Anyone have any spare GOM 701 they could sell me? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-18-2012, 02:50 AM - Thread Starter
steveg66's Avatar
Hi all --
I'm looking for just a small amount of GOM 701; everywhere I have found that will sell it will only sell 3-5 yards minimum. All I really need is 3 "strips" of the fabric that are just under 12" wide -- i.e. less than a "yard" of material. In fact, I don't even need the full 66" length that is the normal "length" of the fabric, if I understand correctly. I really only need the three pieces to be about 12" wide and 48" long.
As for color, black would work best, but other colors could work, also -- namely darker grays (the colors called "medium gray --298" and "flannel -- 795," and possibly a couple of other colors.
Please let me know if anyone has this amount of material (less than a yard) that they might be willing to sell me. It would be much appreciated!
Steve
steveg66 is offline
post #2 of 7 Old 08-20-2012, 07:00 AM
Spaceman's Avatar
Quoted: 45 Post(s)
Liked: 150
Steve-There is a fabric from Acoustex that is very similar to GOM FR701 that can be ordered in quantities as small as one-half a linear yard. It's pricier than FR701, but not having to order so much waste will probably make it a cheaper option for you. I think there is a $5 surcharge for orders under 2 yards, but it's still worth looking into.
http://www.acoustex.com/Home.html
Spaceman is offline
post #3 of 7 Old 08-20-2012, 07:17 AM
jdanforth's Avatar
Liked: 25
I just finished up my screen wall and have lots of remnants of black GOM FR701. Shoot me a PM with the precise sizes you need and I'll check to see if I have what you need.
jdanforth is offline
post #4 of 7 Old 08-20-2012, 07:19 AM
jdanforth's Avatar
Liked: 25
Or, I could read your whole post and determine that for myself! rolleyes.gif
Three strips of 12x48? I think I've got that. Shoot me the PM anyway so I remember to check tonight when I get home.
post #5 of 7 Old 08-20-2012, 11:47 PM - Thread Starter
steveg66's Avatar
Spaceman --
Thanks for your suggestion -- didn't know about the Acoustex fabric, nor that you could order it in smaller increments. That would be a great option -- but, I think I have found a forum member here that is willing to send me some GOM, so hopefully, problem solved!
Thanks all for your help!
Steve
steveg66 is offline
post #6 of 7 Old 08-21-2012, 06:22 AM
BroncoSport's Avatar
I "might" have some black left over, but it will be a while before I will know for sure. I have a tendancy to over estimate the quanities of everything...just in case! If you don't need it right away, I might "know" in a month or so. I have to make the frames for the screen wall and a rear sofit, still.
I might have brown as well, but don't know how much will be left over after covering my riser wall.
What is you time frame?
BroncoSport is offline
post #7 of 7 Old 08-21-2012, 04:32 PM - Thread Starter
steveg66's Avatar
Bronco -- my time frame is probably 2-4 weeks until I'd be ready to install it (that's about when I will probably have finished building the faux columns that will hide my speakers, and thus need the GOM covering), but I could probably wait, if I had to, to install the GOM itself until later.
Having said that, I've had a few people already offer to sell me enough GOM to meet my needs, so I think I should be good to go. I thank you so much, though, for your offer and willingness to help me out!
Steve
steveg66 is offline
