Double Insulation Question? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 08-16-2012, 12:28 PM - Thread Starter
blipszyc's Avatar
Quoted: 134 Post(s)
Liked: 72
I've got 2 pre-existing walls in my theater area that are were built out of 2x6s and I'm going to be putting a 2x4 wall in front of them to decouple. Do I fill both the 2x6 wall and 2x4 wall with insulation? If so, do I mix R19 and R13, or just use R13 in both?
Similar question for the ceiling - I have a new ceiling that is about 12" below the joists, and runs perpendicular to them. Do I fill the joists with R19 and use R13 between the new 2x4s, or is the R19 in the joists enough? Should the insulation be closer to the floor above or the bottom of the joists?
Visit the Lipszyc Home Theater! 1.0
2.0 done and finally posted! - Theater 2.0
And now...The Queen City Theater (3.0)
blipszyc is offline
post #2 of 3 Old 08-16-2012, 07:35 PM
Shan's Avatar
Dennis said to fill both cavities with insulation when he did my layout. The guides on SoundProofingCompany.com say the same. It should be fine to mix r-values. I can't think of any reason why it would matter. Only drywall the inside wall, however.
Shan
Shan is offline
post #3 of 3 Old 08-17-2012, 07:22 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
Shan
+1
__________________
Ted
The Soundproofing Company
Ted White is offline
