Can you install carpet over laminate? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 08-22-2012, 05:36 PM - Thread Starter
tnthudson's Avatar
OK a question has popped up in the pre-planning phases...I have a finished basement, hardwood laminate (installed on the 'pad' so I guess it's 'floating')....can you install carpet over that laminate when the time comes?
I know you "can," but does it make a difference as far as acoustics are concerned?
thanks
tnthudson is offline
post #2 of 7 Old 08-22-2012, 06:19 PM
gregzoll's Avatar
Liked: 33
I wouldn't. Do not take a shortcut, and just rip up the laminate.
gregzoll is offline
post #3 of 7 Old 08-23-2012, 04:28 AM
Quoted: 3656 Post(s)
Liked: 3107
If the laminate was installed properly and you are not likely to have any moisture issues that might cause it to buckle, it can stay, but I would only bother if it is currently solving some uneven floor issues or you actually plan on returning the room to that laminate in the future. Otherwise it should be a quick project to remove it.
post #4 of 7 Old 08-23-2012, 04:34 AM
hakstone's Avatar
You could go with throw rugs.
hakstone is offline
post #5 of 7 Old 08-23-2012, 05:29 AM - Thread Starter
tnthudson's Avatar
OK guys, thanks so much. Had a pretty long talk with 'the wife' last night about finances, plans, etc. and am probably putting the home theater on hold for a few years...HUGELY disappointed right now. The bright side is that I may move the project upstairs after kid #1 moves out, which is a huge bedroom in our cape cod, probably much better suited to doing a theater the right way.
post #6 of 7 Old 08-23-2012, 06:14 AM
Spaceman's Avatar
Quoted: 41 Post(s)
Liked: 145
That gives you lots of time to plan it out and make it perfect.smile.gif I was in the research/design mode for more than a year and then put everything on hold for another year before really getting into mine.
Spaceman is offline
post #7 of 7 Old 08-23-2012, 06:26 AM - Thread Starter
tnthudson's Avatar
Thanks Spaceman, and thanks for your help. It may be more like a few years, which is the hard part to swallow, but who knows? Either way, you're right, it does give me time to plan, I was pretty rushed if I'd gone with the original plan.
