BIGmouthinDC - Summer Fun, Just 10 minutes down the Parkway - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 7Likes
post #181 of 269 Old 11-03-2012, 06:06 PM - Thread Starter
Quoted: 3255 Post(s)
Liked: 2743
The artsy fartsy part is 14 inches. Then there is an inch something black border.
post #182 of 269 Old 11-03-2012, 07:58 PM
applegarth's Avatar
Jeff, does the layout look familiar? I relied heavily on the basic layout from your place except no false wall for the screen, Just not enough room.
On the HVLP sprayer it worked like a champ the beauty is that there are very few parts to clean, no hose to clean. The overspray was minimal and I just sprayed them all on my workbench with a sheet of plastic. My problem was all those nooks and crannies that would have been impossible with a brush required quite of few turns of each piece and a lot of angling of the gun to shoot into every corner, But it worked and I'm going to keep in in my truck.
Yes it does look familiar. Brandon actually said that prior to me commenting. I have considered a HVLP for all the reasons you mentioned. If you want to stop by and help me finish on your way let me know. Chris says she will cook!!
applegarth is offline
post #183 of 269 Old 11-03-2012, 10:15 PM
cdika17's Avatar
Liked: 27
Originally Posted by cdika17 View Post
Is the carpet, Platinum Plus Wondrous from HD?
Yay or nay?
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #184 of 269 Old 11-04-2012, 05:08 AM - Thread Starter
Liked: 2743
It was from a local carpet store, I think it was a Shaw carpet. If it is critical I can stop in when I get home the end of the month.
post #185 of 269 Old 11-04-2012, 09:12 AM
cdika17's Avatar
Liked: 27
No worries, pretty sure its the one and also the one ill be using! smile.gif
Chase "Fetch"
Old Theater Build
New House Build
cdika17 is offline
post #186 of 269 Old 11-04-2012, 10:18 PM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
Big - Are these the Utilitech Accent 4" lights? if so - what bulbs are you using in these and are they OK to install in MDF soffits?
jimmyk36 is offline
post #187 of 269 Old 11-05-2012, 02:28 AM - Thread Starter
Liked: 2743
I used 35 watt frosted GU10 bulbs on the perimeter but upped it to 50 over the screen in the 4 inch Utilitech cans. The picture you posted is a 4 inch Halo can with regular Edison base blubs I used those over the seating. I think I used 65 watt in those , can't remember.
post #188 of 269 Old 12-08-2012, 11:34 AM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
Well I have my design from the Erskine Group - I keep coming back to this thread - I really like the look of the theater.
Couple more questions - what is the ceiling height in this room? In particular - the screen wall?
Also - what speakers did you end up going with?
Jim
jimmyk36 is offline
post #189 of 269 Old 12-08-2012, 12:34 PM
ADDUpstate's Avatar
I forgot to mention that I often hang a blind in the closed position so it looks 100% natural on the outside. If you ever want to open it up and re-purpose the room the framing is in place.
I have black out window tint on my two windows in the theater. Then plugged and buried. Works well too.
ADDUpstate is offline
post #190 of 269 Old 12-08-2012, 12:39 PM
allybuck64's Avatar
What step light did you use, where did you get them. Lowes or HD only has outdoor deck step lights.
allybuck64 is offline
post #191 of 269 Old 12-08-2012, 04:04 PM - Thread Starter
Liked: 2743
Ally from memory they are Royal Pacific step lights from Wayfair. basically a Christmas light bulb holder that fits in a single gang box. Comes with both covers, vertical and horizontal. Does not give off a lot of light if that is what you are looking for.
Back on my laptop and found the link
http://www.wayfair.com/Royal-Pacific-Mini-Step-Light-in-White-8905WH-RYP2559.html
post #192 of 269 Old 12-09-2012, 09:49 AM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
Big - what was the ceiling height in this room?
Jim
jimmyk36 is offline
post #193 of 269 Old 12-09-2012, 10:53 AM - Thread Starter
Liked: 2743
post #194 of 269 Old 12-10-2012, 09:10 AM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
jimmyk36 is offline
post #195 of 269 Old 12-15-2012, 01:44 PM
jimmyk36's Avatar
Quoted: 80 Post(s)
Liked: 35
quote]
Big - Couple questions - I am assuming that is MDF on the lower part of the wall painted black? What is the height of these wood panels?
Now the panels that get installed above this area - I believe you said they are ~20" high?
Jim
jimmyk36 is offline
post #196 of 269 Old 12-15-2012, 07:04 PM
macfan's Avatar
Quoted: 23 Post(s)
Liked: 43
BIG:
Just wanted to thank you for the step light link. I just received my shipment of them yesterday. They are great and you can't beat the price. AVS needs to start a thread where these great finds and deals can be posted/listed.
macfan is offline
post #197 of 269 Old 12-16-2012, 07:37 PM - Thread Starter
Liked: 2743
Jim just eyeball it, I don't remember but they had to be taller than the top of the existing outlets.
post #198 of 269 Old 12-21-2012, 08:42 PM
BIG INJUN CHIEF's Avatar
Liked: 194
Amazing thread. A bit curious how you connected the rope lights. Light switch to a switched receptacle enclosed in the larger soffit. Yes?
BIG INJUN CHIEF is offline
post #199 of 269 Old 12-22-2012, 05:38 AM - Thread Starter
Liked: 2743
post #200 of 269 Old 12-22-2012, 07:42 AM
Skip-B's Avatar
Another Great build and very impressive. I am wondering though, I see so many of these builds that get finished and I am sure that they sound great. However, few people discuss just how well they have managed to keep sound inside their home theater. Big can you comment on some of the builds that you have done? Obviously you are comfortable in your sound proofing approach as you use a similar approach on most of your builds, but how much sound is usually heard upstairs in these builds? I am still kicking around building under the bedrooms or on the other side of the house.
Skip-B is offline
post #201 of 269 Old 12-22-2012, 10:04 AM
Liked: 194
No, hard wired
Excellent. THANK YOU!
post #202 of 269 Old 01-31-2013, 02:32 PM
anubis05's Avatar
was working on the pilasters for the room today and should have done soon, then some Final Pictures. Until then here is the basic layout and the most recent shots I have on my camera
BIG,
Isn't 11.5' from screen to first row a little too close, how was the experience in first row? Also, with just 23' length, the bar section in back must be just 5 feet, wonder if that would fit any stools. And if this layout did work then this is very optimal utilization of space.
Awesome work!
anubis05 is offline
post #203 of 269 Old 02-03-2013, 03:12 PM
landshark1's Avatar
Quoted: 18 Post(s)
Liked: 62
Originally Posted by anubis05 View Post
BIG,
Awesome work!
In my 1st HT, I was 10' away from a 100" diagonal 16:9 screen, and both me & my wife feels like we could go for a 110" especially for scope movies. Therefore, I would say 11.5' for a 116" diagonal 16:9 screen is a pretty good size for both movie & TV/sports. But again, everyone's preference & vision is difference tho. cool.gif
landshark1 is offline
post #204 of 269 Old 02-05-2013, 08:00 AM
anubis05's Avatar
Thanks landshark1.
This forum and especially BIG's theater build threads are inspiring me to get something nice done myself. I am still in process of absorbing all the knowledge in this forum.
anubis05 is offline
post #205 of 269 Old 02-07-2013, 04:33 AM
elmalloc's Avatar
Quoted: 27 Post(s)
Liked: 42
I'm 11ft away from eye to 175" scope screen (6ft height IIRC). No way too close for me. I think some viewers want another foot or two though.
There is no better konwledge than making mistakes. I have redone my theater 2 or 3 times already, I demolished my basement and I'm working from scratch now. You will make mistakes. Stop reading and start hammering.
Current Projects:
ON HOLD - Building Home Gym.
elmalloc is offline
post #206 of 269 Old 02-07-2013, 04:41 AM
Gary Lightfoot's Avatar
Quoted: 593 Post(s)
Liked: 345
Gary
Who says Cameron is "right" and why do we care about him so much - lol!
I trust Gary Lightfoot more than James Cameron.
Gary Lightfoot is online now
post #207 of 269 Old 02-14-2013, 01:43 AM
rmajor55's Avatar
Beautiful build Mr. Big.
Love the bevel where the seams of the red panels come together and your pilaster design is amazing. Yet another build that I will shamelessly steal some ideas from wink.gif
Robin Major
I never know what to put here.<---- Soon to be build thread.
rmajor55 is offline
post #208 of 269 Old 02-14-2013, 06:34 AM - Thread Starter
Liked: 2743
Thanks, steal away. That's how I come up with all my ideas.
post #209 of 269 Old 05-29-2013, 12:21 PM
AV_Integrated's Avatar
Quoted: 972 Post(s)
Liked: 718
Originally Posted by jimmyk36 View Post
What kind of speakers were used for this build?
Also - is there a list of the AV equipment used?
A bit off on time on this response, but I haven't been active on these forums for a while.
The speakers are Golden Ear for the main speakers, I need to check, but it may be Kef speakers for the center and surrounds (they blended well), and Epik subwoofer. Denon AVR-3313CI receiver w/Emotiva XPA-5 amplifier. Using the Denon internal amp for the surround back speakers. Fios, Oppo BD player (103), client furnished HTPC (no idea if that is working yet). Crestron MC2W control system w/MX-850 remote control, and JVC RS-46 projector without the 3D option at this point. Screen by Carada. All equipment housed in a Middle Atlantic rack. Lighting is controlled by Crestron's version of the Grafik eye.
I will post a complete list if the equipment this evening if I get a chance.
This was my first time working with Big, and it was an excellent experience. Most people just want to throw up some drywall and paint and call it a 'theater', and while they often look very nice, it was truly incredibly to work with both a client who knew that they were after a top shelf final setup, and a builder who had the experience to deliver it all in spades. This was one of the smoothest installation projects I have ever worked on, and Big was a 'big' reason for it going so well.
AV Integrated - Theater, whole house audio, and technology installation in the Washington DC metro area.
AV_Integrated is online now
post #210 of 269 Old 05-31-2013, 12:39 PM
JWagstaff's Avatar
Quoted: 28 Post(s)
Liked: 71
I really love the color scheme of this theater. And the panels look amazing too! One of the best looking theaters I've seen on here.
lz7j likes this.
JWagstaff is offline
