Going to start the project of turning basement into theater room. - Page 6 - AVS Forum | Home Theater Discussions And Reviews
post #151 of 166 Old 12-23-2012, 06:59 PM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Ok guys been some time. Crazy for the holiday and been getting some progress.
I received my seats from Roman. Was a pleasure to deal with. Answered all my questions. We have been emailing back and forth for like a month. Very very happy with the seats. Only negative part is the brown swivel trays. Not Romans fault that berkline made them for these seats. I hate Brown. Had anyone refinished there trays?
Holiday121 is offline
post #152 of 166 Old 12-23-2012, 07:01 PM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
I finally mounted my projector as well. I do not like the way it looks so I think I'm going to enclose it.
post #153 of 166 Old 12-23-2012, 08:16 PM
tbraden32's Avatar
^i agree with you on that too
tbraden32 is offline
post #154 of 166 Old 12-23-2012, 08:26 PM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
I figured the black flat paint would be enough for my ceiling and screen wall. That is a big go. When my projector is on I have reflection halfway along my ceiling frown.gif
post #155 of 166 Old 12-26-2012, 10:01 PM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
So after running some audyssey on my 819 I am pretty impressed by the sound. Only thing is my center channel is hard to understand sometimes when other stuff is going on.
I got a popcorn maker for Christmas wil lnpost pics once I get it together
post #156 of 166 Old 12-27-2012, 10:44 AM
pdxfj's Avatar
Quoted: 22 Post(s)
Liked: 31
After you run Audyssey Dynamic EQ, is on by default which can do funky things. Hit the home button on your remote, then go into Audio and scroll around and make sure Dynamic EQ, Dynamic Volume and Re-Eq are turned off. Also if you're viewing a BD with a Dolby TrueHD soundtrack you'll want to turn off "Late Night".
If after all of that you're still not happy, run Audyssey again. Also check out the Audyssey thread for help on microphone placement.
I also received a popcorn machine for Christmas. Even though I've got a ways to go on my theater it won't stop me of "experimenting" with fresh popcorn. smile.gif
pdxfj is offline
post #157 of 166 Old 12-27-2012, 05:27 PM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
I will try that this weekend. I'm off work so I will be able to get some more done .
Do you have a thread open
post #158 of 166 Old 12-28-2012, 06:00 AM
rmajor55's Avatar
Great build
I love the look of your curtains.....Something I thought I would never say......especially to another man.
Keep up the good work.
Robin Major
I never know what to put here.<---- Soon to be build thread.
rmajor55 is offline
post #159 of 166 Old 01-10-2013, 06:46 PM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Some updated pics. I ended up getting some triple black velvet from joann fabrics with a coupon at 7 bucks a yard. My bad since I was able to get it right the. And there. I started by doing the sides 5 feet out and the ceiling so far
post #160 of 166 Old 04-29-2013, 06:42 AM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
Sorry have not updated been rel busy lately. Nothing has chaned in the basement. I had to start concentrating on my patio outside and Saving the money.
I decided that I don't like how my towers look for my side and rear channels. I am sure they are overkill as well. The bad part is for my martin Logan setup the side and rears are just as expensive as the towers.
Any opinions on mismatching my front martin Logan's to the rear and side surrounds? Maybe something like klipsch ? Or any suggestions? For some odd reason I think I might be better off mounting rear channels behind me up high on the wall. Been trying to read alot about dipole and bipole Speakers but not really sure if I would benefit from it.
Any suggestions guys
post #161 of 166 Old 04-29-2013, 11:50 AM
djkest's Avatar
Quoted: 26 Post(s)
Liked: 39
Here's a suggestion!
http://www.diysoundgroup.com/waveguide-speaker-kits/fusion-series-kits/fusion8-kit.html
$161 each speaker, optional fully cut cabinet for $25
Although if you made those, you might like them so much you start using them for your mains. It's high sensitivity which means you only need a handful of watts for your normal listening levels, and the waveguide controls off-axis response.
djkest is offline
post #162 of 166 Old 04-29-2013, 12:00 PM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
I never made a DIY speaker . Thanks for the info but why would these be better off then buying a set
post #163 of 166 Old 04-29-2013, 11:32 PM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
I'm starting to think I might benefit more from a 5.1 setup. My sides are about 2 feet in front of me. All speakers are at ear height in which might be another problem. Just not happy with the sound going to try some things this weekend
post #164 of 166 Old 05-10-2013, 11:32 PM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
So I decided to take the center chanel off my wall. It sounded better but since I am far from a handy man i put a few holes in the wall when mounting
post #165 of 166 Old 05-10-2013, 11:34 PM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
And decided to make this for it to go on hopefully it will be ok
post #166 of 166 Old 06-04-2013, 06:33 AM - Thread Starter
Holiday121's Avatar
Quoted: 540 Post(s)
Liked: 147
So a update. I decided to get rid of the stupid shelf.
Projectors , Jvc Dla Rs45 Home Theater Projector 1080p Hdmi , Epson Powerlite Pro Cinema 6010 Projector
