Fans for a rack - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 09-08-2012, 11:56 PM - Thread Starter
djqwik's Avatar
I just built an av cabinet with 4 wood shelves... 2 of them have Equipment on them. I did put holes in the shelves to pass wires through and have 2 exhaust ports on each shelf where equipment is. The cabinet is mounted to studs on a wall. I want to get 2 fans to help with the heat since some of the equipment gets really warm. Do I want to get exhaust or intake or both and how should I mount them?
Which quiet fans with thermostat do you recommend I get that aren't too expensive?
Thanks... Dave
Sent from my iPad using Tapatalk HD
djqwik is offline
post #2 of 4 Old 09-09-2012, 08:34 AM
Neurorad's Avatar
Quoted: 224 Post(s)
Liked: 142
What's an exhaust port? Does it have a door? What's above and below the cabinet? Recessed cabinet? Pic might help.
Believe nothing, no matter where you read it, or who said it, no matter if I have said it, unless it agrees with your own reason and your own common sense. -Buddha
Give a monkey a brain and he'll swear he's the center of the universe. -Fishbone
Neurorad is offline
post #3 of 4 Old 09-09-2012, 08:55 AM
jpcamaro70's Avatar
Quoted: 16 Post(s)
Liked: 25
Thanks... Dave
Is the cabinet open, or does it have a closed door?
I made mistake in cooling my cabinet, just installed one exhaust fan figuring it will pull enough air through the edges of the glass door. Under normal conditions this does the trick, but if you really push the avr, I mean really push it, my avr will go into thermal shutdown. I now must open the glass door if I plan on shaking the house.
If I were doing it again, I would have an intake and exhaust on different sides of the cabinet.
Denon X3100W
Klipsch RB-61 II (Fronts), Klipsch RC-52 II (Center)
Deftech StudioMonitor 350 (surrounds)
Klipsch SW-115 (sub)
LG 50LB5900
TiVo Roamio
jpcamaro70 is offline
post #4 of 4 Old 09-11-2012, 08:36 PM - Thread Starter
djqwik's Avatar
Its a wood rack with doors..I cut two holes in it and put metal grates in for air vents
djqwik is offline
