New house bought, HT room begins. - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 07-30-2012, 08:04 PM - Thread Starter
TK Doom's Avatar
So i'm in escrow, and have a 27x16 room that i will be converting to a dedicated home theater.
the only "flaw" is that it has vaulted ceilings, are there any challenges that will exist to projector mounting issues?
thanks.
TK Doom
Unreal Tournament Forever
Project Gotham Racing too!
TK Doom is offline
post #2 of 6 Old 08-04-2012, 11:06 PM
awake33's Avatar
I'm no expert, and my vaulted theater room is only 18'x15.5', but depending on the projector you'll be using (mine is a JVC RS-45) and which wall will have the screen, you could wall mount it. My screen is on one of the 18' walls with the projector mount 15' back. It ends up being about 13.5' from the lens to screen.
It took many hours of searching to find this; it seems not many people choose to mount projectors on a wall eek.gif [http://www.chiefmfg.com/Series/WM1] I paired it with the RPA bracket made specifically for the JVC.
It looks much smaller on the website than I expected; this thing is a beast. That's a good thing though, so is the JVC. smile.gif I feel very comfortable hanging a big projector on this mount because I think they were ultra conservative in their weight rating.
I'd include a picture but I'm not home; maybe later.
awake33 is offline
post #3 of 6 Old 08-05-2012, 05:16 PM - Thread Starter
TK Doom's Avatar
Wall mounting would probably not be feasible, as my theater will be going the long way, using about 2/3rds of the room most likely.
Thanks for the reply though! I just figured they had some sort of solution, a angled ceiling mount is definitely a niche item.
TK Doom
TK Doom is offline
post #4 of 6 Old 08-05-2012, 06:57 PM
Quoted: 3257 Post(s)
Liked: 2743
the angled ceiling mounting plate has been in the Chief catalog a long time.
post #5 of 6 Old 08-05-2012, 09:34 PM - Thread Starter
TK Doom's Avatar
Thanks...I am new to this part of HT.
Looks a little chincy to hold a $4-6k projector.
I'll check it out.
TK Doom
TK Doom is offline
post #6 of 6 Old 08-05-2012, 10:27 PM
Brad Horstkotte's Avatar
Liked: 68
Or if you don't mind some extra work, you could do something like Rich Harkness' theater, where he has his projector mounted on a telescoping lift behind the couch.
Brad Horstkotte is offline
