fake / false wall questions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 07-09-2012, 11:38 AM - Thread Starter
zhamid's Avatar
Hi all,
After days of researching meditating, measuring, praying and buying, I've decided to build an acoustically transparent fake wall to put my speakers behind. I plan to use 2x2s to make a frame where I'll attach my (acoustically transparent) projection screen and acoustically transparent speaker fabric.
The problem is, I can't figure out how to make the wall "moveable". What I mean is that I want to be able to move the wall and get behind it to do stuff. I wont be doing it often (once everything is setup I wont have a reason to go back. May be if a speaker dies and has to be replaced), but I do need access.
How do you guys handle it? Are there instructions somewhere? I can potentially build a door. Another option was to drill 2x2s in the wall, put Velcro on them and then use Velcro to "stick" panels onto the frame. That way I can remove those panels and get behind to get stuff done.
I dont care if access is comfortable. It just has to be (barely) big enough for me to get behind and to potentially move speakers / receiver etc. in and out.
Building a budget HT that will look and perform anything but budget.
zhamid is offline
post #2 of 7 Old 07-09-2012, 11:56 AM
Spaceman's Avatar
Quoted: 43 Post(s)
Liked: 150
Spaceman is offline
post #3 of 7 Old 07-09-2012, 04:17 PM
dwightp's Avatar
Some folks have mounted the screen on hinges so they can swing the screen up to get access to the space behind the false wall.
dwightp is offline
post #4 of 7 Old 07-09-2012, 07:21 PM
Brad Horstkotte's Avatar
Liked: 73
With the left, right and bottom panels on (didn't have the top in place in this picture). Left and right are friction fit between the stage carpet and soffit / bulkhead fabric; bottom is friction fit between the stage carpet and the bottom velvet of the screen frame (and the left and right panels).
Brad Horstkotte is offline
post #5 of 7 Old 07-10-2012, 12:47 AM - Thread Starter
zhamid's Avatar
Now why didn't I think of that! I am so doing it. Thanks.
zhamid is offline
post #6 of 7 Old 07-10-2012, 09:07 AM
damelon's Avatar
Liked: 286
I am using BIG's minimalist screen wall, and it was VERY easy to install, though I'll admit the hinges idea is kind of cool. When adjusting my subs I wish there was an easier way to get back there, but you rarely ever need to do so.
damelon is offline
post #7 of 7 Old 07-10-2012, 02:26 PM
GPowers's Avatar
Quoted: 50 Post(s)
Liked: 64
My screen is pressure fitted into a framed opening. To gain access to the stuff behind the screen I just remove it.
GPowers is offline
