PM
dvmiller's Avatar
Hello Alex,
Welcome to the forum!
I am not familiar with the particular unit you mention but, believe the twinkle effect would be the same except that the user chooses which color to display. I am in the midst of assembling my star ceiling but, opted for white only. I did not go with a color unit as I feel the effect would not be desirable since that's not what the real sky looks like.
Best of luck with your star ceiling project.
Dale
dvmiller is offline
