Ideas on how to seal up a powerbridge - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 06-16-2012, 06:31 AM - Thread Starter
jgourlie's Avatar
Quoted: 26 Post(s)
So I picked up monoprices version of a powerbridge. I can easily seal up the electrical side as it uses a 1 gang box, and I could put a putty pad.
The issue is with the hdmi side of the bridge where the wire comes in. I don't think code would allow me to use a 2 gang box with the low voltage and electrical in the same box.
It appears that caulking the low voltage side won't work cause its a big hole for the hdmi cable to come through.
Great stuff expanding foam maybe?
Any ideas are really appreciated
jgourlie is offline
