Rigidity of Theatre Dimensions - AVS Forum | Home Theater Discussions And Reviews
post #1 of 6 Old 08-14-2012, 08:12 PM - Thread Starter
killswitch1968's Avatar
I'm currently planning a basement for a new house. I have a 9' house but due to the layout of the main floor I'm having a time avoiding a width of 18'. I'm of course trying hard to avoid a common denominator but it's a challenge.
Should I try to avoid 18' by a full foot? What about 17'6"? What about 17'11"? I know it sounds ridiculous but it's been the worst game of Tetris to try and fit everything in! Thanks!
killswitch1968 is offline
post #2 of 6 Old 08-14-2012, 08:29 PM
Quoted: 3265 Post(s)
Liked: 2751
I wouldn't give up a foot of length or width just because on paper you think it will be a 9 ft ceiling. By the time you add furring to work around that gas pipe running smack down the middle of the room, and you add soundproofing clips and channel that room might end up being 8 1/2 ft. Get the house built and you can always adjust a basement wall later.
killswitch1968 likes this.
post #3 of 6 Old 08-14-2012, 08:56 PM
SierraMikeBravo's Avatar
Quoted: 338 Post(s)
Liked: 214
There are NO golden ratios. Don't worry about modal issues at the moment. Make your dimensions the largest you can afford. Square footage is leaps and bounds more important than modal issues.
Shawn Byrne
CEDIA Certified Professional EST II - HAA, THX.
Theater Design Information and Examples
skbyrne@sbcglobal.net
shawn@questai.com
SierraMikeBravo is online now
post #4 of 6 Old 08-15-2012, 09:43 AM
FOH
FOH's Avatar
Quoted: 38 Post(s)
Liked: 234
Admittedly, SMB and DC possess agreat skill set and a significant amount of experience, and they are vastly more experienced than myself in this area. But I do think it's prudent to proceed as you suspected,...with an eye on potential dimensional issues. Isn't it true that finished surface dimensions that are multiples of one another (16x24x8), should be avoided if there are options?
Yes, there are methods and approaches to mitigate an otherwise "un-golden" ratio'ed room. Extreme example; One could fill an entire boundary will loose-fluffy, scrim it off with AT fabric, hang diffusor/scattering stuff on the AT fabric faux surface,...the system "sees" the bigger, well damped acoustic, the listener experiences the two halves of the Schoeder freq differently. Yes, extreme, just sayin cool.gif it's what I'd do with blank slate and deep pockets.
Best of luck
Active 16.8kw, 7.3 system
(2)Seaton SubM-HP, (4)18" IB
FOH is offline
post #5 of 6 Old 08-15-2012, 10:12 AM - Thread Starter
Thanks very much this is my first built house and theatre, appreciate the advice!
post #6 of 6 Old 08-15-2012, 03:04 PM
dengland's Avatar
Quoted: 21 Post(s)
I think that is a pretty good analogy.
I am right there with you on trying not to screw something up that you may have control over. In some ways, it is almost better to have some hard physical constraints instead of a blank sheet of paper. At least with the constraints, you can say "I did the best with what I had."
I am currently asking my own Noob questions in a different thread ....
dengland is offline
