The Big Bay Home Theatre - Page 12 - AVS Forum
post #331 of 352 Old 05-07-2014, 04:45 AM
AnalysisParalysis Analyst
TMcG's Avatar
Quoted: 216 Post(s)
Liked: 279
Two racks side-by-side would be about the same width as your sump room....something to think about if you keep them sideways and just forward of that one electrical panel mounted on the long wall to the left. But to get what you are looking for, the only real option is the Middle Atlantic AXS rack (or similar from another company) which you could mount immediately to the left once you walk into the room so the equipment front is facing you. That would also look the nicest IMHO. The racks are a bit spendy, but not outrageous.
http://www.middleatlantic.com/products/racks-enclosures/slide-out-racks/axs-series-in-wall-slide-out-rack.aspx
TMcG is offline
post #332 of 352 Old 05-07-2014, 06:10 AM - Thread Starter
memmo's Avatar
If I opt to not do the built-ins, I would simply finish off the cubby as nice as possible, trim it out and then have 2 freestanding racks sitting side by side a few inches from the wall.
I already have a slim-5 that I found cheaply on Craigslist but I don't see any way to cleanly build it in (ie. frame a small wall to conceal it).
The Big Bay Home Theater Build Thread
My personal theater build on Kempenfelt Bay, Barrie Ontario Canada
memmo is offline
post #333 of 352 Old 05-07-2014, 08:01 AM - Thread Starter
memmo's Avatar
What about framing it out slightly like this?
With something like this, after drywall, it would leave about 32.5" to walk around back. This is assuming Slim-5 racks at 19.25" each and then 3.75" on each side to create the "closet" look.
Having the rack sit 3.5" out from the left wall, also provides room for cabling etc.
memmo is offline
post #334 of 352 Old 05-07-2014, 08:26 AM
TMcG's Avatar
Quoted: 216 Post(s)
Liked: 279
Yes, that render is precisely what I was talking about in my comment above. Alternatively, you could either buy the Middle Atlantic caster wheels for your Slim5 rack: http://www.bhphotovideo.com/bnh/controller/home?O=&sku=416971&gclid=CIj0oaiPmr4CFe99OgodbF4A_w&Q=&is=REG&A=details or buy the entire caster base: http://www.showmecables.com/product/Middle-Atlantic-CBS-5-Fine-Floor-Slim-Caster-Base-20in.aspx?utm_source=google&utm_medium=cse&utm_campaign=CBS-5R&zmam=49733141&zmac=5&zmas=1&zmap=CBS-5R&gclid=CKz_57yPmr4CFQKhOgodPnQA6Q
I personally like the built-in look, but I see the advantage of having these racks off the the immediate left and pulled out only when needed.
TMcG is offline
post #335 of 352 Old 05-07-2014, 08:29 AM - Thread Starter
memmo's Avatar
I like the built in look too -- and its much cheaper -- I can frame and cover it using scraps. It also gets the rack 10" off the floor which is good incase any water were ever a concern. It hides the cubby, which I like aesthetically, it just means I'll have to reach through the rack in order to access it. Not a huge deal.
memmo is offline
post #336 of 352 Old 05-07-2014, 09:44 AM
AVS Club Gold
LeBon's Avatar
Quoted: 24 Post(s)
Liked: 30
I'm not a big fan of movable racks. I don't like flexing the wiring all the time, and allowing cable loops so you can pull out the rack, etc. I like your idea of framing them in so you have rear access. You can also get side and/or back panels, if you don't want to frame them.
LeBon is offline
post #337 of 352 Old 05-07-2014, 10:12 AM
TMcG's Avatar
Quoted: 216 Post(s)
Liked: 279
+1, especially with the Slim 5 which is about the thinnest rack Middle Atlantic makes. You can buy side panels....but have you seen the pricing on those things?? About $225 per pair at discount (and unfortunately Memmo could only use one because the other side panel would block the wiring access) - talk about highway robbery!
TMcG is offline
post #338 of 352 Old 05-21-2014, 04:07 PM - Thread Starter
memmo's Avatar
Had the equipment room boarded today. 2 guys, 1 hour 20 minutes. What a difference pros make!
They'll be back tomorrow to start taping. After they've got everything finished, I'll frame out the platform for the 2 slim 5 racks and do a bit more drywall. I wanted the platform to be built within the "shell".
memmo is offline
post #339 of 352 Old 05-21-2014, 04:51 PM
Tedd's Avatar
Quoted: 37 Post(s)
Liked: 63
You could make side panels for a Slim5 out of plywood, and attach with screws, from the interior.
If those are to to be actively cooled racks, I have to wonder if a panel separating the racks might be in order?
Tedd is offline
post #340 of 352 Old 05-21-2014, 04:59 PM - Thread Starter
memmo's Avatar
The thing is.. I want to hide the raw opening in the wall and have a more built in look. I don't find the slim 5's (even with a panel on the end) particularly attractive.
There is a large vent directly above where the racks will sit. It's connected via 6" to a Fantech fan. The fan is controlled by a Cool Components thermostat which is wall mounted, but has a remote sensor which I'll stick at the top of the rack.
memmo is offline
post #341 of 352 Old 05-22-2014, 09:33 AM - Thread Starter
memmo's Avatar
Playing with the placement of the racks...
memmo is offline
post #342 of 352 Old 05-23-2014, 04:17 AM
Tedd's Avatar
Quoted: 37 Post(s)
Liked: 63
I understand the desire to hide the side wall recess. I have done something very similar, except it is a series of recessed electrical boxes.
If you used stained dimensional lumber, you could use those as the finish. Something like Zuluwalker's rack, except you'll have Slim5's.
Tedd is offline
post #343 of 352 Old 05-23-2014, 04:25 AM - Thread Starter
memmo's Avatar
I'm not sure I would stain dimensional lumber but you did perhaps spark another idea. After framing, I could clad it in MDF that I would paint white -- and on the end piece, I could continue the panel theme I'm doing in the theater. So rather than drywall painted the same as the room, I'd use MDF to make it look like cabinetry. Hrmmm...
Though drywall might be easier in the sense that any gaps etc would be filled with mud smile.gif lol
memmo is offline
post #344 of 352 Old 05-23-2014, 04:45 AM
Tedd's Avatar
Quoted: 37 Post(s)
Liked: 63
Why would you have gaps? I would secure the two verticals to the wall, then put the inside alternating holes on the sides of the Slim5 to use, by attaching the
first rack to those verticals, then add another set of verticals, then the second Slim5 secured, then an end panel. (Using those holes would have all fasteners
hidden from view.) The end could be drywall with matching end verticals routed to hide however you decide to finish the end treatment.
You would also gain a center vertical cable run between the racks. If the center divider is wider, maybe you tuck a vertical run of electrical outlets there?
(a top down view:)
Created with GIMP
Tedd is offline
post #345 of 352 Old 05-23-2014, 04:55 AM - Thread Starter
memmo's Avatar
My racks will be butted up against one another since I don't have a lot of extra room to play with but yah, something like that could work.
memmo is offline
post #346 of 352 Old 05-23-2014, 08:18 AM
AVS Club Gold
LeBon's Avatar
Quoted: 24 Post(s)
Liked: 30
I used the MA cable chase to connect two Slim-5 racks ( http://middleatlantic.com/products/accessories/external-vertical-cable-ducts/cc-series-vertical-cable-chases.aspx?utm_source=/products/accessories/external-vertical-cable-ducts/cc-series-vertical-cable-chases&utm_medium=redirect )
I found that butting the 2 racks directly together didn't look good because the Slim-5s are "frameless" and front panels in adjacent racks didn't look good with no trim. Also, the space between racks is very useful for access to screw things to the sides, and for the cable chase.
LeBon is offline
post #347 of 352 Old 05-23-2014, 08:23 AM - Thread Starter
memmo's Avatar
With some slight edits, I could accommodate the chase.. something like this:
This pushes the left rack out 2.25" from the wall. I can bring bundles of cables in directly on the side and if I'm smart about power etc, the power located in there won't be a problem either.
Hrmm... now if I go this route, drywall probably seems like the best option.
memmo is offline
post #348 of 352 Old 05-23-2014, 08:49 AM
AVS Club Gold
LeBon's Avatar
Quoted: 24 Post(s)
Liked: 30
If your layout is like what you show in Post 333, it doesn't seem like you need to worry about a slightly narrow access passageway. I have two side-by-side Slim-5 racks, framed in, with a 24-inch wide door immediately to their right, which I use for access to the small room behind the racks. Works fine, but of course I'm the only one who ever uses the door.
LeBon is offline
post #349 of 352 Old 08-19-2014, 01:17 PM
BllDo's Avatar
Quoted: 57 Post(s)
Liked: 75
Any updates?
Is it solipsistic in here, or is it just me?
BllDo is offline
post #350 of 352 Old 08-19-2014, 01:43 PM - Thread Starter
memmo's Avatar
Funny you should ask... After talking most of the summer off, I got back at it last weekend. I got some drywall up on the outside of the theater and then started on the custom door install. Went pretty well. Should have pics shortly. After the door is installed, my focus will change to finishing the wainscotting, then prepping and painting. Then the crown for the rope lighting. My mother is visiting in September sometime and she's a champ with the fabric so I suspect I'll get the bulk of the walls covered then also.
memmo is offline
post #351 of 352 Old 08-28-2014, 06:55 AM
Mr.Tim's Avatar
Liked: 51
Just sayin...
Hope everything is well.
Tim
Mr.Tim is offline
post #352 of 352 Old 08-28-2014, 07:03 AM - Thread Starter
memmo's Avatar
Hey now!
I'm taking next week off... hope to:
Finish the electrical in the remainder of the basement
Finish hanging the theater door
Finish the wainscot/trim
Prep and paint the wainscot and columns
Install the crown light tray
MAYBE get a start on the fabric... I'm itching and my folks will be here for a day or two.. my mom is a champ with the fabric panels
So... hopefully soon!
memmo is offline
User Tag List
