Question about panels on front of stage walls - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 07-20-2012, 04:27 PM - Thread Starter
str1der's Avatar
Quoted: 28 Post(s)
I've got a couple questions about the front panels that are covering peoples screen walls. I have the main frame for my shadow box/stage wall. I bought the speaker cloth but I'm curious about what most people are using to create the frames that they are attaching to the front. Are they making them out of 1" plywood? 2X2 pine? or something else? How are you joining the corners?
Ken
str1der is offline
post #2 of 5 Old 07-20-2012, 05:00 PM
Quoted: 3267 Post(s)
Liked: 2751
I get the finger joined 5/4 pre-primed exterior trim boards that Home Depot sells and rip them to the desired width. They come straight and stay straight. I drill pilot holes and then screw them together with long deck screws using butt joints.
post #3 of 5 Old 07-21-2012, 04:15 PM - Thread Starter
str1der's Avatar
Quoted: 28 Post(s)
So is there a particular reason why you buy wide boards and rip them instead of just standardizing on a 2" wide board cut to length? Did you use any glue or just screws in the coreners.
Is this pretty much what everyone does?
str1der is offline
post #4 of 5 Old 07-21-2012, 04:35 PM
willscam's Avatar
I bought the 2" width finger joined pre-primed trim boards. They worked great. I'm too impatient to go about ripping boards.
"Trying is the first step towards failure" - Homer Simpson
willscam is offline
post #5 of 5 Old 07-21-2012, 04:40 PM
Liked: 2751
I usually rip the 4 inch boards in half. They don't stock 2 inch boards here.
