New Equipment setup\help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 08-20-2012, 09:31 AM - Thread Starter
rekyt's Avatar
I hope this is the right forum to post this question… if not please move.
Do you guys recommend paying an A/V professional to come out to install and calibrate receiver and speakers? I need them to run HDMI about 20 feet through drywall, setup 2 zones, config receiver and speakers. Setup macros on URC MX-450 remote.
I already have Klipsch surround sound speakers (and sub-woof) installed so no retro fit needed. I also already have a telescopic mount installed on wall above fireplace so only need to hang TV.
Labor is about $500-600 to install and setup everything (rate is $75 per hour).
They will match online prices on the following equipment I plan to buy:
-Panny P60ST50
-Yamaha RXA720
-URC MX-450 remote
Using a wireless Uverse receiver.
I would usually try to do this myself but not a lot of time within next few weeks and I want it finished (correctly) by start of football season.
Any input or advice is appreciated. Thank you!
rekyt is offline
