BEF from Norway,DIY Uncompromising Theater - Page 4 - AVS Forum | Home Theater Discussions And Reviews
 13Likes
post #91 of 183 Old 11-24-2012, 11:26 PM
localhost127's Avatar
Quoted: 25 Post(s)
Liked: 58
Originally Posted by DavidK442 View Post
Excluding Dennis Erskine's professional builds many people just line their walls with absorbption and call it a day...a dead, dull day.
Over the past two years I can probably count the number of AVS Forum theater builds which have taken a serious stab at diffusion on one hand (Roger Dressler's beautiful space and Landshark's 2.0 come to mind).
Kudo's to your effort.
yes, it is very common to see those blindly line walls with absorption - but even worse is the lining of the walls with "thin" porous absorption.
the same actually goes far too frequently with "diffusion" as well .. but the OP here has clearly understood the benefit a little extra material gives you, considering the bulk of the time spent on the PRDs has little to do with actual "length" of the wells. +1 again to good broadband design (a rarity it seems all too often) - but regardless, there are rules at play regarding reflection phase gratings (primarily, the 3x design frequency distance limitation to allow on to be in the "far-field" of the coherent spatially and temporally dispersed returns (vs the near-field of a RPG which is quite a chaotic superposed "mess"!)
far far too often we see the deployment of shallow reflection phase grating diffusers (eg, 3-5" max well depth). +1 to the OP for low design frequency.
localhost127 is offline
post #92 of 183 Old 11-30-2012, 02:25 PM - Thread Starter
BEF-NO's Avatar
Quoted: 13 Post(s)
Liked: 68
Very good that there is discussion about acoustics. It is a factor too many people forget in their setup.
BEF-NO is offline
post #93 of 183 Old 11-30-2012, 02:29 PM
TMcG's Avatar
Quoted: 1072 Post(s)
Liked: 870
That is a serious system and some serious committment you have there sir. Congratulations!
The pictures of the finished room are simply astounding.
Great that forum members have provided expert diffuser critique but don't be discouraged.
+1 to both comments. Oh, and by the way....my theater's acoustics are being handled by Dennis Erskine to maximize the theater's performance after my investment in Procella loudspeakers which require more diffusion than most other speaker types.
TMcG is offline
post #94 of 183 Old 11-30-2012, 02:36 PM
Elill's Avatar
Quoted: 98 Post(s)
Liked: 89
What makes them different to any other controlled directivity speaker/anything with good off axis response?
Peter the Greek
Downunder Theatre MkII
List of Pro Designers
Elill is offline
post #95 of 183 Old 11-30-2012, 06:10 PM
TMcG's Avatar
Liked: 870
Probably not huge differences, but when I said "other speaker types" I was referring to a traditional speaker without the benefit of the compression drivers and controlled directivity waveguides.
TMcG is offline
post #96 of 183 Old 12-01-2012, 06:55 AM
Quoted: 25 Post(s)
Liked: 58
what's your definition of "diffusion"?
post #97 of 183 Old 12-01-2012, 08:16 AM
Nightlord's Avatar
Quoted: 711 Post(s)
Liked: 237
The special lens they used to shoot William Shatner in the last couple Star Trek movies.
Under construction: the Larch theater
Nightlord is offline
post #98 of 183 Old 12-10-2012, 01:36 AM
Nightlord's Avatar
Quoted: 711 Post(s)
Liked: 237
Originally Posted by BEF-NO View Post
For even better sound insulation I use double board layer of special glue, green glue, between the layers.
400
How was it to work with this one, thinking about getting the same one for redoing my front wall? Any typical mistakes you can stop me from doing?
Did you remove the screws after it dried, or do one keep then there for good?
post #99 of 183 Old 12-12-2012, 03:25 PM - Thread Starter
BEF-NO's Avatar
Quoted: 13 Post(s)
Liked: 68
You should wear gloves when working with it. I used about 2kg per. plate, the plate is screwed with a normal number of screws, the screws should not be removed.
It is a very good product.
BEF-NO is offline
post #100 of 183 Old 12-13-2012, 01:49 AM
Nightlord's Avatar
Quoted: 711 Post(s)
Liked: 237
Thanks. I do keep getting feedback on the swedish forum that I way end up losing sound proofing in the low range by using it rather than just using multiple drywalls on their own, so currently I'm somewhat confused on how to proceed. I'll try to figure out the problem frequency range and then go over the different ways again to see what might work the best.
I'm certain it's a good product - my main speakers are laminated using it.
post #101 of 183 Old 12-13-2012, 11:41 AM - Thread Starter
BEF-NO's Avatar
Quoted: 13 Post(s)
Liked: 68
When it comes to soundproofing, there are many who have thoughts and opinions, as it is in cable debates. The effect you get with using this type of product is that you change and reduce resonance in the material. Frequencies below 150-200Hz will have less effect on, but will not be any worse than without.
Which forum you are on in Sweden?
Mfusick likes this.
BEF-NO is offline
post #102 of 183 Old 12-13-2012, 12:00 PM - Thread Starter
BEF-NO's Avatar
Quoted: 13 Post(s)
Liked: 68
Here are clips of the article from my home theater, here is the link to the article Hjemme hos Bjørn Erik, Hjemmekino interiør med høyt nivå
From the Web report,
BEF-NO is offline
post #103 of 183 Old 12-13-2012, 01:25 PM
Nightlord's Avatar
Quoted: 711 Post(s)
Liked: 237
I will try this weekend to find out the frequency range I have problems with. Assumption is the very low end.
Primarily faktiskt.se, less so on minhembio.com
post #104 of 183 Old 12-23-2012, 07:21 AM - Thread Starter
BEF-NO's Avatar
Quoted: 13 Post(s)
Liked: 68
When the home theater has been completed, it was time for a facelift of the reception room to the home theater.
zuluwalker likes this.
BEF-NO is offline
post #105 of 183 Old 12-23-2012, 09:52 AM
dengland's Avatar
Quoted: 21 Post(s)
What an unassuming entrance to sonic terror that awaits inside ....
I could have financed my (future) build if I would have just invested in MDF stock before you started building speakers...
Heck of a place you have there. As others have said, your craftsmanship is excellent.
dengland is offline
post #106 of 183 Old 12-23-2012, 04:48 PM - Thread Starter
BEF-NO's Avatar
Quoted: 13 Post(s)
Liked: 68
Thank you!!
Have been some board with MDF in the project and it will come something more, i have started on something new around the speakers smile.gif
BEF-NO is offline
post #107 of 183 Old 12-24-2012, 05:40 AM - Thread Starter
BEF-NO's Avatar
Quoted: 13 Post(s)
Liked: 68
Want to wish you all on AVS Forum a Merry Christmas
BEF-NO is offline
post #108 of 183 Old 12-28-2012, 06:41 AM - Thread Starter
BEF-NO's Avatar
Quoted: 13 Post(s)
Liked: 68
I have not been happy with the screen size i chose that it is 16:9, so i decided to rebuild the front wall and install 2.35:1 screen. To get a screen that would fit right into my room i chose to build the screen myself. It will have a picture of 321 centimeters in width, room total width are 383 centimeters.
The olde screen size in red
BEF-NO is offline
post #109 of 183 Old 12-28-2012, 07:33 AM
Nightlord's Avatar
Quoted: 711 Post(s)
Liked: 237
God Jul och God fortsättning!
Looking great so far!
This actually gets one wondering if that's not the way to go from the beginning, or at least to make sure I have masking available for the format.
post #110 of 183 Old 12-28-2012, 05:21 PM
just jim's Avatar
Quoted: 70 Post(s)
Liked: 50
The green glue that I have used, does not actually dry and is not actually an adhesive. It remains pliable. It is a sound/vibration deadening material. The second layer of drywall has the "glue" spread on it and should actually be held in place with special "drywall to drywall" screws sold by commercial DW suppliers. They are a fat , course thread, 1 1/2" long screw with the typical DW screw bugle head. The screws DO NOT hold into the wood, but rather the first layer of DW ONLY and are kept in place. This keeps the sound hitting the surface of the DW from transmitting through the screw into the wood/steel studs.
It should be noted that a 1/4" gap should be left around the perimeter of the wall or ceiling which gets filled with acoustic seal (comes in calking tubes) before the adjoining wall gets it's second layer of DW (especially at the floor). The second layer of DW should lap the joints of the first layer, as BEF has done, or run perpendicular to the direction of the first layer (this can help the 2nd layer sit flatter). There should be a bead of acoustic seal applied along the edge of the sheet, that the next sheet butts into. Basically, there should not be any unsealed cracks for sound to leak through. Acoustic seal can be messy to work with. It always seems to get onto your hands...and beyond. When applying the beads, apply only enough to seal the gap without bulging beyond the surface. These joints are then taped and finished in the usual manner.
The green glue also comes in large calking tubes and gets applied at the rate of two tubes/4 x 8 sheet.
Winterfell theatre build - working title
just jim is offline
post #111 of 183 Old 12-29-2012, 04:00 AM
Nightlord's Avatar
Quoted: 711 Post(s)
Liked: 237
Thanks, I got that confirmed in my mailbox by the green glue company that one cannot remove the screws at at later point as the green glue does not have adhesive power to hold the drywall. I haven't yet asked swedac if their glue is the same, but I'd hazard a guess that the answer would be the same.
It only leaves some question about how those premanufactured drywalls with green glue in them from the start are made, of course.
post #112 of 183 Old 12-30-2012, 12:27 AM
just jim's Avatar
Quoted: 70 Post(s)
Liked: 50
We have such a board called Quietrock. I believe it stays together because it is 1) rapped as a unit with paper, 2) has a complete thin coat with no voids, 3) held up as a unit with screws penetrating both layers and 4) the surfaces bonded are not perfectly smooth. If you cut a small square, you can get it apart, but a thin "film" of gypsum seems to coat the green glue layer, so there may also be some penetration into the surface of the gypsum by the glue.
Did you have any luck finding the drywall to drywall screws? My regular building supply companies have never heard of them, but the drywall specialty outlets, who handle Quietrock type DW would have them.
Of course to avoid the expense of Quietrock, resilient tracks could be used to help keep the sound vibrations from going up through the ceiling structure if a separate frame for the ceiling is not used as done by BEF. The second layer of DW with green glue could be used with regular DW screws also into the same resilient tracks. Using 5/8" DW also helps. This is not as good as two layers of Quietrock however.
Any holes cut through the ceiling for such things as pot lights, junction boxes, vents, etc., that do not have sound traps will of course negate all of the time and expense of the double DW. Pot lights create their own problem since the heat they create must dissipate to at least 6' of joist space, unless a Insulated Thermal Unit is used to safely contain the heat and minimize the risk of fire. Ceiling speakers should have sound traps. This holds true for any openings in the walls as well. Sound will travel/reflect through any open space to rooms beyond. And vibrations will travel through solid materials to other rooms if no dampening or isolation is incorporated.
just jim is offline
post #113 of 183 Old 12-30-2012, 03:49 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
This is absolutely not correct. The second layer of drywall needs to be secured to the structure holding the wall board whether it be channel or studs.
BllDo is offline
post #114 of 183 Old 12-30-2012, 03:56 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
Can you speak a little bit to your thought process regarding the change? I'm currently debating a new screen size and leaning towards either 16:9 or CIA.
BllDo is offline
post #115 of 183 Old 12-30-2012, 07:05 PM
just jim's Avatar
Quoted: 70 Post(s)
Liked: 50
I'm afraid we disagree on this point. This is the installation technique I got from Quietrock and the people selling the products. And my own experience.
The logic is that sound waves hitting the surface of the board can transmit through the screw to the stud (this is limited to frequencies with wavelengths equal to or shorter than the length of the screw), thus allowing higher frequencies to transmit. By screwing to the first layer of DW only you are breaking this link.
The green glue people would also like to see you use a bead of green glue on the studs before installing the board which would further dampen this connection. It didn't look like BEF had used this bead on the stud, so I was limiting my comments to installing a second layer of board to an existing drywalled room which is, I believe, where Nightlord is proceeding from.
FYI...The issue with attaching DW to a new wood stud without green glue, is that the stud will probably shrink slightly as the wood acclimatizes to the room humidity. The screw holds fast in the wood and when the wood shrinks a gap can develop between it and the DW, allowing movement. If you have ever seen a "popped" DW screw, if you push on the DW, you will probably see movement at the screw. This is why. This can also be a major problem with old, very dry studs, if you drywall in the summer in an un-air conditioned room. The studs actually swell in the humidity and shrink once the building is sealed and the heat/ A/C drys the air. Now, if you have a layer of DW that can move, it acts as drum skin and makes the air in the stud space vibrate like a drum and those nasty lower frequencies have escaped.
Now, this is all pretty picky in the grand scheme of things, and as I have previously said, all for not, if you then start cutting holes through the DW for lights, wiring and ventilation without sound traps!
There will always be different opinions about how things should go together. What works in one case won't necessarily work in another. You literally have to look at all the details around a particular situation. I'm just trying to share my experience in trying to "minimize" sound transmission that I've learned through watching and listening to others in the construction industry and my own trial and error R & D as a contractor over the past 30 years.
...But, as always, I'm willing to listen to your argument.
just jim is offline
post #116 of 183 Old 01-01-2013, 08:08 PM
BllDo's Avatar
Quoted: 572 Post(s)
Liked: 372
You can disagree all you want, I don't really care. I'm not going to clog BEF-NO's great thread with your troll fodder. If you'd care to start a new thread to discuss the merits of your "expertly" advised drywall installation methodologies, I'm sure the many experienced members around here (including Ted White one of the co-founders of Green Glue) would love to rip me to shreds. In the meantime, I'd challenge you to provide even one piece of documentation from a reputable manufacture or municipal building code that would recommend the use of laminating screws as the sole method of securing multiple drywall layers with damping compound.
BllDo is offline
post #117 of 183 Old 01-03-2013, 06:03 AM
erwinfrombelgium's Avatar
Quoted: 410 Post(s)
Liked: 216
BEF,
Great theatre! Seems like you Norwegians really got the knack of it. There's also Atledreier who posts on HTShack, he uses the same LCR. And there's Akto, who posted pics of his stunning HT here:
http://www.blu-ray.com/community/gallery.php?member=akto
Good for you to go to a 2,35/1 screen. I have one waiting in a box until our HT is ready. Same size: 130"...
I am especially interested in those inConcert Miles. But it seems the designer is no longer in business. Are there variations available such as your surrounds or did you come up with those yourself?
Building a 9.3.4 HT: DIYSG Titan LX [LCR] • Cinema 10 Max [6 Surrounds] • Beta 10CX custom [TF+TR] • LLT Mal-x 18" subs [2] • XPR-5 • MM8003 [8ch] • XMC-1 [RMC-1 wanted] • PT AT6000E • 130" Seymour Center XD • Oppo 103EU • WTB: 1 extra Mal-x 18" SW
erwinfrombelgium is online now
post #118 of 183 Old 01-06-2013, 02:54 PM
just jim's Avatar
Quoted: 70 Post(s)
Liked: 50
Someone seems to have anger management issues, as illustrated in his portrait. Did something happen that makes him think that "experienced members would love to tear him to shreds"?
Troll fodder? Seriously? I've reviewed my post and don't see it.
BEF, seeing the thought and science that you have obviously put into your build, I made my final decision about the screen being AT. I was hung up on the fabric affecting brightness/contrast/sound acuity. This has changed my screen from 120" x 51" to a much more satisfying 152" x 65" CIH, resolved speaker placement issues and moved my projection wall in 2'. Now I am working very hard at winning the lottery to pay for it all. Thank you for the inspiration (my wife doesn't). smile.gif
Nightlord, You asked Q's, I hope my answers were helpful. I like to understand why something is done a particular way or the cause for a problem; hence the FYI.
I try to limit my input to topics I know. I don't pretend to always be right. I am always open to a discussion about points of view on how to do things. That is how we learn and evolve. I thought that this was the beauty of an open forum, so that people can share their experience and build a better mouse trap together!
just jim is offline
post #119 of 183 Old 01-06-2013, 04:42 PM
aaustin's Avatar
Liked: 36
just jim,
While your input is certainly appreciated as it results in discussion, this is a public forum and the correct information must come out in the end so that those reading but not posting can be sure that what they are reading here is accurate.
The second layer of drywall should be screwed directly to the studs just like the first. This is what The Green Glue Company specifies, as well as all industry leaders that I have spoken to who are involved with the production and manufacturing of Green Glue. Laminating screws with a drywall adhesive may be an ok way to attach multiple layers of drywall, but we must remember that Green Glue is not an adhesive despite its name and sticky characteristics. Especially when first applied before the damping compound has time to cure, Green Glue has almost no adhesive properties. This would result in the laminating screws being the only method of holding the second layer of drywall for up to a month before the Green Glue becomes more sticky. On a ceiling especially, this would scare me.
You also stated that The Green Glue Company recommends applying a bead of their product on the studs before the first layer of drywall. This is also incorrect. I have never seen such a recommendation and one of the founders of Green Glue, Ted White, has specifically recommended against it.
Once again, your input is certainly welcome as it spurs on discussions such as this, but the final information in this case comes straight from the manufacturers and founders of Green Glue.
If you'd like to discuss these points in more detail please consider starting a new thread where others can weigh in and provide you with more scientific explanations if you so wish.
GWCR likes this.
The Austin Home Theater:
aaustin is offline
post #120 of 183 Old 01-11-2013, 02:19 AM - Thread Starter
BEF-NO's Avatar
Quoted: 13 Post(s)
Liked: 68
I have disliked the "small" picture when I have watching movies that have 2.35:1 format. The combination having 2.35:1 and 16:9 with the same height of the image is absolutely perfect for me. The cinema feeling you has with a large and wide 2.35:1 screen is huge. I have no regrets!
BEF-NO is offline
Speaker Systems , Blu Ray Players , Monster , Oppo Bdp 95 Blu Ray Disc Player , Crown It4000 Itech Power Amplifier
