/** * vBulletin 3.8.7 CSS * Style: 'AVSForum-new'; Style ID: 113 */ @import url("http://www.avsforum.com/forum/clientscript/vbulletin_css/style-46aa44cc-00113.css"); Insulation - batts vs. rolls - am I missing something? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 06-18-2012, 01:49 PM - Thread Starter
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
Ok, so I've started to shop for insulation and don't know if I should go with Rolls or Batts. It seems like 1 roll covers approx. 49 sq.ft for about $10 or 21 cents/sq.ft. 1 bag of batts on the other hand cover 77sq.ft. for about $42, or 55 cents/sq.ft. Why wouldn't I just buy rolls? Sure, I'd have to cut it to length, but since my joists and walls are longer/taller than 8ft. anyway, there be some cutting of batts as well.
Am I missing something?
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #2 of 7 Old 06-18-2012, 01:59 PM
tlogan6797's Avatar
Quoted: 105 Post(s)
Liked: 131
If your wall are taller than 8', I'd go with the rolls. Ultimately there's less waste. MY walls were less then 8 feet so it made sense to me to use the rolls since I would have had to cut every one anyway. You would have to put up a full batt and then a fill piece in every stud bay, so you'll be doing a lot of cutting, too. I'd just go with the roll. Plus, I think they are easier to handle while transporting, etc.
Tom Logan
Need motivation? Get LOGANED
tlogan6797 is offline
post #3 of 7 Old 06-18-2012, 05:12 PM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 180
You pay about 50% more for batts. Your .21 cents vs .55 cents doesn't match what my pricing shows; are you sure you are comparing the same thickness?
It's just a question of time and labor. Percentage-wise it's a big increase, but for the typical theater it's probably less than $100 difference.
I think the ease of use and time savings are worth it, but YMMV. If saving money is top priority then I would go with the rolls.
Tim
Edit: One other thing with the batts.. I just picked up some R-19 and on the new JM batts they are pre-split so you can tear them lengthwise. Depending on how you tear you can get 3", 7", 8" 10" etc.. pretty cool.
Mr.Tim is offline
post #4 of 7 Old 06-18-2012, 09:39 PM - Thread Starter
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
I thought so:
This is 15"x32ft or 48.75 sq.ft for $9.98
http://www.homedepot.com/Building-Materials-Insulation-Fiberglass/h_d1/N-5yc1vZbay7/R-202585902/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051
This is 8x 15"x7.75' batts or 77.5sq.ft for $42.91
http://www.homedepot.com/Building-Materials-Insulation-Fiberglass/h_d1/N-5yc1vZbay7/R-202585871/h_d2/ProductDisplay?catalogId=10053&langId=-1&storeId=10051#customer_reviews
blipszyc is offline
post #5 of 7 Old 06-19-2012, 04:54 AM
Mr.Tim's Avatar
Quoted: 277 Post(s)
Liked: 180
Ouch, that *is* expensive for batts! On the other hand, that is *cheap* for a roll!
IIRC, I got my R-19 unfaced batts (87+ sq.ft) for $39.00.
Mr.Tim is offline
post #6 of 7 Old 06-19-2012, 06:46 AM
Crash11's Avatar
Quoted: 23 Post(s)
Yeah this is a no-brainer. Just wear gloves and cut up the rolls.
Crash11 is offline
post #7 of 7 Old 06-21-2012, 08:51 AM
cybrsage's Avatar
Liked: 154
You pay for not having to cut the roll into batts yourself. Just cut them and save the cash, as others have said.
A tip for cutting the roll is to put a scrap piece of plywood under your cutting area, then use a wide level (or anything wide and flat) to push the roll down. This makes it a LOT easier to cut.
cybrsage is offline
