Riser Construction Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-29-2012, 01:21 PM - Thread Starter
Anon E Maus's Avatar
I've searched the forums for an answer to my question, but there doesn't seem to be any consensus. Basically, what are the current thoughts on anchoring a riser to floor? I think that the weight of the lumber, seats, and people should be sufficient to keep it from shifting but am a little concerned about some movement. We have ripped up the carpet to install the riser, so don't want any movement to adversely affect the carpet installation over time. Is there any drawback to anchoring the riser to the floor? Thank you!
Anon E Maus is offline
post #2 of 3 Old 06-29-2012, 02:20 PM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 139
No need to anchor it. It won't go anywhere.
Spaceman is offline
post #3 of 3 Old 06-29-2012, 04:20 PM
benclement11's Avatar
Not sure how big yours is(riser that is), but I just build a 12'x8' riser last week and it isn't going anywhere. I used 2x12 on the outsides and 2x8 as joists. I insulated it and used 2 layers of 7/16 OSB. The thing isn't moving. Even if yours is considerably smaller...it won't move.
Panasonic P60ST50-Yamaha RX-V467 receiver-Sony PS3-Velodyne SMS-1-Canton 430 mains, 455 center and 402 surrounds-Rythmik FV15HP subwoofer- Pro-ject Debut III turntable- I also have a pair of Mark K's DIY design, the ER18DXT's
My humble entertainment room
http://www.avsforum.com/t/1417652/midwest...
benclement11 is offline
