what wires to run to ceiling mount projector? Ethernet to projector? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 08-28-2012, 10:18 AM - Thread Starter
michelevit's Avatar
My humble home theater project is currently in studs and I’m running all my inwall wiring.
I’m planning on running vga, hdmi, usb and power to my ceiling projector mount. Any purpose to add Ethernet?
Or any other wires? I’d hate to open up the sheetrock in the future just in case I’m forgetting anything.
Thanks in advance.
michelevit is offline
post #2 of 10 Old 08-28-2012, 11:59 AM
jayn_j's Avatar
Quoted: 62 Post(s)
Liked: 41
How long is the run? You may find on a longer run that HDMI is marginal and you might want to run a couple of cat-6 wires up there so you can do HDMI to cat-6 adapters.
jayn_j is offline
post #3 of 10 Old 08-28-2012, 12:25 PM
jautor's Avatar
Quoted: 1215 Post(s)
Liked: 777
Run a flex conduit to the projector location so in the future you can add whatever the next-big-thing is...
But definitely run at least 2 category (cat5e or cat6) wires to the projector. 3 would not be too many, and cat wire is super cheap. Category cable is useful for many things besides Ethernet (which you'll probably want at the projector location, too): HDMI-over-category, RS232, IR repeating, etc.
Jeff
jautor is online now
post #4 of 10 Old 08-28-2012, 12:44 PM - Thread Starter
michelevit's Avatar
the run is short @ 15 feet. I'm currently have a vga projector but will upgrade once the bulb give out. (estimating within 2 years)
Thanks for the advice. I'll pull some ethernet for the future.
post #5 of 10 Old 08-29-2012, 09:07 AM
BroncoSport's Avatar
I ran a 15' HDMI, 3 Cat5e (network connection to projector, backup and one for IR blaster for the anamorphic lens sled) and 6 RG6 coax cables and a 1 1/4" conduit for future proofing.
Now that the projector is mounted and hooked up, I can't find ANY reason for the 6 coax wires. My thought at time of wiring was 2 sets of component cables. Now that I am using a DVDO iScan Duo in the rack, I highly doubt the coax will every get ends cut on them.
BroncoSport is offline
post #6 of 10 Old 08-29-2012, 11:39 AM
Crash11's Avatar
Quoted: 23 Post(s)
If you do run any network cable (cat5 or cat6) run 2 as has been said already.
As far as conduit, I personally like running PVC better than flexible stuff like smurf tube. PVC is way cheaper in large sizes, and since you're not looking for perfect sealing, it's pretty easy to install.
Crash11 is offline
post #7 of 10 Old 08-29-2012, 12:14 PM
phisch's Avatar
Quoted: 58 Post(s)
Liked: 41
I also used PVC pipe (2") to the projector as my conduit run - much cheaper and easy to install. Like the others I ran 3 cat6 cables to the pj, along with my 25' HDMI cable.
phisch is offline
post #8 of 10 Old 08-29-2012, 05:31 PM
GRBoomer's Avatar
I ran:
  • 1 RS232
  • 2 CAT6
  • 2 HDMI
And then an empty 2" conduit.
I got my HDMI cables here www.MyCableMart.com. They were local to me so I could pick them up. They actually use MonoPrice for their bulk speaker cable.
GRBoomer is offline
post #9 of 10 Old 09-02-2012, 09:19 AM
fcaico's Avatar
I'm in the process of building my theater right now. I've run a 2" conduit to my projector and inside of that one HDMI cable.
Thats it.
I know that the conventional wisdom is to plan for the future and not use the conduit initially, but I really can't see the point. I actually fished the HDMI cable through it a couple times and it was so easy I don't feel any need to run anything else for the time being. If the HDMI needs to be changed for something else, or I need more cables I'll just fish them through at that time. I see no reason to run a bunch of cables I don't have any plans to use.
fcaico is offline
post #10 of 10 Old 09-02-2012, 10:43 AM
jautor's Avatar
Liked: 777
Well, you've got a 2" conduit, so it's going to be much easier to pull cables through than if it was a smaller conduit. Which is why we recommend to run existing cables outside initially. It's also much, much easier to pull cables through an empty conduit than one with cables in it (regardless of size). But with 2" available, and what sounds like an easy pull, you won't have any problem...
Running additional cables that you "don't need" is some guessing - but I only suggest running category cables because they're so flexible (in what they can be used for), and so cheap that if you never use them, you're only out a few bucks...
Jeff
